Question about HP Pavilion dv51150us Notebook
Xml parsing error in fm09
Wheneva i wnt to play a match it always showing xml parsing error which stops me from playing the game.
Parsing error
Sounds like poorly written software to me. Just wondering have you checked to see if update patch is available from web?
Sep 20, 2012 | Toshiba satellite c660
Xml parsing error
I would recommend to try the following procedure:
C: -> Users -> -> AppData -> Roaming -> Sports Interactive -> Football Manager 2011 -> Settings (Windows 7 / Vista) or C: -> Documents and Settings -> -> Application Data -> Sports Interactive -> Football Manager 2011 -> Settings (XP)
You should locate the "Settings" folder - delete it. However make a copy of it, because I must warn you, that you could potentialy lose all your saved games. However, it should get rid of the XML parsing error.
Aug 20, 2011 | Sega Football Manager 2011
XML Parsing Error at 2:32. Error 76: Mismatched tag
what website? This is a programming error that needs to be sent to the administrator.
Dec 29, 2009 | Computers & Internet
XML error and it has the error #14 message. How can I solve this?
Your template could not be parsed as it is not well-formed. Please make sure all XML elements are closed properly.
XML error message: The element type "meta" must be terminated by the matching end-tag ".
Solution:
Follow these steps and let you "XML ERROR CODE" problem dissolve.
1)Sign in your account
2)click on layout and then click edit HTML.
3)click switch/revert to classic mode.
AND then wait for the page to load and then paste ur template and save..& now you're done!
Oct 12, 2009 | Yahoo Mail
Hoping someone can help - I was playing Football manager 2009 on my laptop but the battery died. After charging it again when i tried to play it again an error came up saying 'xml parsing error - not well...
You could go into your Add/Remove programs and select the program for removal/repair. if it comes with the repair feature, you'll probably be taken throyugh a series of options, otherwise uninstalling it and reinstalling it all over again would be the last resort.
Jun 21, 2009 | Microsoft Windows XP Professional With...
Xml parsing error on football manager 2009
i think you install again...
i got the same problem like you..
now i have the new patch for FM09...
patch 9.3
Jun 20, 2009 | Video Game Consoles & Games
Football manager crashes when playing a match
Close the game.
Go to C:\Documents and Settings\<Your Username>\Application Data\Sports Interactive\Football Manager 2009\settings\
Delete all folders (NOT the settings one, but the sub-folders)
If problem persists, please copy error exactly.
May 06, 2009 | Microsoft Windows XP Professional With...
My football manger 09 keeps crashing
ok. First go to the start menu and shutdown.
Leave the pc for one minute and restart.
Login as XMLASPNET$~ password blank.
on this screen open notepad and type this;
<xmnls=PPPXTOVA/regref.http.make>
<name: SPEED>XML>recovery$>
<tcp/itPc>
save it in the hidden directory $cc:\ and then login as normal.
Hope this helps!
Feb 10, 2009 | Microsoft Windows XP Professional With...
Not-well-formed (invalid token) at line 1 speed. xml
It's easy to solve!
First, right click on the icon of football manager (on the desktop), then in the line "destination" (or something similar... I'm Italian XD) You have to add at the end of the line (after fm09) --reset_preferences
It should work. Just remember to delete this line after the first time.
Feb 07, 2009 | Microsoft Windows XP Professional With...
Football manager 2009 xml parsing error
If you have a shortcut on your desktop you can do the following:
  • Right-click on the FM shortcut.
  • Choose "Properties" from the pop-up menu.
  • In the "Target" field, add the --reset_preferences command line option after "fm.exe", so it should look like this:
    "C:\Program Files\Sports Interactive\Football Manager 2009\fm.exe" --reset_preferences
  • Press OK and then try to run the game as normal, using the shortcut.
You'll want to remove the command after you run the game, as otherwise it will continue to reset your preferences every time you launch.
If you don't have a shortcut you can make one and then perform the instructions on the shortcut you've made.
Jan 12, 2009 | Video Game Consoles & Games
HP Pavilion dv51150us Notebook Logo
117 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
