Question about Nokia 6270 Cellular Phone
I cannot set time and date of my nokia 6270. *#7370# doesnt work
My nokia 6270 is showing time 12:00 am . Time is stopped and it is unchangeable. I cannt format it by using *#7370# code or any other code. I updated its firmware version but nothing happened. Please tell solution.
You go to nokia care centre and update your mobile software in 200 rupees.your time work properly
Posted on Sep 03, 2009
  • 79 Answers
Try removing battery for 1 day and then put it back, I think that there is some problem with timer and phone has capacitor inside, so you need to wait until it discharge to reset clock
Posted on Jul 11, 2009
How do i change the time on T5K801 Marathon watch
To set time and date:
1) With time and date showing,
press SET and hold for 2 seconds.
2) Seconds flash. Press START/STOP to set seconds
to zero.
3) Press MODE
Hour flashes.
Press START/STOP
to change hour, including AM (no symbol) and PM.
4) Press MODE
Minutes flash.
Press START/STOP to change
minutes; hold button to scan values.
5) Press MODE. Year flashes.
Press START/STOP to change year.
6) Press MODE
Month flashes.
Press START/STOP
to change month.
7) Press MODE
Date flashes.
Press START/STOP
to change date.
8) Press SET
, at any step, to exit and save settings.
With time and date showing, press SET
to switch between 12- or 24- hour time format.
Date (day of month) appears in upper part of display in Time
mode. Press and hold START/STOP
to see month, date, and year in large digits
Or go to:
http://assets.timex.com/user_guides/Marathon/W292-Marathon-AllLanguages.pdf
Jul 31, 2017 | The Watches
Need to set just the time on a timex WR100M mens watch
SETTING
  1. First, find the regular time mode by pressing the MODE button until the time (with the date at the top) shows.
  2. Press & hold the SET button until the word ENTER disappears and is replaced by the word TIME. Release that button. You'll notice that at the top of the display, the words SET T1 or SET - T2. This is where you select between setting the 1st time zone or the 2nd time zone. Select between T1 or T2 by pressing the RECALL button or the STOP/RESET button.
  3. Press either the MODE or the START/SPLIT button. You'll notice that whatever is blinking is what you can change. You can make the changes by pressing either the RECALL or the STOP/RESET button. You can change the Seconds, the Hours, the Minutes, the Month, the Date, the Year, and choose between 12 hour (civilian) or 24 hour (military) time. If you keep MODE or START/SPLIT button, you will go through all the things you can change and start again at the beginning. The START/SPLIT button goes through these things forward, and the MODE goes through the backwards, so if you pass something and want to back up, just switch buttons. In the same way, the RECALL changes things by making them larger, and STOP/RESET changes them by making them smaller, so if you accidentally pass the number you're trying to set it to, just switch to the other button and go back.
EXAMPLE OF SETTING THE WATCH Suppose you want to set the hours and the date in the 2nd Time Zone. (Just as an example, but setting any other time or date settings would be the same.)
  1. Press the lower left button on the side (MODE) until you see the date & time.
  2. Press & hold the lower right button on the side (SET) until the word TIME appears on the display, then release it.
  3. If SET T1 is showing, then press & release the upper right button on the side (RECALL) to change it to T2 (because we're wanting to set the 2nd Time Zone we'd leave this unchanged if we wanted to set the 1st time zone, T1.)
  4. Press & release the lower right button on the face (START/SPLIT) twice, skipping the seconds. You should see the hours flashing.
  5. Press & release the upper right button on the side (RECALL) repeatedly until you have the hours position set to what you want it to be. If you pass the hour you want, go to the lower left button on the face (STOP/RESET) and press & release it to back up.
  6. Press & release the lower right button on the face (START/SPLIT) three times, skipping minutes and months, so that the date begins flashing. Press the RECALL button until you have the date you want. (You can go backwards by pressing the STOP/RESET.)
  7. When you're done, and you've set everything you want to, press & release the SET button once to tell the watch you're through setting and to lock those settings in.
Nov 23, 2015 | Timex Ironman Watches
How to hide time on to display on nokia 2690
Hello there,
To hide the times display on the nokia 2690, simply go to the menu, select the settings, then you scroll to date and time, in date and time scroll to date and time format settings, in the date and time format settings select time, when you open the page you will see clock and 12-hours or 24 hours depending on what time format you are using, select clock, you will see show time and hide time, select hide time.
All the best Elect_Comp
Sep 15, 2011 | Nokia 2690 Cell Phone
The size of the clock on screen in nokia 2700 classic is too big. Is there any way to make it small or keep the clock in the upper right corner as in other nokia mobiles.
1-enter in menu 2-enter in settings 3-date and time 4-date and time format 5-to hide/show date enter in "date" or to show/hide clock enter in "clock" and select show/hide :-)
Aug 12, 2011 | Nokia Classic 2700 Cell Phone
I have nokia 5130xpressmusic but it has problem it doesnt shows full serial no. N restarts in every 2 min.
If serial number doesnt shoe completely it might probably due to corrupted files or virus on the phone, It happens to me before and i suggest to reset your phone to factory setting so in that way it will go back to its original setting, However pls take note that files and save information will be deleted by doing this.
Please see below instruction for getting serial number and How to reset your phone:
To enter in the secret menu in Nokia Phone.
On the main screen type *#92702689# [*#war0anty#]
It will take you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
To restore Factory Settings for Nokia mobile
*#7780# reset to factory settings.
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
Jun 02, 2011 | Nokia Lands Phones
How delete time display from screen for nokia 2690
Settings-->Date n time-->Date n time format settings-->Time-->Clock--> (show clock/hide clock) !!
Mar 26, 2011 | Nokia 2690 Cell Phone
How do i change the time?
Hello, here is the instructions for setting the clock
RDS Clock Time Broadcasters can choose to send clock time information in the RDS data. This information can be used to update the clock time on the radio. RDS clock time is broadcasted once a minute. To set the clock using RDS clock data perform the following:
• Press and hold the HR and MIN buttons together for two or more seconds to update the time.
• The display will show "UPDATED" after receiving the broadcasted time data. • If the broadcaster is not broadcasting the time data, the radio will display "NO UPDATE" and the time remains unchanged.
if this doesnt work, just simply push and hold the hr and minute buttons to set the time
• Press and hold the HR and MIN buttons together for two or more seconds to update the time. • The display will show "UPDATED" after receiving the broadcasted time data. • If the broadcaster is not broadcasting the time data, the radio will display "NO UPDATE" and the time remains unchanged.
Oct 23, 2010 | 2002 Chevrolet Impala
Time doesnt get set automatically
sir, there is no solution for this prolem.you will have to set it manually only. if you dont the default settings will be set.
May 27, 2009 | Nokia 6233 Cellular Phone
Message received shows 5 hours ahead of the original time
You have to set ur mobile's time. For doing this u go to
Settings > time settings > Set time and dat > set time
make sure u set it in 24 hour format
hope this helps, please leave me good ratings :)
Mar 25, 2009 | Nokia 2366i Cellular Phone
Nokia 6270 Cellular Phone Logo
320 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
Damen Wong
Damen Wong
