Question about LG DLG2525S Electric Dryer
Does maytag make an electric dryer with bottom vent?
  • 240 Answers
You want to vent of of the base of the dryer, directly down? None of the maytag/whirlpool line can handle this anymore. Only side vent options. GE may still be able to bottom vent. no dryer is really made for it out of the factory but some can be converted to it with a kit. usually if they can there will be a knock out panel for the duct in that place. GEs heater is on back wall making more room on the base for this kind of thing.
Posted on Jul 11, 2009
Maytag epic electric dryer takes a long time to dry clothes
check your vent by removing the vent from the back of the dryer run a normal load in the dryer and if it runs normal you have a crushed vent hose or it is plugged somewhere
Nov 17, 2013 | Dryers
Maytag dryer is taking forever to dry clothes, can even smell bad while running? how do i clean it besides the lint catcher?
Make sure the vent is not clogged. Its in the bottom of back side. Typically vented outside. Also, verify your heater elements are working by running dryer with door open to check for heat
Jul 27, 2011 | Maytag Neptune MDE5500AY Electric Dryer
I have a Maytag Dryer that stopped in the middle of a cycle and there is no lent at all and the dryer will not come back on..
Possibly a blown thermal fuse. May have to call repair man. Pull bottom panel and ohm our thermal fuse, just behind blower, lint trap assy. Also, check for clogged vent. This sometimes causes the thermal fuse to blow.
Aug 04, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore dryer w/back vent, need to make it vent into floor/bottom
you will go to any hardware or home depot and purchase a metal ductwork elbow. that will direct the vent down 90 degrees
Jul 14, 2009 | Maytag PYE2300AY Electric Dryer
The upper cabinet of the Maytag MCE8000AY Electric Dryer heats up, but the air isn't blowing out the vent. I can't find a filter to check or where the top cabinets vents to the outside vent. Anyone help??
You must remove the screws from the door and the hinges there are 8 screws 2on the top hinge 2 on the bottom and the other side also.After that the door lefts up and toward you.Once the door is off the panel around the door should come off then there is a shroud infront off drum remove 4 5/16 screws off then then cheak for lint obstruction or piece of clothing around the blower housing.Hope i helped:)
May 18, 2009 | Maytag Neptune MCE8000AY Electric Dryer
''AF'' error on Maytag Bravos dryer
"AF" means "Air Flow". Your vents are cloged with lint. I have had to vaccum out my vents several times, both inside and out. It's been a bit of a pain.
Apr 23, 2009 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Maytag gas dryer doesn't dry properly
SOUNDS LIKE A RESTRICTION IN THE VENT. CHECK AIR FLOW WHERE VENT EXITS HOUSE. IF IT IS NOT STRONG, INSPECT VENT LINE BEHIND DRYER. IS IT CRUSHED OR CLOGGED WITH LINT? THIS WILL CAUSE DRYER TO SHORT CYCLE. IF VENT IS NOT CLOGGED, CHECK AIR FLOW AT BACK OF DRYER WITH VENT DISCONNECTED. IS AIR FLOW STRONG? OF NOT, PROBLEM IS WITH BLOWER.
Jan 27, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
How do we get to the termal fuse on a maytag dryer
hi yES IT COULD BE THE THERMAL FUSE . tWO SCREWS AT BOTTOM OF DRYER REMOVE FRONT PANEL tHETHERMAL FUSE IS LOCATED ON THE AIR VENT TO THE LEFT OF THE ELEMENT . THANKSFOR THE QUESTION THE APPLIANCE DOC
Jul 25, 2008 | Maytag PYE2300AY Electric Dryer
Maytag frontload dryer
hi THE THERMAL FUSE IN THOSE DRYERS CAUSE THIS PROBLEM rEMOVE THE FRONT PANEL 2 SCREWS ON FRONT AT BOTTOM REMOVE . THERMAL FUES IS LOCATED ON THE VENTING TO THE LEFT OFTHE ELEMENT .THANKS THEAPPLIANCE DOC
Jun 22, 2008 | Maytag PYE2300AY Electric Dryer
Maytag Electric Dryer MDE308DAYW doesn't turn on at all when pressing the button
Since the vent was filled with lint I would check the High Limit termal fuse located on the front of the heater asm. It is best to replace the fuse and thermostat. These parts are part of a kit that can be purchased from your local supplier. The heater asm is located in trhe bottom left of the dryer. and looks like this
Jan 16, 2008 | Dryers
LG DLG2525S Electric Dryer Logo
428 people viewed this question
Top LG Dryers Experts
Mike
Mike
John Tripp
John Tripp
Craig Butler
Craig Butler
Are you a LG Dryer Expert? Answer questions, earn points and help others
