Question about Apple iPhone 3G Black Smartphone
I have the i9 When I make a call to check me account I sometimes need to press 1 How do i get the keypad on screen after I make a call and how do I download pisc and music
    Problem Solver:
  • 6 Answers
To upload pictures to the phone:
connect the phone to your PC using the USB cable
If prompted: press the "mass storage" option
The telephone should show up as a hard drive on your PC
If you have an extra memory card in your phone, TWO hard drives will show up
1 is your phone, the other one is your memory card
Move the mp3 to a folder called My Music
If the folder is not there, create it
Move the video to a folder called Video
Move the jpg's to a folder called Photos
Posted on Jul 12, 2009
Another business we share an office with wants to use our photocopier. How do we set up their own password to enable this to work.
You can always find solutions to Xerox problems @ www.xerox.com/support Once you set this up both you and your neighboring business will BOTH have to use individual codes. Hope it helps!
Solutions for : How To Set up or Modify Auditron User Accounts Solution : Set up or Modify Auditron User Accounts The following information describes how to register userIDs and usernames, login names, and passwords for authenticating accesses attempted through the network for scanning services, and impose restrictions on the maximum number of pages to be copied or scanned. Up to 500 user accounts can be registered.
NOTE: You must be a System Administrator to perform this solution.
  1. Press the [Log In / Out] button on the Control Panel. The Login screen will be displayed.
  2. Enter the System Administrator userID using the numeric keypad on the Control Panel, or select the [Keyboard] button on the Touch Screen to enter the userID, and then select [Save] on the Touch Screen.
  3. If necessary, enter the System Administrator password using the numeric keypad, or select the [Keyboard] button to enter the password, and then select [Save] on the Touch Screen.
    NOTE: The default userID is 11111, and the default password is x-admin (must be entered in lower case). If the userID and / or password have been forgotten, a service call must be placed.
  4. Select [Confirm] on the Touch Screen. The System Administrator Menu screen will be displayed.
  5. Select [System Settings]. The System Settings screen will be displayed.
  6. Select [Login / Auditron Administration]. The Login Setup / Auditron Administration screen will be displayed.
  7. Select [Create / Check User Accounts]. The Create / Check User Accounts screen will be displayed.
  8. Select a user account number or use the numeric keypad to enter a user account number in the Go to (001-500) field.
  9. Select [Create / Delete]. The User Account screen will be displayed.
  10. Enter a userID using the keypad on the Touch Screen, and then select [Save]. The Create / Delete screen will be displayed.
  11. Select from the following options:
    • UserID: Allows a userID to be entered using the keyboard on the Touch Screen. Up to 32 alphanumeric characters can be entered including spaces.
    • User Name: Allows a username to be entered using the keyboard on the Touch Screen. Up to 32 alphanumeric characters can be entered including spaces.
    • Password: Allows a password to be entered using the keyboard on the Touch Screen. 4 to 12 alphanumeric characters can be entered. The Password button is also displayed if a password was selected on the Login Setup / Auditron Mode screen.
    • Remote Login Settings: The following settings can be modified on this screen:
      • Login Name - Allows a login name to be programmed that needs to be entered when the machine is accessed through the network.
      • Password - Allows a password to be programmed that needs to be entered when the machine is accessed through the network.
    • Account Limit: Select [Copy Service] or [Scan Service], and then select [Account Limit]. Using the numeric keypad on the Control Panel, specify and restrict the maximum number of pages to be copied or scanned for the account. The maximum number can be entered within the range of 1-9,999,999 pages.
    • Reset Total Impressions: Deletes all data tracked for the selected account.
    • Reset Account: Clears all settings and data for the selected account.
  12. Select [Save].
  13. Select [Close] three times.
  14. Select [Exit].
Feb 03, 2011 | Xerox CopyCentre C123 Copier Copier
Tip
How to repair keypad problem in China Mobile
First we need to know china phone keypad connected with PCB how way
(A) Direct on PCB
(B) Flex System (flex cable direct soldering pcb to keypad panel)
© Flex and socket system include (flex one side soldering with key panel other side connect to pcb with socket)
(D) only Socket System (here have 2 socket, 1 with key panel others with pcb)
Keypad problem have various type
1. All key not work.
2. some key work and some other not work.
3. sometimes work and sometimes not work.
1. All key not work
china phone all key not work for this type of problem
(A) though its touch screen phone, first try to disconnect touch panel line from phone pcb or display flex (4 line)
(B) though not solve and keypad direct on pcb first you try to good clean full pcb with cleaner.
© though not solve now you try to format/flash your phone because some time key problem come from software problem.
(D) though still not solve now you check must be CPU. 95% china phone keypad directly going in cpu. and other 5% first going to resistor or capacitor near the cpu or keypad than going to cpu. so now first check them than you can try to re-hot, re-soldering or changing cpu.
(E) though its flex or socket system, first check GND connection continuslay pcb to key panel. next check full flex or socket all line going continuously pcb to key panel or not. also sometimes flex or socket shorted with other line or gnd so check also them.
(F) Also you can check all key anyone is short 2 line.
(G) sometimes keypad line broken from cpu pin on pcb to key panel, so check them.
2. Some key work and some other not work
Some key work and some other is not work for this type of problem
(A) maximum time this problem we face for flex or socket system keypad. so check flex cable and socket all line any line is broken or not and though need change them. and check all key connection on key panel.
(B) though its direact on pcb, some of key line broken internaly. and maximum china phone have alternative test point near every key or with other key on keypad. so check them with multimeter and though need connect to not work key with near testpoint or other working key.
© common problem is keypad metal ball (which is short 2 line on key when we press) sometimes its damage for phone water damage or over key voltage, so clean them or change.
(D) also try to check line continuously from cpu to not working key.
this problem come from this defect
(A) flex or socket system keypad any line is bad soldering or do lose contact. check them and
re-soldering or keep there line join with extra ware.
(B) for cpu bad soldering or cpu pin is broken. so re-hot or re-ball cpu.
on Jan 06, 2010 | Cell Phones
Annoying clicking sound with my new cect i9 3g
turn off the lock feature for the screen settings/security setup/autolock keypad. seems to have worked for mine but bummer not being able to lock keypad.
Jul 27, 2009 | Dual Electronics CECT P168 Cellular Phone
Apps wont work
Supposing these games and apps are installed correctly the problem is that most games and apps you find are for phones with a 'certain' number of keys, and the i9 has NONE ... the only solution is to try and convert them with a program called 'JAM'. This program 'tries' to convert programs to work with the stylus instead of keypad .... sometimes works, most times doesn't ....
Jun 12, 2009 | Dual Electronics CECT P168 Cellular Phone
Need to change the language in my i9.s apps
Go to the "Call" icon as you would to dial a number manually.
type in the following characters
*#0044#
press the "Call" button as you would to call someone.
You should see a message flash on teh screen saying changed to English.
Check any of your Java appl'n. They should now be in English.
Cheers.
Jun 11, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
I9 wap/gprs & mms settings for O2
First you have to make 2 data accounts,
1 for wap,
1 for mms.
Press service,
Data account,
GPRS, ok,
Pick any one of the settings because you are going to change it,
Press edit.
account name edit to O2 WAP GPRS,
APN to payandgo.o2.co.uk,
user name to payandgo,
password is password,
authentication type normal,
after each one if done is the option press it. this is the setting for wap internet.
You have to do the same again to make a new data account for the mms. the settings for this is
account name O2MMS,
APN payandgo.o2.co.uk,
user name payandgo all others same as before.
Now you have 2 new data accounts you need to set up wap.
press service, wap, settings, edit profile, sim 1 or 2 which ever you are using,
select the O2 WAP GPRS account that was made earlier,
press ok. press edit profile,
rename profile is ok it is O2 WAP GPRS,
edit home page to http//wap.o2.co.uk,
set data account to O2 WAP GPRS,
connection type wap, IP address 193,113,200,195
user name payandgo,
press back and activate profile.
you should be able to get on to o2 homepage now.
To get mms
press text, mms, mms settings, server profile, sim which ever you are using 1 or 2 ,
select the O2 MMS made earlier, edit profile, rename profile is 0k should be O2 MMS, home page is http//mmsc.mms.o2.co.uk:8002,
data account is the O2 MMS you made before,
MMS IP address 193,113,200,195
user name payandgo,
select back when all settings are entered and select activate profile. this should be it.
This works OK for me.
Mar 23, 2009 | Dual Electronics CECT P168 Cellular Phone
Need to establish PIN/Code for machine - help xerox c123
  12. Select [Save].
  14. Select [Exit].
Jan 08, 2009 | Xerox CopyCentre C123 Copier
Free games for i9 phones
The CECT i9 and i68+ have JAVA. Unfortunately, most of the free JAVA games out there, are designed for keypad input. You will have to look for specifically "touch screen" apps and games. And among those, not all of them will work. I am afraid it's going to be "trial and error" for a while.
As for HOW to load the JAVA apps and games on your CECT i9, here's how:
On your computer, with the i9 plugged in with the USB cable, drag the JAR or JAD files into the "RECEIVED" folder. After you're finished with everything you want to add, disconnect the i9. Touch your DOCUMENTS button, then "memory card," then "received," you will see your JAR/JAD files listed. Touch the file you want to install. The next screen, choose INSTALL. It will bring you back to the menu choices of "phone" or "memory card." Choose PHONE and select YES. It should give you a message when it has successfully installed. Then exit out to the main screen, touch the JAVA button. Select "Installed Java Software" and you should be able to use your newly installed JAVA apps and games.
Hope that helps.
Dec 23, 2008 | Dual Electronics CECT P168 Cellular Phone
Keypad I9 cect
When making a call there are three items above the pictures on the bottom of the screen, one is to choose options, the other is H-Free on the right. You want to hit the middle one which is a green telephone button which will bring you to the keypad to punch in ext and voivemail info
Nov 11, 2008 | Dual Electronics CECT P168 Cellular Phone
How to use the keypad of P1
In creating message try to press Number 1 or the "*" sign and then you can see the "?" when press this. In Number 1 press thrice for the * sign press once and then find the "?". In the photo album is not opening try to check your memory maybe it is low of space, sometimes the memory affected on some virus that some of the profile doesn't read quickly.
Jun 19, 2008 | Sony Ericsson P1i
Apple iPhone 3G Black  Smartphone Logo
Top Apple Cell Phones Experts
David
Marvin
Marvin
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
