Question about Philips 42PF7320A 42 in. Plasma HDTV
My tv keeps changing to the "settings" menu. - Philips 42PF7320A 42 in. Plasma HDTV
  • debbie_varse Jul 18, 2009
    It's the right answer, but I bought a new tv instead.
    The cost to fix with labor was about $500+.
Change its main procesing IC
Posted on Jul 18, 2009
Menu Keeps Popping Up
There is either a short in the menu button on the TV or it is sticking/dirty.
Jan 30, 2014 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Sanyotv com
Sanyo TV Service Menu Method 1
1.Unplug the power cable.
2.Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet.
3.Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed.
4.Use the {CH+} {CH-} buttons to select menus.
5.Use the {VOL+} {VOL -} buttons to change settings.
6.Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data.
7.Press the {MENU} button or turn the TV off to exit.
Sanyo TV Service Menu Method 2
2.Press and hold the {VOL -} button on the TV while plugging the power cable back into the outlet.
3.Keep pressing the {VOL -} button until the TV powers on with the Service Menu displayed.
Sanyo Projector Service Menu Method 1
Factory Menu Access
1.Press and hold the {SELECT} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Factory Menu will be displayed.
Service Menu Access
1.Press and hold the {MENU} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Service Menu will be displayed.
Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
To exit, turn the Projector Off.
Sanyo Projector Service Menu Method 2
1.Press & hold the {MENU} button on the Projector for about 10 seconds.
3.Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
4.To exit, turn the Projector Off.
Jul 20, 2013 | Televison & Video
The book shows 0154 as the code for my sanyo tv ,it does not work .
Hello
If you are looking for its service menu, there is no code, but some doings is necessary as follows.
Two proceedings are given. One amoung them will surely open your TV to service mode adjustments.
To enter the service menu do the following. Most of the sanyo sets will get positve results with this.
* Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet.
* Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed.
* Use the {CH+} {CH-} buttons to select menus.
* Use the {VOL+} {VOL -} buttons to change settings.
* Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data.
* Press the {MENU} button or turn the TV off to exit.
OR
* Unplug the power cable.
* Press and hold the {VOL -} button on the TV
* Keep pressing the {VOL -} button until
OK
Jan 24, 2011 | Sanyo Televison & Video
Have new E370VL hooked up to Dish Network via coax. The picture jumps/blips? Connections are tight. Help.
This can happen when there is radio interference near the coaxial cables. Sometimes the interference is behind walls. The solution is to try a different combination of modulation and channel than what the DISH receiver is current set.
The DISH menu screen for this setting is Menu-6-1-5. With dual-tuner receivers, typically "TV 1 Out" is the TV that is connected in the same room as the receiver is located. "TV 2 Out" is the tuner that is fed to the remote TV via backfed coaxial signal.
All that needs to be done is to change the channel and mode going to the effected TV to something different. If your channel/mode is currently set to Air/60, try changing it to Cable/73. When you change the mode/channel in the DISH receiver, you need to set the remote TV to the same mode and channel.
Keep in mind that with some TV companies like VIZIO, they call their "Air" mode "Antenna". With VIZIO's the TV must be set on TV input and then go into the Menu to the Settings, Tuner Settings. Change mode type to match what you are trying on the DISH receiver, exit the VIZIO menu and manually enter the channel number.
Eventually with trial and error, you will find a mode/channel combination that isn't effected by your particular environmental interference.
Jan 03, 2011 | Televison & Video
Subtitles keep coming on
Hiya, have bought an Alba 26" LCD TV myself today. If you go into the menu and then into subtitles change it from English to Dutch. This should solve the problem. :-)
Dec 13, 2009 | Televison & Video
My tv keeps reverting to the Philips TV Menu
If that TV has a 'menu' button on the front of the set, make sure nothing like coca-cola has spilled into where that switch is located. I would try a different remote in case the remote is getting flaky....
Oct 21, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Audio Menu keeps popping up
There are probably some failing components in the uPC control area, or with the keypad board on the TV sets front panel. It is also possible that there is a problem with the filtering of the distributed power through the circuit boards of the set, and there is some noise causing a false trigger of the function.
This type of fault can take some time for the tech to figure out, unless it is a published common fault with the particular model of set where they give a list of parts to change.
Jerry G.
Dec 04, 2007 | RCA F36676ET 36" TV
Sony KP-61XBR48 Service Menu Item Keeps Changing
the only thing to do is pick which video mode you want (tv, vid1,2,3,etc) and then turn off and then immediately on for an hour or two and then the picture will come on. I,ve heard it's an internal transformer problem.
Sep 26, 2007 | Sony KP-61XBR48 61" Rear Projection...
Philips 42PF7320A 42 in. Plasma HDTV Logo
55 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
