Question about Kenmore Microwave Ovens
Replase fuse then when shut door blows fuse again whirlpool GH7145XF
  • Kenmore Master
  • 9,149 Answers
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Jul 13, 2009
How old is my Whirlpool Microwave Oven GH7145XF?
The date on these is on the sticker. open door and look at the bottom left.. most were made in 2002
May 23, 2011 | Whirlpool GH7145XF Microwave Oven
I have a Whirlpool GMC305PDS07 Oven Microwave combo. The microwave display shows "Door" and it won't start. The door looks fine and closes properly. Is there anything I can check or do before...
Sorry to read about your problem, I hope this helps you out.
sound like you have a defective door closed switch
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 20, 2010 | Whirlpool GH7145XF Microwave Oven
We burned perforated plastic inside window of door.
Explain this to me in more detail, write me at home wbwill@sbcglobal.net, this could be dangerous, I don't know what you mean you by burning anything, but if you burn't something, why, and will that happen again, and what is this perforated vinyl?
Is it the enclosure of the oven, see through the glass?
Explain this to me, soon as you can.
Will
Dec 16, 2008 | Whirlpool GH7145XF Microwave Oven
Gh7145xf has lost all power.
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 28, 2008 | Whirlpool GH7145XF Microwave Oven
Whirlpool gh7145xf makes loud noise and there is no heat
If the noice is a loud electrical noise then it is your magnetron
Mar 01, 2008 | Whirlpool GH7145XF Microwave Oven
Whirlpool Miccrowave (GH7145XFQ-1) went dead...
Does the display light up?
Are you sure it is getting power?
Check that and get back to us cause the next step is going inside
Jan 01, 2008 | Whirlpool GH7145XF Microwave Oven
Whirpool Microwave GH7145XF
So is it dead? (No life, no beeps, no lights?)
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open.
When it cools, it closes the circuit and allows power through again.
If it's random, it may be a bad connection, usually on the control board or fuse holder.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
See our listing here on FixYa: http://tinyurl.com/yzjozk
Let us know if you need more help.
We appreciate your thoughtful rating of our answer.
Nov 09, 2007 | Whirlpool GH7145XF Microwave Oven
Whirlpool GH7145XF
Check your main breaker fuse in your panel/subpanel.
Otherwise if the inline fuse is good and the main power is good, then look at the power supply for the microwave.
Mike
Microwave builtin
This is almost certainly a bad upper door switch or a broken switch mount. You can find exploded views for this model at http://tinyurl.com/gv383 The involved parts are on exploded view 5 with reference numbers 10, 11, 12 & 13. We have important safety info, disassembly info, and door switch diagnosis and replacement info at our site which is available via our FixYa listing: http://tinyurl.com/yzjozk
Jan 30, 2007 | Whirlpool GH7145XF Microwave Oven
Microwave Ovens Logo
43 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
