How can I get a replacement AC adapter model 090-02180-I3? I assume mine has faided as the blue light on the unit went out at the same time as the picture quit.
  • d_goss Jul 11, 2009
    I appreciate your directing me to a repair source for my AC adaptor. Could not find any local source that even cared to consider my problem or suggest a solution.
  • 3,037 Answers
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} That particular power supply is no longer manufactured. From my knowledge, it has had a lot of failures after a short time. You can "watch" eBay for one being placed up for sale, but I have seen prices in the $125 range.
I recommend you contact a company that specializes in repairing power supplies of this nature. One I have recommended before, and have had good results is http://www.compusolinc.com/power_supplies.html Another one, located in
Texas, I've heard good comments about but have no direct experience is http://www.thepowerclinic.com/
One advantage to having it repaired, is that these companies will warranty their work, and the reason that there are probably so many failures in these units, is that the components were rated at minimal acceptable levels - the repair companies will replace the failed components with one that exceeds the minimal levels for longer operating life.
Benjamin
Posted on Jul 11, 2009
Hp pavalion dv6550 runs on charged battery but not on adapter and does not charge the battery either. When the AC adapter is connected the blue light comes up so I'm assuming it is powered and con
Try another cord/charger with the EXACT same power specs as the original. Has the AC jack in the laptop been damaged, loose connection, due to pulling on the cord while plugged in? Try to wiggle it when plugged in to see if there is any connection. The AC jack may need replacing, if your lucky.
Apr 07, 2013 | HP Pavilion Computers & Internet
Hp compaq 7620s wont start ( constant blinking blue light )
The adapter output appears correct, the batteries often work in that voltage range. But the problem you have is the motherboard, the HP line has constant trouble with the main board, only option is board replacement.
May 12, 2012 | Computers & Internet
Battery has gone dead. When I plug the A/C cord in the light on the charger immediately goes out and won't charge battery.
try connecting ac adapter alone without the laptop, check if ac adapter light will stay green or blue.
try another power outlet using the ac adapter alone without the laptop check if the ac adapter light will stay as green or blue. if all fails replace ac adapter.
if ac adapter stays green or blue try connecting to the laptop without the batt, check if the ac adapter light will stay on, if yes then try connecting ac adapter to laptop with the batt plugin check if the light stays green. if not update the BIOS. if fails replace motherboard.
Oct 12, 2009 | Dell Latitude D610 Notebook
AC Adapter blinks once, but no power getting to hard drive
These drives are known for lunching the power supply within the unit itself. Depending on you PC configuration, you may wish to do the same as I did when mine went. The drive itself is a standard 7200 sata drive. If your motherboard has sata capability, and/or a spare sata connection, you can slave the drive into your pc, and end of problem.
Sep 19, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
My protron lcd tv power supply died and i would like to find a new one. it is 120 to 12 volts and 3 amps but has a 4 pin connector
Mine did the same thing right before 4th of July. I was watching tv and it just went off. At first I thought my power had gone out, but the tv was the only thing that was off. I tried to turn it back on, but it was dead as a doornail. :-) When I plug in the power cord the blue light usually comes on or the fan runs, etc. I tried to plug in the power cord and it did nothing, so I was upset thinking I had to get another tv.
I took a gamble that it was the powercord and after searching and searching finally found this website. http://www.lcdpayless.com. I placed my order on Thursday and went out of town for the 4th and I checked my mail today (Monday) and it was there. I plugged it in, the power came on and the tv works perfectly....plus the new cord doesn't have an annoying fan.
The cord is pricey at $117, but it beats buying a new tv. The company accepts returns minus a 20% restocking fee and shipping, so I figured worse case scenario I would only be out of $40+bucks if it didn't work and I had to send it back. So, if you plug your current power cord in and it's not lighting up, it may be your power cord. Hope this helps!!!
Jun 09, 2009 | Protron PLTV-32 Television
No response
First follow procedure to try to reset the power.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
May 23, 2009 | Acer Computers & Internet
Acer laptop shut of during power outage .
From the Acer website:
Product
Notebook
Issue
Power Issues or Will not Boot
Solution
If the notebook does not power on:
Make sure the ac adapter is correctly plugged into the notebook and into the power cord.
If everything is plugged in correctly and it still will not power on, follow these steps to complete a ‘power reset' of the notebook.
Also, depending on whether your power went down "clean" (quick and stayed off), or went down and quickly came back on and off many times. Or when it came back on "clean" (came back on quick and stayed on), or it came on then off many times, your power supply may have been damaged from the power surges Are you having any problems with any other appliances?
Feb 07, 2009 | Acer Aspire L100 PC Desktop
Avion 32" LCD HD TV AC Adapter 090-02180-I3 Problem
Contact dave@thola.com
He recently repaired my adapter within 2 weeks.
Excelent job!!
Jul 27, 2008 | Televison & Video
Screen went black
plz try by resiting the ram, if the problem persist then you have problem in display adapter,send it to the vendor from whom you have bought
May 16, 2008 | Compaq Presario 700 470024-192 Notebook
Protron 32 with no power
Is the blue light on the blax box ( ac adapter) on? Mine just went as well.... if its not on you need a new ac adapter... Mine overheated, vents got clogged with dust, this is the second one that went on me ... but the TV is fine
Sep 10, 2007 | Protron PLTV-32 Television
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
