Question about Dell V7 (U1868 ) ( u1868 ) Tape Drive
The driver is not found
My sonic was working fine until recently. I have windows XP. I noticed when I closed the program I had 3 consecutive error messages. They all started with "The instruction at 0x0037ae60....for the first and other numbers for the second and third. It said "Memory could not be written" and the other 2 said it can not be read. I try to burn a cd and it says no driver found. Sonic is not recognizing my Cd drive.... if you have any suggestions, please respond, Thanks
    Problem Solver:
  • 15 Answers
Have you recently run any Windows updates?
I would try uninstalling and re-installing the drivers for the cd rom and/or Sonic first. If that doesn't resolve the issue, you could attempt a system restore to a date when the program was working.
Posted on Jul 11, 2009
I have XP. Recently I tried to install a new printer (Kodak). A window kept popping up stating it was not compatable with the windows program. I called Kodak for help and was told the computer I had (which...
You might have installed the drivers recently with the "found new hard" wizard without selecting "No, Not this time".
Once the "found new hardware" wizard pops up, don't close it or cancel it, rather leave it and directly go to your device manager, expand all the snap-ins and locate any device link with yellow highlighted question (?) mark. Make sure in which device's category it is listed, and install the driver from the "found new hardware" wizard by selecting "No Not this time only" before you proceed to the next step.
If you have problem, let me know.
Good luck.
Thanks for using FixYa.
Jul 27, 2010 | Microsoft Computers & Internet
Hi there, I recently had to reinstall Windows XP and of course then reinstall the Airplus DWL-G510 drivers. I accidentally did this whilst the card was still installed in the PC (Which it tells you not to...
If you are not OK with editing the XP registry, then I would enlist a computer savy friend to help you. If you make a mistake the computer will be inoperative and needs Windows XP re-installed again.
The other way is to re-install Windows XP from scratch but make sure the Airplus is card removed first.
To fix your problem using Regedit follow these steps :-
1. Remove the program using Add/Remove Program.
2. Delete the Airplus folder from the Program Files folder.
3. Click on Start - Run and type Regedit (registery editor)
4. Click on Edit then Find and type Airplus
5. Click Find Next
6. When Regedit finds a Airplus entry then delete this entry and press the F3 key to find the next Airplus entry - delete and repeat until all Airplus entries have been removed.
7. Close Regedit and reboot the laptop.
8. Install the Airplus driver etc.
If this doesn't work then re-install Windows XP from scratch, it might be quicker to solve this problem in the long run.
Have fun.
Let me know how things go.
Nov 15, 2009 | Computers & Internet
Diamge Scan II, Error = 5 Windows 2000, Error = 1 on Windows XP
Before you install try this.
1. Start -> Click Run
2. Enter msconfig and click ok
3. Click Startup tab
4. Uncheck program that you don't want to startup
You can disable programs that you don't want automatically load when you start your computer. By disabling these programs will help your computer startup faster.
5. Click Ok and restart
Now you should notice that your computer startup faster.
My Hot Tips to Make Your Computer Faster:
* Regularly check your startup folder to prevent malicious programs installed itself without your knowledge.
* Delete the temporary files from Temp folder (Start > Run > %temp% > delete all files).
* Upgrade your RAM to makes your computer boot faster : )
I hope this helps you to make your computer faster..
Sep 14, 2009 | Minolta Dimage Scan Dual II Film Scanner
CAN'T INSTALL WINDOWS SERVICE PACK 3 (KB936929) and SONIC UPDATE MANAGER
All you need to do is open sonic update and disable sonic update manager from running automatically.Then reinstall the updates.
May 16, 2009 | Dell Precision 380 P4 Dual Core 3 GHz...
Job Status Window Interface has stopped working.
The issue usually occurs if you are using windows xp drivers on a vista machine. It's strange that the error does not come up when printing from internet explorer 7.0.
There is a file on support.dell.com that you can run to remove any xp drivers and then run the vista installation file. that should take care of these error messages from the operating system.
you can copy and paste the following links to download and run the files :
Patch file to remove xp drivers:
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=224499
Driver for vista
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=203951
Feb 17, 2009 | Dell A960 All-In-One InkJet Printer
Programs closing
you probably have some kind of infection - reinstall windows from the cd (unpartition, repartition, and quick ntfs format the drive at the start of the install.
Sep 03, 2008 | Toshiba Satellite A100-S8111TD Notebook
Radeon X800 XL AGP Card Installation Error
You should do a deep uninstall of all of the ati drivers present in your system... here are the instructions.
The "deep uninstall" starts by first uninstalling all ati drivers and programs present in the affected computer computer, remember to remove al ati related programs from control panel's add remove utility, including the whole multimedia center. And finally reinstalling the new drivers.
You should have downloaded the most recent catalyst drivers from ati.
Now proceed with the "deep uninstall" following this directions, taken from somewhere on the internet, thanks to the one who wrote them...
1. Go into the Control Panel and under the ADD/REMOVE SOFTWARE icon uninstall the ATI Multimedia software and/or the ATI DVD software.
2. Uninstall the ATI drivers also found in the Add/Remove section. Once removed, it will prompt you to reboot....do so.
3. When returning to windows, the NEW HARDWARE FOUND wizard will come up and will tell you that it has found a new VGA card and will prompt you for drivers. Hit CANCEL!
4. Now, go to START - SEARCH - FOR FILES OR FOLDERS and do a search for all files and folders using the filename ati*.*
This search will normally give you 3 to 4 files found in your c:/windows directory and subdirectories (including the Windows/System directory). Select these files and erase them. Now go to your Recycle Bin and Empty your bin.
5. Next...time to go to your Registry. Go to START -- RUN -- regedit
Here go to key HKEY_LOCAL_MACHINE -- SYSTEM -- ControlSet001 -- Control -- Video . Here there should be 4 entries. 3 of them are default Windows XP entries and the 4th one is put in by the ATI drivers. Expand each one by one until you see ATI entries. Once found, erase the entire key.
Now repeat the same step above for the ControlSet002 key and the CurrentControlSet Key. Normally, whenever you erase a key in the ControlSet001, XP automatically deletes it in the CurrentControlSet section too. So if the ATI key is not found in the CurrentControlSet section, don't worry about it.
Once all keys are deleted, proceed to the next step.
6. While still in the registry, go to the key HKEY_LOCAL_MACHINE -- SOFTWARE section. Here you should find an ATI Technologies key. Select it and delete it. In that same section, look for an Installed Options key. Expand it and there you should find another ATI Technologies key. Select it and erase it.
7. Still in the registry, go to HKEY_CURRENT_USER -- Software and there you should find another ATI technologies key. Select it and erase it. Once all this is done, close the registry. the registry is now clean. Though you might want to even run a registry cleaner, like the one included in the freeware program CCLEANER, it's very good, can be undone and it's safe enough to use it almost blindly.
8. Close all windows and reboot.
9. When in windows after the reboot the NEW HARDWARE FOUND WIZARD will pop up again. Cancel that. Now find the new ATI drivers that you have downloaded and extracted and run the SETUP file. Once complete, reboot and you are DONE!
Jul 08, 2008 | ATI Sapphire RADEON X800XL RADEON X800 XL...
Continue to have windows not load after recovery, error
try getting a full copy of xp then use another application
like nero
if you need more advice on this get back to me
Mar 24, 2008 | Computers & Internet
File format error - Transcend T.sonic 610(1gb)
I had the same problem. I had formatted the player's drive using Windows explorer and the got this error: "File Format error" while trying to play any mp3 file.
I went to the command prompt. Deleted all files:
E:\> del *
Then I copied the MP3 files again in the T.sonic MP3 player. All MP3 files played fine after this.
Jan 29, 2008 | Transcend T.sonic 612 MP3 Player
Computers & Internet Logo
428 people viewed this question
Clive
Clive
Alun Cox
