Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Can you take the water tank liner out of the Bissell ?
Can you take the water tank LINER out of the Bissell Pro-heat12 amp ?
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
jklkj
Posted on Sep 30, 2010
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
I have a bissell pro heat 2 it will spray water through hand held pipe system but wouldnt spray from main capet brush area can you help me please
Ours would not spray water either, after messing with it for ages I discovered the round black housing that the tank locks into where the water flows out of the tank was loose. So I held the housing from underneath while seating the tank & it started working. It's very flaky & a lousy design. Good luck.
Jan 16, 2011 | Bissell Carpet Cleaner Powerbrush Deep...
My Pro heat 2x by Bissell does not put out or **** up water Brand is Bissell. Model is 8920 12 amp
Please check the following with liquid in both tanks.
- Check to see if the machine will spray through the hose with the setting on tools. If it does, the pump is fine. Continue troubleshooting.
- Check for debris on spray tips. Clean them with a soft brush (on old tooth brush works well). The spray tips may be lifted out for easier access.
- Ensure the tank lid is properly attached to the bottom of the tank. To attach this properly, remove the Water Tank from the machine. Hook the front window onto the lip of the bottom container and then allow the window with lid to cover the complete tank. Secure the latch on the back of the bottom tank to the back of the tank lid. THE TANK LID CANNOT BE ATTACHED PROPERLY IF THE BOTTOM TANK IS ALREADY INSTALLED IN THE MACHINE.
- Check the bottom of the Water Tank and the Formula Tank to make sure each has a red auto-load gasket attached. Make sure the Water Tank and the Formula Tank are seated properly. Depress the x on this gasket to ensure this depresses and release back out. Liquid from the tank should dispense.
- Remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
If the machine continues to not spray, check the following:
REMOVE THE COLLECTION TANK:
• Make sure the unit is set to water rinse
• Remove the smart mix bottle and fill it with water only
• Place the smart mix bottle into the collection tank reservoir
• Run the unit and try to spray. If the machine sprays, you will be able to see the water level decreasing in the smart mix bottle and you will need to replace the bottom tank. It is possibly warped.
If these suggestions do not resolve the issue contact BISSELL Consumer Services at...
1-800-237-7691
Mon-Fri: 8am to 10pm ET
Sat: 9am to 8pm ET
Aug 15, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell pro 2x the cleaner solution & water
heatman101
shg
Jul 11, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Water line routing
The biggest prob with Bissel is not pumping soap. Becuase if you don't run hot water through this tank the soap will dry and clog after cleaning and storing. Before taking it apart try running hot water through the solution tank and help break up the residue, best of luck. Steve
Jun 06, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
My Bissell Pro Heat 2X steam cleaner is not releasing the water
Have you tried cleaning out the small filterfrom the reserve tank? Also, check the tank/resevoir valve is operating properly, when you take it out to fill try to make water release from tank.
Apr 29, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Mar 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Cant get any water to floor or hand dispenser on my bissell power pro steam cleaner
That means that the pump belt is worn or stretched and needs to be replaced. Here is a link to the belt you need and the manual which has instructions:
Bissell ProHeat Belt and Manual
Dec 12, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
32 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
