Question about Flotec 1/2 Hp 3000 Gph Utility Submersible Pump
What size submersible pump do i need to deliver 20000l/hr ,pump is 50 meter deep in bore hole.
    President:
  • 1,730 Answers
That's a lot of water. In the U.S. , pumps are rated in GPM (gallons per minute. Your 20000 liters per hour converts to 88 GPM. So you need to find a pump that can produce at least 88 GPM.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 11, 2009
I have a submersible deep well pump and lately if I run the water for 15 minutes straight it shuts off why.
Grundfos pumps are thermally protected by a bi-metal strip temperature switch. Your pump is overheating. Typical cause of this is operating to near the shutoff head pressure. Try reducing the discharge pressure by increasing the flow rate.
Jun 25, 2016 | Grundfos Pumps Grundfos 60S50-9 61530095...
Any suggestions when a newly installed utilitech pump won't turn off?
its sucking dry or your wiring is not right, or of course an airleak, or the prime is not good, did you fill the pump prime hole at the 3/4 plug on bottom.of pump, deep well pump do you mean submersible? if so and it is a deep well submersible there is a prime, its got to be an airleak in the line or the pressure tank is not pressured up to the specs, and the gauge
May 16, 2015 | Jet Plumbing
I have a submersible Gould pump in a well. Recently air is getting into my system and coming out as irregular spurts. I replaced the water storage tank and the check valve, and the problem persists
Sounds like pump is not set deep enough and getting air. If the pump is as deep as it can go you may have to have to screen in the well changed or cleaned with acid pellets.
Dec 28, 2014 | Plumbing
How do I troubleshoot a Simer 3/4 hp submersible deep well pump
Check power at well head. then turn power off and disconnect wire nuts. check continuity on leads to motor should read about 500,000. Check each lead to ground for shorts.
Oct 14, 2014 | Simer 2873G Submersible 4" Well Pump,...
Rain soft water treatment system install manual
dont know about this as i have a pozo or a bore hole in english with a submersable pump
Apr 05, 2012 | Cars & Trucks
What is the ideal operating fuel pressure for an 89 Corvette w/ LT-1 TPI
The 5.0L injector is sized to deliver approximately 4.05 milligrams of fuel with a 2.5 millisecond pulse or 18.13 lbs per hr at approximately 36 PSI. The 5.7L injector is sized to deliver approximately 4.83 milligrams of fuel with a 2.5 millisecond pulse or 23.92 lbs per hr at approximately 43.5 PSI. This information is typical for all manufacturers and flow rates will vary slightly even between identicle injectors.
Good luck and hope this helps.
Feb 06, 2010 | 1989 Chevrolet Corvette
Twice in the last year, the floater of my toilet jammed causing the water to run all night long. After running for 12 hours the water kept running but turned brown and muddy. After a day or so, all returns...
the valve that controls water flow is sticking. replace the interior water stand pipe valve with a new one you got dirt in the valve and it is not clsoeing. It would be a good ideal to put a filter on the output side of the pump. Aslo the wll level is most likely low due to lack of rain causeing the brown water. If you need more help post and let me know. the Vlave assembly costs $15.00 for a good replacement. also check that the flush handle is notr cathcing on anything and the flapper valve does not have a hole or rust arounf the ring.
Sep 28, 2009 | Little Giant Pumps W8G-X Submersible Deep...
Wet elph
That kind of submersion is usually a lethal thing, plus turning it on while still wet could deliver a nice killing blow, just to make sure it's dead... you passed current through conductive water spread inside the electronics. Don't mean to discourage you, there's always a chance, and you could take it for a shop to give you the final verdict, but if you told them what it went through there's a chance that they won't even bother opening it up. Sorry, at least life aint boring? ;[
Jun 24, 2006 | Canon PowerShot SD400 / IXUS 50 Digital...
Flotec 1/2 Hp 3000 Gph Utility Submersible Pump Logo
127 people viewed this question
Top Flotec Garden Experts
Jay Finke
Jay Finke
cornfuzzle
Level 1 Expert
Craig Butler
Craig Butler
Are you a Flotec Garden Expert? Answer questions, earn points and help others
