Question about Cameras
The front cover of the lens comes off. - Cameras
  • mikeforte Jul 11, 2009
    The front lens of the camera got stuck while taking a picture. In addition the front lens rim cover came off. The camera is a Canon Power Shot SD1100 IS, Digital ELPH.
  • 3,037 Answers
Hi mikeforte
Could you please be a little more specific on the problem and let me know the make and model of the camera in question in order to be more help. Thanks
Benjamin
Posted on Jul 11, 2009
  • Benjamin Patri
    Benjamin Patri Jul 11, 2009
    Ok, these cameras have a history of both of the problems you are describing. I usually recommend Kodak cameras over Canon. Anyway, first the lens stuck problem usually can be fixed by cycling the camera off and on about 15 times as a part is usually out of alignment. If that doesn't work then try gently pushing it back in. If you still can't get it, then the camera should be opened up and the problem found in the assembly. The rim cover can be glued on, very cheap design. Again Kodak cameras which are similar in looks and use experience very few problems compared to these and I recommend one on your next purchase which if you are fed up with this one might be right now as I would not stick any money into fixing this one if you can't get it to work with the above information.
    Benjamin
Why won't the shutter on my Nikon coolpix won't open?
hi do you mean the shutter? or the lens cover in front of the lens? if you mean the two leaves that separate when the lens comes out it is probably a lens issue or a spring not working correctly in the front cap.
Jul 15, 2014 | Nikon Inc Nikon Coolpix S9400 Black
Lens mount is shaky
remove front cover (four screws, one front, two sides, and one bottom), plus loosen two screws holding door latch plate and lift plate up slightly so front cover will lift free (plate has tabs that fit in slots in front cover. Do not lift up too high, just enough to slide cover free). Tighten four metal mount screws and re-attach front cover
Mar 30, 2013 | Canon T70 35mm SLR Camera
Regrding Olympus Stylus 500.. When turned on the lens cover opens half way twice then closes with a green flashing light and beeping sound.
Have just solved similar problem with mine. Problem turned out to be that the lens cover was very slightly dented in. It didn't really look dented at all, but just wasn't quite symmetrical and was a bit more recessed on the side away from the shutter button. This was causing it to rub on the case when it tried to slide. (Mine had been not sliding completely shut for a while before it stopped opening properly too).
To fix it I undid two small cross head screws which let the front panel be prised off. On mine, with the front panel off, the lens and lens cover mechanism all worked perfectly, as the problem was that the lens cover was rubbing on the front panel. If yours is still broken with the front panel removed, then your problem is not the same as mine...
I used a small screwdriver to push out the metal bar on which the top of the lens cover slides, pushing on the right hand end of the bar to slide it left and out through the USB connector compartment door. That lets the top of the cover come off the bar and move freely. To take the cover off, it has to be detached from the arm which moves it. There is a pivot trapped in a slot in the arm, but once the cover is off the bar at the top, it can be moved down so that the pivot reaches the bigger hole at the bottom end of the slot in the arm. This lets the whole lens cover come off the camera.
I then used a screwdriver to gently push out the middle of the cover until its shape was more symmetrical. (I'm not sure a screwdriver was ideal for this, as there are now tiny lumps in the cover where I was pushing it).
Putting it back together was the reverse of taking it apart, although you can test whether it's fixed or not before doing up the screws holding the front panel on.
Apr 28, 2010 | Olympus ? Stylus 500 Digital Camera
When i turn it on it says turn off and on again
I have just had exactly the same thing on my daughter's NV3. In this case the lens cover would not open but if you power on the camera with you finger on the display button you can view stored images. If the lens cover is jammed you need to open the casing and maybe take the lens cover assembly apart. You need a very small cross head screwdriver (No.00 should be OK). There are 5 screws in total, 4 screws on the outside of the case (3 plus1 under the headphone socket cap) and 1 inside the battery compartment. You need to remove all 5 to remove the camera front casing. There are some retaining springs top and bottom on the front cover, gently prize off to reveal the lens cover assembly. Check to see if the lens cover will operate by switching on and off - if it works then the camera front casing is preventing it from opening and is probably bent out of shape. A little careful bending back into shape should resolve the problem. If it still does not work with the casing removed, read on. This is the tricky part. There are two extremely small, black retaining screws to the left hand side which hold the assembly onto the lens cover motor. Remove these screws and the front of the lens cover assembly to reveal the lens cover and the back plate of the assembly. Lift off the lens cover and switch on the camera. If the motor is still working, you will see a short black peg move from side to side as you turn the camera on and off. Thoroughly clean the lens cover and assembly, remove any obstruction and replace the lens cover making sure you locate the hole in the lens cover over the motor peg (described above).
The motor is magnetic and will attract the screws away from their holes if you replace the assembly front straight away, so when you replace the front of the lens cover assembly, place the screws in the correct holes before lowering it into place and then screw onto the motor/assembly back. Test that the lens cover opens and closes and replace the Camera front cover taking care not to bend it too much - if this becomes distorted it can stop the lens cover from operating resulting in the same problem.
Apr 01, 2010 | Samsung NV3 Digital Camera
Olympus Stylus 600/Digital 600 6.0 megapixel
Hi
This camera can be very picky when it comes to the front lens cover... It's not a simple mechanism and has many small parts and gears involved. If the lens cover is dislodged it won't work smoothly, and if the case is dented it will not be able to move properly and this can cause lens problems.
If the lens was out when the camera was dropped, then it's possible the lens was damaged and not the lens cover. Sometimes you can tear down the lens, clean it and rebuild it and it will work smoothly again, sometimes this doesn't work and the lens needs to be replaced.
If you're comfortable opening the camera, first check out the lens with the front body section removed so nothing is blocking the lens cover. Does it work properly now? If not, then expect lens damage to be the issue.
We are an AFFORDABLE digital camera repair shop... if we can assist you with parts or do the repair please let us know. (google: darntoothysam)
Hopefully this is of some help. Even if you don't use our services please feel free to let me know if you need more assistance.
Good luck from Darntoothysam com
Thomas
Oct 10, 2008 | Olympus Stylus 700 / 700 Digital Camera
Lens do not come out
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Aug 26, 2008 | Canon PowerShot S70 Digital Camera
SONY HANDYCAM DCR-40
Lens cover error message comes when its not opend. There is a switch inside Front Cover (where lens and mic mounted) got bad contact. Open that Front cover and unscrew the circuit board, put 1 drop of W-40 cleaner oil and fix back all things.
Apr 27, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Cover over lens doesn't open properly.
This is a common fault and is caused by dirt/dust/sand particles interfering with closing/opening of the lens cover ( btw before you do anything else try blowing out with compressed air ). Solution :
1) repair yourself route ( if brave and skilled enough) : remove screws and fron cover compltely. Unsolder six thin wires on the left hand side of the circuit board. When front cover is removed blow out sand /dust from the lens cover which is now quite accessible.
2) send to repair outfit route . Note that this is not an expansive repair which does not require installation of spares. So perhaps you should send it in.
Jan 14, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Lens front cover
visit camera store bring your camera lense show what cover , for temporary cover a soft cloth keep .put absorbent shashy.
Dec 24, 2007 | Minolta 35-80mm f/4-5.6 II Lens
Cameras Logo
24 people viewed this question
Top Cameras Experts
Damen Wong
Damen Wong
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
