Question about Grilling
I have a barbeques galore turbo four burner gas grill. i need to switch to propane. barbeques galore sent me the conversion kit with the nozzles and fittings. I'm not sure where the nozzles are i'm supposed to switch. Help.
  • ttilford Jul 12, 2009
    are the nozzles to the front side of the grill inside under the each burner? are their any diagrams or directions for this conversion so i can see what i'm attempting to do?
  • 784 Answers
You will have to replace the Nozzle IN EACH BURNER
1. Turn off the gas supply .
2. Disconnect the flexible gas line from inlet [usually on the ON-OFF control valve on the heater].
3. Remove the heater's control valve. Located on the end opposite from where the gas line was attached, is the nozzle [it looks like a brass pipe plug (hex head) with a small hole in the center of the hex head]. It is the size of this hole which determines the rate of gas flow.
4- Remove this nozzle,
5- Replace the removed nozzle with the new nozzle.
6- Repeat for each nozzle.
Good luck.
Posted on Jul 11, 2009
  • Linh Thanh Jul 12, 2009
    There should be an instruction or diagram from your kit according to your model. The gas first go to your control valve before going to your burner. Theerefore the closest to your control valve not futher from your control valve. Hope it could help.
Propane conversion kit
BBQ galore is a retailer so you need to know what you have to buy the parts. we stock the parts to convert any of the turbo models they sold and most of the other brands they sold. conversions are simple and inexpensive but the parts are not sold by the manufacturer because an actual manufacturer does not exist. the retailer buys appliances overseas and changes the name and model to make them their own. you need a grill parts company (like us!) who actually works on grills and know the parts because these import companies sold the same appliances over and over again to different retailers so there are other models that use the same parts which makes them readily available.
Sep 20, 2013 | Barbeques Galore Grilling
Can a Turbo STS 3 burner grill (720-0057-3b) be convert from natural gas to propane? Barbeque Galore has gone bankrupt and does not offer any assistance at their 1 800 number and I can't find any...
The original BBQ's Galore went bankrupt, but was bought by new owners, who still operate it as BBQ's Galore. However, they did buy any of the older company's parts supply. However, all you need are the burner orifices for each burner (including the rear burner) and a Hose/Regulator Assembly to connect the grill to the grill tank. Follow the conversion instructions in the Owner's Manual (see link below) and you should be able to do it.
http://www.grill-repair.com/images/grill/turbosts.pdf
I suspect if you call BBQ's Customer Support 800-752-3085. They can provide the orifices, as they are universal in fit. The Hose/Regulator Assembly can be purchased from any hardware store or home improvement center that sells grills and accessories, for about $30.00.
Once converted, you will see marked improvement in the heating capacity of Propane Gas, as opposed to Natural Gas. The grill will preheat faster and maintain higher temperatures longer.
I hope this helped you, Bradley and thanks for choosing FixYa. Happy Grilling!!
Aug 10, 2011 | Barbeques Galore Turbo STS 4-Burner with...
Can't find a natural gas regulator for a BBQ Galore 4 burner slide in grill. Believe it is a SST ( or sts) Turbo model. Any suggestions on what might be a valid substitute? Grand Hall ( the parts...
I assume you have already check with BBQ's Galore ( 800-752-3085 ), as they usually stock conversion kits, if that particular model is approved for conversion. Also, you will need 4 new Natural Gas Burner Orifices. The Propane ones will not work satisfactorily, if at all.
Hope this helped and Happy Grilling!!
Jun 28, 2011 | Barbeques Galore Turbo STS 4-Burner...
I have a natural gas used built in bbq and want to change it to lp barbecues galore 167935
Contact BBQ's Galore either online or at your local BBQ's Galore store, As they have conversion kits available.
Mar 11, 2011 | Barbeques Galore Turbo Classic 3-Burner...
I am looking for a conversion kit for a BBQ Galore Turbo from NATURAL GAS to Propane
BBQ Best (www.bbqbest.com.au) have natural gas conversion kits so you can convert your bbq from LPG to natural gas. Great site and good advice - Simon the owner was the only guy that could help me out.
Jul 30, 2010 | Barbeques Galore Turbo Classic 3-Burner...
Turbo STS grill, converting to propane from natual gas, orafices arn't available from Turbo
I would like to convert my Turbo STS grill from propane to natural gas. Where can I find the correct sized orifices?
Jun 17, 2010 | Barbeques Galore Turbo STS 4-Burner with...
Converting to gas
If it does not get hot enough when using natural gas then the small propane orfices must be sized larger for the equivalent BTU rating of propane. Conversion tables are online via Google
Jan 03, 2009 | Barbeques Galore Turbo Elite 4-Burner with...
Changing from natural gas to propane
You will need to contact the manufacturer for replacement burner nozzles. As Propane is at a higher pressure, the nozzles need to be smaller in diameter.
You will also need a tank fitting for Propane with a regulator attatched - and a large spanner to attatch it.
Make sure any pipe connector to this is fitted with an approved hose crimp, as "jubilee" type clamps are not recommended.
If you just fit the regulator, the burners can flare dangerously on the high settings - unless it has been designed to be dual fuel originally, and have replacement nozzles.
Jan 01, 2009 | Barbeques Galore Turbo Elite 4-Burner with...
Grilling Logo
99 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Marvin
Marvin
Are you a Grilling Expert? Answer questions, earn points and help others
