Question about Kenmore Dryers
Kenmore dryer hot air blows when it starts and but does not re ignite
  • 234 Answers
Ahhh yes, classic sign of weak coils. there are 2 circular black coils near the ignitor that energize and let the gas come in..they tend to get weak over time. Change them and your problem will be fixed..good luck :)
Posted on Jul 18, 2009
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Dryer not blowing hot air
When you say 220 gas dryer I'm not sure what you mean. If it's 220V then it should be an electric dryer, not a gas dryer. Troubleshooting is totally different between gas and electric. If it's electric (large 30A 220V plug) then good chance heating element(s) have gone bad. You can look up parts on www.searspartsdirect.com Have your complete model number. IF it's gas, it may be the pilot ignition has failed
Jul 26, 2010 | Kenmore 62602 Electric Dryer
No longer blows hot air, only cold air
when a dryer does'ny blow hot air,it's normally either the element or the stats on the element.
Nov 01, 2009 | Dryers
Dryer doesnt blow hot air.
I find that quite often the ignitor is out of alignment or the glass window is covered with lint.
a gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes.
There are two common styles of ignitors, glow ignitors and spark ignitors. The ignitor ignites the gas either by heating up and glowing, or by sparking. If the ignitor fails, the dryer will not heat.
The easiest way to check the ignitor is to observe it. Remove the small access panel in front, select a high temperature setting and start the dryer. Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow or spark. If you see it glow or spark, then the ignitor is working.
Aug 19, 2009 | Kenmore Dryers
MY DRYER GETS HOT ON TOP OF THE DRYER (KENMORE) COULD IT BE THE VENT?
start dryer, go outside and see if vent is blowing hot air. If not then vent is clogged with lint, esp if vent has a curve or elbow in it. unhook vent at dryer or os vent and run a vacumn hose in as far as you can. easy way to determine if vent is to unhook at dryer and see if dryer blows air, could be just inside at vent opening
Jul 11, 2009 | Kenmore Dryers
Dryer working but not blowing hot air
Either bad thermal cutoff or bad element .( first 3 numbers missing on model #)
Jul 05, 2009 | Kenmore 800 6983 Electric Dryer
Hi, If you use the automatic dry cycle, there needs to be heat in order for the timer to advance.
Remove the little cap in the front lower left corner and start the dryer. The ignitor should glow for about 15 seconds and then the gas should ignite. If there is no glow from the ignitor and the fuse is good, you will need to remove the front panel and check the senser on the burner, the ignitor, and the thermostats.
I hope this helps you. If you need more assistance on this issue, please let me know.
Vic
Jul 03, 2009 | Kenmore 63942 Dryer
you either have bad element or bad thermo disk or thermo fuse
Jul 01, 2009 | Kenmore 63942 Dryer
My dryer is ot blowing hot air
Remove the heater vent, then turn dryer on. Does this fix problem? If so then you have a block in your vent hose.
Dec 31, 2008 | Kenmore 75962 Gas Dryer
KENMORE DRYER
Electric or gas?
Sep 13, 2007 | Dryers
Dryers Logo
47 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
