A
Anonymous Posted on Jun 09, 2015
I am having trouble connecting the external fiery E200-02 to the bizhub. All the cables are connected and the software switch is set in the bizhub but I get an error saying controller unconnected?
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Mar 11, 2017
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1913915
Points
11960
5 Related Answers
Anonymous
  • Posted on Mar 09, 2009
SOURCE: Socket Connect Error on BizHub C550
Select HTML on the Pagescope login page.
Anonymous
  • Posted on Sep 09, 2009
SOURCE: reload of software on Fiery 405 canon
i have canon ir 405 copier. i want to reload fiery software because my machine is not giving priting & is erroe E677 pl tell me about.
57 varieties
Karl Wright
  • 1653 Answers
  • Posted on Sep 14, 2009
SOURCE: xerox docucolor 3535 error 016-387
I've seen plenty of these issues with Fiery's connected to all manner of printers.
Actually, 016 errors are network related issues. The 387 usually indicate an issue with tthe switch device that the fiery is connected to and not the fiery itself. Get the connection from the fiery to the switch checked out and also the port status on the switch itself. Also recycle the Xerox and Fiery and you may also have to recycle the network switch as well.
Anonymous
  • 61 Answers
  • Posted on Oct 24, 2009
SOURCE: clc1150 cannot connect to fiery
Your Fiery need"s system software reloaded. let me know if you need help to do so.
Philip Hughes
  • 80 Answers
  • Posted on Jan 30, 2011
SOURCE: I have a docucolor 12
You should have a color separation guide with small gray scale from Kodak. You put the gray scale and the calibration sheet on the glass and follow the instructions from the fiery display.
3answers
Errore Trouble code C-C172
Refer to Konica Minolta Bizhub C451 Printer/Scanner/Finisher's User Manual or Call Service Center.
How to find server name for bizhub c352
The fiery network info can be found by pressing the small "i" in the bottom corner of your screen and selecting the config option. You can also access fiery settings by pressing "utility/counter" followed by "controller detail".
I have got a Xerox Docucolor 12 printer, a Fiery X12, and a laptop running on Vista. I dont have any cables except the power cables and was looking for a list of everything I'd need to get it running...
There are 2 cables that go between the fiery and the printer, not sure where you can get these.
You will need to be running windows xp
connect to the fiery with an ethernet line
download the drivers, command workstation, and fiery remote scan from the xerox website
hopefully the fiery still has its software loaded otherwise post a request for a copy here.
1helpful
2answers
Konica minolta bizhub c350 installer for mac
You have to have a fiery unit (external controler) to use the C350 With a Mac because the c350 dosnt come with appletalk in the software. IC-401 Is the model number of the controller you will need to connect the c350 to any kind of mac for printing / scanning.
3helpful
2answers
Xerox docucolor 3535 error 016-387
Ricoh 6513 Fiery E-710 Reinstall Setup
contact me [email protected] i have external drive with scsi terminator 2 different software programs one is fiery xj bp 100 color server and one is fiery xj r/r2 v3.1nds/tr system soft ware main program you need you may also contact me via telephone at 740 644 1793
Clc1150 cannot connect to fiery
6answers
1helpful
2answers
Can't Network Print
in printer you should log in as administrator and there should be network settings, where you can put in ip address and gatway and so on.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
