Question about Garden
WeedWacker Craftsman 32cc won't run. Did last year.
Unit has a Walbro carb WT628. I have replaced with new parts the: Carb; air and fuel filters; spark plug; fuel lines . i was able to get it started but it will not continue to run. It dies just like it ran out of gas. Only adj. on carb is ''idle'' which is no more than a detent for the throttle. Unit is only a year old, but then again'' it is a Sears, even if Poulan makes it or part or what ever. HELP
5 Suggested Answers
  • 101 Answers
SOURCE: 32cc Craftsman weedwacker dies at idle
could be blocked muffler
Posted on Aug 14, 2010
  • 150 Answers
SOURCE: poulan 32cc multi-attatchment weedwacker will
Try backing out high speed screw counter clock wise a guarter turn. Also check muffler for blockage. Spark arrester screen may be blocked. Remove screen, clean or replace. I use bernzomatic tourch to burn off deposits.
Posted on Oct 03, 2010
digritz
  • 530 Answers
SOURCE: craftsman 32cc would not idle
If you are certain that you have correcting gaped the plug then the next step is to readjust the low end idle carburetor. If you look you should see two holes in the plastic cover that lead to the flow adjustment screws they may even be out in the open. If they are not labeled H and L (the L is the one you want), check your manual for the correct one. A good place to start is turning the screw all the way in then backing it out 1 1\2 turns. Then check it. If you still have problems do 1\4 turns out. After about one full turn from that you might want to consider taking the carburetor off and removing the float bowl or the bottom for a good cleaning. A sticking float could cause problems with your fuel flow.
Hope this helps.
Posted on Sep 03, 2009
  • 316 Answers
SOURCE: I have a Craftsman's Gasoline Weedwacker model 358.791580. The weedwacker wouldn't start after priming and choking. I observed the fuel filter inside the gas tank unattached because the fuel l
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, oo
Posted on Feb 21, 2012
I just rebuilt the carb on my craftsman 32cc weedwacker primed some gas and it flows through just fine but gas doesn't seem to get into the carb. I can add some gas directly into the carb and it runs...
Dean Hi there, is it possible that you have got a blockage in the fuel line or maybe just put one of the gaskets back wrong. It needs everything airtight to suck the fuel through.
Sep 02, 2013 | Garden
Craftsman 25 cc Weedwacker
Look for air leaks in the gas line and around the carb , a bad gas cap will not let any pressure build up. It could be that too. Check also the fuel line and filter inside the tank. replace if needed.
www.ereplacementparts.com has parts for craftsman or the online Sears Stores.
Nov 01, 2017 | Craftsman Garden
I need the fuel line routing diagram for a Craftsman Model No. 358.791510 Weedwacker 32cc/1.9 cu.in. 2-cycle
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, ``
Jan 18, 2012 | Garden
My 32cc 4 cycle craftsman weedwacker won't run off choke
MORE THAN LIKELY YOU HAVE BEEN USEING ETHANOL FUEL NEED A METANOLE FUELCLEANER AT MOST AUTO PARTS SUPLYER THEY SELL A FUEL CLEANER FOR SMALL ENG. IF NOT THAT MAKE SURE FUEL LINE IS NOT CRACKED
Nov 15, 2011 | Garden
My 25cc craftsman weedwacker will not start it is not getting fuel prim bulb will not fill up lines are full of fuel when i pull them off new lines took csrb off and blue out with air. if i put fuel min...
Clean you needle/ seat inside carb pull apart and clean all out and try it off the w.w. to see if primer works ,also the primer has a check valve internally also make sure that is working, if the primer won;t pull gas through carb it won;t run 2StrokeJim
May 17, 2011 | Craftsman 25cc Gas Line Trimmer
Weedwacker won't start
Is there an air lock in the line. Remove the lines and insert only one at a time and see if one will take fuel and the other none? Also, check carb float to make sure its not stuck open intaking fuel constantly flooding bowl
May 31, 2010 | Craftsman 25cc Gas Line Trimmer
Have craftsman 32cc gas line trimmer it runs until given gas
Replace the spark plug, clean the air filter and fill the tank with new fuel at the correct fuel oil ratio. Had the same problem last year. Tried to cheat with year old gas.
May 04, 2009 | Craftsman Garden
Craftsman weedwacker keeps dying
If the weedwacker runs OK on 1/2 choke or even better on full choke then most likely the cause is the carb gaskets are stiff and can no longer pump the fuel. Of course make sure the fuel lines are are the right ports (return and supply). While you have the carb apart clean all of the passages with carb cleaner.
Apr 16, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
484 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
