what usually cause the problem of most tagital tablet not turning on
is when the battery is over charged.the maximum time to charge a battery is six hours when bought new.if you dont it will pose some difficulties later.
there are three options
1. get another battery
2. get a booster to boost the battery
3.you also use LED by pinning its cable to the battery,this will take some time.then wait until the light on the LED goes off.it normally takes 3 days before the LED light turns off.
if you have taken these steps the next thing to do is to put the battery back on your tablet and connect it to a power source i mean electric current and see if it will respond to charging.if it works, then you got your tablet back,but if not please get a new battery.thanks
That symbol usually indicates the battery isn't charged or charging. It could be a connection problem, a charger problem, or a battery problem.
If you have an extra wall charger, try that first as they don't always last forever. Make sure the plug that connects to your tablet looks clean and not corroded.
If it still won't charge, then chances are the battery needs servicing to make sure the connection is OK or the battery just might need to be replaced.
Lithium ION batteries are usually rechargeable. The use mode for these batteries is that there are a set number of recharges that equate to the life of the battery. Usually that life is approximately 1,000 charges.
If you use your battery to 50% then recharge, you can do this ~2,000 times. As the life of the battery is used up, the maximum charge lessens which means where you may have had 8 hours of play time when the battery was new, you will only have 6 hours as the battery life is used up.
In order for a Lithium ION battery to recharge there must be at least a small amount of charge left as a "seed" for that recharge. If you drain a L-ION battery down to zero, it may never recharge again or the max charge will be reduced to an insignificant amount of the original full charge. eg instead of 8 hours you may only get 15 minutes, or 5 minutes, or no minutes.
You are much better off recharging when 50% depleted than using it up til your product stops.
L-ION batteries cannot be repaired only replaced. Most cheap products using L-ION batteries cannot have their batteries replaced.
try resetting it, power it off completely. If still not working check charger on another device to make sure charger is OK. If it is you will need to have it repaired, new battery or charging circuit or new socket
