If power is getting to the machine and you have verified this, the programmer might be the issue... it usually is.
.Please be cautious as regards safety
kindly remove the battery n check with power, if possible get checked the power connector of the power supply, with a multi meter, if its ok then its a main board issue. u have to change the main board
my Indesit washing machine start washing normally taking water and spinning and draining but for each cycle i have to do manual its automatic cycle is not working by it self the way it meant and suppose to be . for example if i start on number 3 to wash it just stay on number 3 not moving to next cycle . plz can anyone knows why this happen .?
IF you got a good board and a lot of replacement boards aren't good the only other thing that would make the set dead is if you have a bad main board, if your able to pull the back off and test the either 3.5 or 5 volt standby voltage if its ok then look at the PSON voltage, it should be at a half volt and go to about 3.5 when the power button is pushed..if you don't have standby you have a bad power board yet, if you have standby but no PSON the main board is bad, if you have PSON its back to the PS as being bad...Good luck!!
Ur tv still having the same result a flashing LED power light indication,after u change the tv power supply board.Mean only one thing the main logic Tuner signal board it is also dead too.The Tuner signal board that the board where the tv incomming broadcasting signal wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish main logic Tuner signal board for the replacement.Tries out the old power supply board with the new refurbish main logic Tuner signal board too 50/50 the old power supply could be still functioning.If ur old power supply board still good and functioning,than return ur new bought refurbish power supply to the vendor u bought it from to get some money back.
The main processor was interuppted and so has hung up or is faulty. Remove the main plug and press on the control pad of the washing machine to drain off any residual voltage that is remaining on the main board and which seems to have hung up the processor.When the plug is plugged in and switch please hold down the start/stop button.
If there is no result after plugging in the machine then the main controller board is a suspect. You can remove the control board and check the connectors, check the main door switch , if possible clean the connectors/ contacts as a last chance.
Hi, You have to check whether the main board is ok or not for that first hold all the buttons in the operational panel except the cancel button and switch on the machine it will process to check all the cycles in few mins. then check the machine whether it is functioning normally If not functioning properly means kindly change the main board
because of the short time this runs then stops, there could be maybe 3 faults,
1 check water inlet valves and supply for water flow
2 check for any motor action (use another programme)
3 check heater element for open circuit
number 1 or number 3 sounds most likely
hope i have helped, if so rate me please
