Question about Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive
Jumper settings for slave - Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive
    President:
  • 948 Answers
Page 21 in this manual shows the jumper should be removed to set this drive as a slave. You could also position it over the second column of pins, that is the cable select position and should also work if the drive is a slave or master. Your other drive on the cable would also need to be set to cable select if you do that.
Posted on Jul 11, 2009
Templarius
  • 86 Answers
SOURCE: jumper settings for maxtor
http://www.tacktech.com/display.cfm?ttid=379
Go there and enjoy dude ....
Posted on May 26, 2008
Beni S-P
  • 1006 Answers
Here you have MANUAL'S
Posted on Mar 24, 2008
worldvet
  • 859 Answers
Jump the middle pins, second set from the right when looking straight on with the power connector on the right.
Worldvet
Posted on Nov 17, 2008
  • 211 Answers
SOURCE: slave jumper setting
SATA drives don't have jumper settings.
You can set master/slave in BIOS.
Posted on Mar 29, 2009
astrotheque
  • 4 Answers
SOURCE: what are the jumper setting for slave on maxtor diamondmax plus 9
This web page shows the jumper settings you require.
http://www.google.com/imgres?imgurl=http://www.seagate.com/staticfiles/images/support/en/us/mxo_ata_jumpers_rev.jpg&imgrefurl=http://forums.macrumors.com/showthread.php%3Ft%3D387061&usg=__oBf6Czrk9E5_4ovUuuyxJCl68fY=&h=411&w=850&sz=83&hl=en&start=3&itbs=1&tbnid=J_I6lp0cCbuIwM:&tbnh=70&tbnw=145&prev=/images%3Fq%3DJumper%2Bsettings%2Bold%2BMaxtor%26hl%3Den%26sa%3DG
Posted on Dec 01, 2009
Jumpers Serttings on Quantum HD
CS = Cable Select
DS = Master
SP = Spare (Slave)
Nov 10, 2013 | Maxtor Computers & Internet
Jumper settings for master drive
if its a SATA hard driveyou dont need to set master slave the biggest capacity hard drive will set as master
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to IDE-1 means Pri slave escape then press f10 to save to cmos to restart
you will have to have master with slave set up
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
IDE-0 means Pri master
IDE-2 means Sec master
IDE-3 means Sec slave
single or master :::::
master with slave ::'::
slave :::':
black line between dots is plastic jumper
note the plastic jumper is ' located at the rear of the hard drive between the EIDE and electrical lead/s
Oct 03, 2011 | Dell Computers & Internet
Is there a jumper setting to run my hitachi 250 gb sata laptop hdd as a slave ?
There should be, look on the rear of the drive, close to the SATA and power connectors, you should see the jumper connections as well.
It varies from drive to drive, but the jumper setting could be engraved near the connector, look of SL for a slave setting.
If no, look on the label on the top of the drive, there should be the jumper settings listed there.
Some may be ambiguous, my last one offered the option of Master on / off. (Jumper in position 1 for on, no jumper for off) The off in this case was of course slave.
The result being, no jumpers - Slave.
Mar 26, 2011 | Hitachi 250GB Hitachi 2.5" SATA Hard Disk...
What is the jumper pin placement to make a slave of a DiamondMax Plus 9, 80GB hard drive?
The manual is linked below and section 3.3.1 covers jumper settings.
The slave setting shows the park position so you have a jumper on the drive so you can reconfigure it later.
A quick answer is that the slave setting is no jumper at all on the jumper pins.
DiamondMax Plus 9 Manual - DiamondMaxPlus 9.book
Feb 12, 2011 | Maxtor Hard Drive
I have a maxtor quantum fireball plus as 20.5 hard drive. i want to set it to slave. how do i set the jumpers?
on maxtor drives, you will find the jumper within a cluster of 9 pins. if you look on the bottom of the drive, on the circuit board, the pins should be labeled "ms" "cs" and such. the "ms" and "cs" stand for "master" and "cable select". you rarely use the true "slave" setting anymore, more often than not' "slave" drives are set to "cable select" and are attached to the middle, slave position on the ide cable. in "cable select" mode, the cable decides what device is master and what is slave, depending upon the devices' position on the ide cable.
to set the drive to "slave", set the jumper so that it only has 1 pin under it, and doesnt actually jump any pins, or just take the jumper out. only use the "slave" setting if the "master" device on the same ide cable is actually set to "master".
if the master device is actually set to "cable select" then you will have to set the slave device also to "cable select" and the middle position on the ide cable will set it automatically to be a slave. , instead of using the jumper to make it the "slave".
to set the drive as "cable select", which is what i would recommend, use the jumper to connect the 2 pins which are labeled "cs", the 2nd position from the bottom position on most older maxtor drives, and attach this hard drive to the middle connector of the ide cable.
Nov 25, 2010 | Quantum Fireball Plus AS (QMP20000AS-A)...
Need IDE jumber settings.
There is a little jumper block on the rear of a DVD. by IDE connector. on the case above there will be a Table marked . Master: Slave: CS. Now, you must set the jumper as to your drive's position. IE: Master or Slave, Master is on the plug at the END of the ribbon, the Slave is on the "Other" one. Accordingly the Master has the Master Jumper ON, the Slave the Slave Jumper ON. CS is Cable Select. It isn't all that used.
Feb 11, 2010 | Plextor 52x32x52 PX-230A Internal CD-RW...
I need jumper settings for maxtor n256 model 96147h6 i wish to run it as a slave pls help. thx
For use as slave there is no jumper connected. (Master on/slave off0
Oct 04, 2009 | Maxtor Hard Drive
Maxtor Model 32049H2 Slave jumper settings
I would guess that it is a diamond max driver, and therefore the jumper setting for slave should be no jumper at all. But in case I am mistaken, here are all the jumper setups for Maxtor drives, choose the one that looks like your setup and then choose the correct Slave setting:
Sep 04, 2008 | Computers & Internet
Slave harddrive jumper settings
usualy its just one jumper if no jumper on maxtors becomes slave. jumper on 50 is master. if u use cable select.. on same ide another device must also be cable select.
if one is master other is slave on same ide.
Jul 15, 2008 | Maxtor Hard Drive
Slave pin settings
hi frined
remove your hard disk jumper & u r hard will be slave
Apr 12, 2008 | Maxtor 20.4GB 7200rpm ATA-100 HDD p/n...
Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive Logo
2,094 people viewed this question
Top Seagate Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
