Question about Dryers
Whirlpool Model LE768MXMWO spinning
My dryer turns on, the cabinet gets warm like it is working, but the clothes are not dry after three entire cycles.
  • 290 Answers
Re: Whirlpool Model LE768MXMWO spinning
The most common cause of this is the air duct is restricted. It may be clogged with lint or, if you have a plastic vent hose, it may be kinked so that the moisture can't get out of the machine.
If you can get to the vent where it comes out of the house, go out and see how hard the air is blowing out the vent.
If there is no problem with the vent, post back and we will go through checking other parts of the machine.
Posted on Nov 15, 2007
0 characters
3 Points
Problem drying clothes
This is the classic symptom of "poor air flow". Another symptom you didn't mention (but I bet is happening) is that the top of the dryer gets VERY hot. OK, don't move your dryer yet... get a flashlight and look behind there. See the flexible vent connecting the dryer to the wall? It must have SMOOTH, FLOWING turns. No crushing allowed. If it's crushed/pinched, you found the problem. It's "choking" off the air flow... not allowing the hot air to escape and containing all of it in the dryer cabinet. If this is the problem, pull the dryer away from the wall about 8" and make sure the vent isn't pinched off anymore. Leave your dryer this far out, it'll ensure that this doesn't happen again. If the flexible vent is OK, there is a blockage in your house's internal dryer duct work somewhere. Turn the dryer on and go outside to where the exhaust is. Check air flow. Check the exhaust vent for debris (I've seen birds build nests in the outside exhaust, incubates the eggs...but your clothes won't get dry!). If your dryer location and the exhaust location are quite a distance (20' or more) from each other, you should hire a professional to come out and thoroughly clean it out for you. In this case, you should have this done once a year as part of routine Home maintenance. To test and verify my solution to this, you can remove the dryer vent from the wall and cover the end of it with a pair of old pantie hose. Then run the dryer as usual (the pantie hose will act as a secondary lint trap). You'll see that the dryer will be happy again and the clothes will dry in no time at all.
Aug 21, 2007 | Whirlpool GGW9200L Gas Dryer
Dryer won't dry clothes
How to check the timer:
Sep 26, 2012 | Whirlpool Dryers
I have an older model gas dryer with the lent catcher located on top of the dryer. It spins and it gets hot but it is not drying properly. I have to run the dryer three times to completely dry my...
you might have a restriction in the exhaust system. check the entire exhaust vent tube/hose from the back of the dryer to the outside of the building for any restrictions. check the outside exhaust vent for any restrictions or obstructions. make shure the exhaust tube/hose are as short and straight as possible any sharp curves or bends can restrict air flow.
Oct 07, 2011 | Whirlpool GGW9868K Gas Dryer
My dryer does work but doesn't heat very good and the clothes take forever to dry.
there is a restriction in the vent-housing or vent tube, you can remove the tube and see if it is blowing a strong warm/hot air out, if it is then it is in the vent tube, if not then it is in the vent housing. you will need to remove the cabinet:
Oct 24, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer is not drying properly. Have to go through a couple of cycles to dry clothes.
2 things are needed to dry clothes. 1 is good air flow. Check to make sure that the dryer vent is not clogged or partially clogged with lint. Also make sure there are no kinks in the vent hose. With the dryer running you should feel good air flow blowing out of the outside house vent. The 2nd thing a dryer needs heat. Check to see that the dryer feels warm to hot when you reach in to tough the clothes. It is possible that the heat element has partially failed. Another thing to investigate is how well the laundry machine is spinning out the water in the spin cycle. This spin cycle is used to get as much water out as possible prior to placing the clothes in the dryer. The wetter the clothes when they come out of the laundry, the longer it takes to dry them.
Oct 01, 2010 | Whirlpool Dryers
Have a whirlpool cabrio gas dryer. It takes several hours to dry one load of clothes. The clothes seem to stay damp towels may take all day... what could be the problem
Have you opened the door while its running to see if its warm inside (heater working) If its getting warm and still not drying the clothes properly you likley have a air circulation concern. With the unit running check the exhaust vent outside from dryer it should have a good flow of warm air, if not you have a restriction sowher between the unit and outside. Heat alone will take forever to dry clothing,you need good air circulation to remove the moisture from the clothes otherwise all you will end up with is warm moist clothing.This generaly happens over a long period of time and then all of a sudden you realize the dryer is not working like it use to..Hope this helps you with your concern.....
Aug 09, 2010 | Whirlpool Dryers
Clothes do not dry completely on one cycle
Check your dryer vent (the entire length) for lint build-up. Check that the vent is opening properly (the flapper type can come loose and block air-flow).
Those are the most common reasons for an inefficient dryer.
I hope this helps.
(we have had the vent get blocked by the flapper)
Apr 03, 2010 | Whirlpool WED5300S Electric Dryer
Gas Dryer Heats up very little, but not enough to dry my clothes
you need to check that for vent hose is not kinked if it is not then remove it from the dryer and see if it work right if it does then the vent tube that goes thourgh the wall has a blockage
Feb 24, 2009 | Whirlpool LGR3624JQ Gas Dryer
Dryers Logo
57 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
