Question about Planar Computers & Internet
I hooked my monitor up and it gives me a reading that says "over range".
  • 79 Answers
While booting pc keep pressing F8 key, than select VGA mode in menu shown
Posted on Jul 11, 2009
I have a LG Flatron EW224 computer monitor. It was working great but one day the screen went blank and reads in the center of screen: D-Sub out of range 68.5Khz/85Hz. Does anyone know how to correct this...
This is usually due to your computer Video resolution being set to a setting out of the supported range of your monitor, Lowering the computer video resolution should solve this issue.
Oct 01, 2013 | LG Flatron 22" Super Led Ew224 1080p High...
Out of range
Hook a spare monitor to the pc computer to rule out the video graphics card, change the video cord from the computer to the monitor to rule out the wiring.
May 21, 2012 | Westinghouse Electric L1916HW 19" Monitor
My 2004 Tahoe did not pass emmissions, it read not ready, I took it to a Chevrolet dealer who hooked it up a tech do scanner and it did not read anything says it's not hooked up HELP!!! PLEASE
This is normal when it says not ready some one could disconnected the battery,which would set the monitor to not ready,To set the monitor just drive it.Now if you hook it to the smog machine and it read not ready then you vehicle is communicating as for the tech 2 that did not communicate thats thier machine problem not yours.There is a way to set the monitor which involve the trip monitors by driving the vehicle a certain way,which doesnt work what I find effective is you just drive it and use it,when its ready its ready give it one day.
Mar 28, 2012 | 2004 Chevrolet Tahoe
I am putting my old computer (Dell XP) in garage to use strictly to view files, play dvd's/cd's, etc. It is not going to be used to go online to internet. I hooked up...
Hi there.
You'll need to adjust the refresh rate. I have recently written a tip on adjusting a monitor's refresh rate. I suggest you give it a read and let me know how it goes.
You can see my tip here:
http://www.fixya.com/support/r9352855-adjust_or_change_monitors_refresh_rate
Enjoy my tip.
Slasher_X
Sep 24, 2011 | ViewSonic VX1935wm LCD Monitor
LG Flatron l1515s which is giving Out of Range 64.0kHz / 60Hz and can not even give setup menu. Please help.
This is not a setting on your monitor. It is a setting on your operating system. The display settings needs to be set to a 60Hz refresh rate.
Hook up your old monitor and right click on desktop --> properties --> and then to display and advanced settings. You can then set it to proper refresh rate and plug the new monitor in.
Mar 28, 2011 | LG Flatron L1515S 15" LCD Monitor
I hooked up my monitor to my pc onthe screen it is saying out of range with some numbers i can't get my mouse on the screen to fix it...help
Your PC video resolution is too high, you need to lower it to the native resolution of your monitor.
Please read here:
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Please leave rating if it helps.
Feb 14, 2011 | LG Computers & Internet
Change from a monitor to a flatscreen
You need hook up your old monitor back and set the PC video resolution to 1024 × 768 @ 60Hz which is the native/max resolution of the E15T4, remove the old Dell monitor and connect your E15T4.
You are getting out of range because your PC video resolution is too high for the E15T4 to display.
Apr 28, 2010 | E-Machines eMachines Monitor E15T4
Screen says out of range
I would say that the computer is trying to use a display resolution that the monitor is incapable of displaying. You may have to lower the resolution from the PC before you get a picture. Make sure you install the correct drivers for the monitor onto the new computer and use a different monitor to adjust the display resolution to a level that the monitor is capable of displaying.
Dec 15, 2009 | AOpen F2705 17" LCD Monitor
Signal out of range
1: Signal out of range meas the monitor can't handle the input refresh rate. lcd and Tft monitors usually supports 60 and 75Hz refresh rates.
2: The Resolution you are using to view the desktop is too high, this number is depending on the size of the lcd monitor.
a 15" lcd usually runs with: 1024x768 with 60hz
a 17" lcd usually runs with: 1280x1024 with 60hz some of them supports 75hz.
a 19" lcd usually runs with 1600x1200 or higher.
I recommend reading the user manual if you have it, or checking the information on the manufacturer's website.
3: As a solution turn on your computer and after it passes the bios screen press F8 and select VGA mode.
This will enable 640x480 (standard vga) resolution and 60Hz refresh rate, after windows boots up you can change thease nmbers , and windows automatically asks for turning to 800x600 60Hz.
If you want to change the resolution go to: Right click on your desktop, select properties , select settings tab, and adjust the resolution on the bottom of the window.
Hope this helps, good luck.
Nov 10, 2008 | Kogi L7CH Monitor
"Out of Range" Message
This happens when your screen resolution is set to something higher than what your monitor can display. For example, if your monitor supports resolutions of up to 1024x768 and your video card allows you to crank it up to 1600x1200, doing so will give you an error. Another reason you might get the error is if the refresh rate you selected a certain resolution is higher than what your monitor supports. The monitor can't "sync" with the video card, so it just gives you that "Out of Range" error. If you are sure you have your resolution set at a reasonable amount, make sure that your monitor is plugged in all the way. Actually, if you're like me, that might be the first thing to check. =)
If you are using Windows, hold down the F8 key while the computer is starting up and choose "Safe Mode" from the list of options that appears on the screen. This should force the display to be a low enough resolution so that it will work.
May 02, 2008 | Compaq Presario V400 14" CRT Monitor
Computers & Internet Logo
133 people viewed this question
Top Planar Computers & Internet Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jay Plesset
Are you a Planar Computer and Internet Expert? Answer questions, earn points and help others
