Question about Canon PIXMA MP160 All-In-One InkJet Printer
Service error 5100
When i give the print out command then error showservice error 5100. actually i changed my printer cartiridge & this is new. what can i do . please give a proper solution.
  • 4,345 Answers
Hi You can Try 2 things.
This some times works
There is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
Error code 5100 i have turned off machine, unplugged at electrical source. After 30 min replugged in to electrical source, turned on printer. Pressed print button. Machine processes for a few minutes...
Hello and Welcome
Error 5100 means that the cartridge can not be detected by the printer.
Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve these follow the following steps. I hope it works
  1. Turn off printer
  2. Remove both the cartridges from the printer
  3. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  4. Return the cartridges
  5. Turn on the printer.
Error will be removed
Further assistance i am here to help
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using Fixya
Mar 11, 2011 | Canon PIXMA MX700 All-In-One InkJet...
Service error 5100 on Canon IP 2770
Hello thanks for using FixYa
Error 5100 means that the cartridge can not be detected by the printer. Actually the printer is not actually loading the cartridge and showing you the error 5100.
  • Turn off printer
  • Remove both the cartridges from the printer
  • Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  • Return the cartridges
  • Turn on the printer.
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Feb 01, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Printer is not working properly. after giving print command, a crrr voice is there and occures error no. 5100
Hi Good day!! It is a waste tank error 5100 you need to reset your waste tank
Please follow this:
1. hold RESUME then press & hold POWER
2. release RESUME, then press it twice, the light should go amber then green again.
3. you're now in service mode (you can release POWER now)
I think waste tank reset is 4 presses of the RESUME button. To confirm, press POWER once.
Thank you for using FixYa
Please accept if my solution helps you
Nov 10, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Service error 5100
Google service error 5100 you need to download the free epson counter resetter, once downloaded install choose your model number & it gives you the choice to reset the counters, do that & you will be printing again.
Nov 08, 2009 | Canon i860 InkJet Photo Printer
Canon pixma ip1300 initialisation problem
I have a canon ip 1300 produces an error(both LED's are alternately blinking one blink for the green led and 5 blink from the orange led) then it will produce an error 5600.
Dec 03, 2008 | Office Equipment & Supplies
Kodak printer
pls make sure that there is no error in blk cartridge nor ther any warning symbol, ensure as well that you have installed corrctly and you can see the presence of the blk ink on your console. in other areas pls check when printing on the printer properties and select blk to identify what is the real prob.
we can start from here goodluck
Jul 29, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Service error 5100
may be the driver are not installed correctly ... just try reinstalling the drivers ... and make a check that you have inserted the ink cartilage or not ...
if not insert it and then give try ... it may work ..
if problem persists then call the service rep ...
Feb 07, 2008 | Office Equipment & Supplies
Error 5100
I Have the same problem. Greece.  This is the second services and I a lot overwrought with this instrument.
Him I was deprived 2 times and now one more time will again make installation of other instrument for the time of repair.
Rather I will reverse the sale in order to I finish with problems with canon.
actlaw@ath.forthnet.gr
Nov 17, 2007 | Canon SELPHY DS810 InkJet Photo Printer
Canon ip2000 service error 5100
I have been facing same error and this was the solution.
Canon Error 5100
Sep 08, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
Clive
Clive
old marine
old marine
