SOURCE: heating
it needs to be blown out buy a can of compresseed air and blow out where the fan is on the bottom and the air grills you will see a bunch of dust and lint come out and it will run much cooler
SOURCE: HP nc8000 shuts down after 10 seconds
try pushing on the upper right corner of your laptop, above the home key, does it start up again?
If so its the maxim chip
if not take one so dimm out and dissable wireless.
Could also be your battery not charging because a battery or power cord malfunction.
SOURCE: i am using COMPAQ CQ60-101 au laptop.my laptop is
Try to check if your cpu fans are working. If it is still working. Try buying a decent laptop cooler or you can add an electric fan to further cool the laptop.
Thanks. Cheers!
SOURCE: I'm having a problem with my computer, it's an HP
Hello, here is a solution that I think might be helpful. If you have the recovery CD that came with you laptop, then i suggest you do a new installation to see if it keeps giving those error. And if it does please take it to your nearest HP shop for diagnostics. I hope this solution has been helpful. Have a wonderful day.
SOURCE: no display power on after one miniute it is shutdown
1)have you cleaned RAM slots if not clean them and try or else
2)Try to start in safe mode if problem persists
3)open BIOS during boot and check temperature of CPU and tell me details
4)also send me your hardware configuration and how this problem started
