Cylinder is upside down
Remove lock from door , remove spindle from center of lock by center spindle then depressing release and remove spindle ( release is spring loaded at base of spindle , insert a flat peace of 1/2 " wide metal with a V shape at the end , , push the metal I to the lock and release the lock . it may have to be taped in until the lock falls out,
SOURCE: I have Kwickset door knobs on my outside doors. I
The instructions they send are almost always generic and cover more than one subject.
If you insert the key and turn it all the way clockwise, you should be able to insert the tool tip they sent you into the hole on the shank part of the handle. Pull straight out and it should come off. Some times it takes several attempts to do.
Next turn key counter clockwise back to starting position and remove key. Dump lock out of handle, paying attention to orientation. Turn lock 180 degrees and reinsert back into handle. Put lock and handle back on to door and reinsert the key. Turn key clockwise and push.... remove key.
Hope this Helps,
RSMITH972278
P.S. PLEASE RATE MY ASSISTANCE
