Question about Toshiba Televison & Video
Toshiba 65UL610U Wont stay on
Hit power key, indicator light functions properly, after a few moments, shuts itself down.
  • Brent Craig
    Brent Craig Jun 09, 2015
    Not a remote problem, just posted in wrong category. When the TV is turned on, it goes throttheits normal cycle like its going to come on. Right before the picture would appear, it restarts itself and goes through the cycle again. I was wondering if there was a certain board/component that is normally the culprit in situations like this. All help appreciated
  • Toshiba Master
  • 5,631 Answers
Is the problem with the remote or your TV? Does it stays on if yiou turn your TV on manuall?
If so, you may have a contact problem with the remote and should take it to a repair service to get it cleaned
Posted on Jun 08, 2015
  • Brent Craig
    Brent Craig Jun 08, 2015
    Its not the remote, I posted it under "remotes" by mistake. I turn the unit it on and it starts going through its normal mode, (indicator light blinking, humming, etc), then it clicks itself back off. When this issue first arose, the picture would actually come on for a few seconds, then it would restart itself. Now, the indicator light blinks, but no picture ever appears. I've been digging through forums trying to determine where this issue stems from and what board/component could be swapped out to correct it. From what I've read,this is a pretty common issue. Thanks for your time.
SOURCE:
Toshiba Satellite not Booting (No post Screen)
you can't boot on safe mode under F8 function key?
Mar 30, 2014 | Computers & Internet
Dish Network Remote Codes? Can't seem to get the few I have to work the dish remote
If your remote is a learning remote (has a little black glossy square on the top left side of the remote) you don't need a code, you just need the original remote. Place both remotes on a table, or other flat, sturdy surface, with the original TV remote facing the square on the DISH remote. Make sure both remotes have functioning batteries. On the DISH remote, hold down TV until the button blinks three times, then hold down record (for 5+ seconds) until the TV button lights up and stays on. Then, slowly, for each key you want to use, hit the key on the DISH remote (TV light blinks) then the corresponding key on the original remote (TV light blinks). For example: DISH Volume Up, TV remote Volume Up. When you are done learning all the keys you want to train, hit SAT. The TV light will blink three times, then the SAT light will light up for a moment. Try the DISH remote on your TV functions.
Nov 15, 2013 | Emerson LC320EM8 32 in. LCD TV
My motorola h700 wont pair to my htc hero.when i hold the button down on the bluetooth, it lights up blue for 5 seconds then the light goes out
go into settings, look for wireless controls or bluetooth, should ask you to pair with the name of your bluetooth if it wont, turn off the bluetooth in the phone and turn off the bluetooth itself by holding down the button for about 6 secs till the light blinks a few times then goes out. turn the bluetooth function on on the phone FIRST, wait till it says its on, then turn on the bluetooth itself by holding the button down until the light blinks a few times then you get a solid light, it wont stay solid, it will blink a few times then go out blinking from time to time. go back to your phone and find the bluetooth menu and it should ask you if you want to pair, hit yes or whatever option you have and it should start pairing and then connect or you may have to hit the connect option if you have one they dont all connect automatically sometimes so you have to go through all this when you charge the bluetooth or turn it off. good luck.
Dec 14, 2010 | Cell Phones
I need to know how to reset my printer, I 've cleaned the pads, but nothing... Thank you in advance...
Power down the Canon Pixma IP4300. Once it has shut down, leave it off for a few moments.
Hold down both the "Resume" button and the "Power Button." When the printer begins to restart, release the "Resume" button but continue pressing "Power."
Push in the "Resume" button twice, then let go of both the buttons. In a moment, a green light flashes a few times.
Press the "Resume" button four times once the green flashing has finished.
Push the "Power" button again until the printer shuts down. Wait a few seconds, then press the power button again to restart the device. The Canon Pixma IP4300 will now function properly. for more information http://www.fixyourownprinter.com/forums/printer/67824 hope this helps you.
Aug 18, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Toshiba Satellite P205-S6237 won't Boot up after full shutdown
i think there is some issues with the OS because i noticed you can't shut it down properly so maybe the files needed in order to shut down had been corrupted but one more theory, the bios settings make sure that everythings configured properly there by checking the power options on the bios setup(the blue screen)so try setting it to default and change the boot priority to HDD,CDROM,FLOPPY.
Jul 14, 2009 | Toshiba Satellite P205-S6237 Notebook
T6420 E-Machine won't/Reboot W/O F8 Key
No sync means no video signal to the monitor. The rest sounds like a corrupted OS. This could be from a number of reasons, including a virus. If you have NORTON or MacAfee, Your open to a lot of attacks. Get AVG free, and use Mozilla instead of IE.
The reason the fans come on full speed is the MB senses a high temp on the CPU, until the bios fan control takes over after POST. This is normal on most systems.
Aug 22, 2008 | E-Machines eMachines Desktop PC
Toshiba MW20FM1 DVD section quits
am toshiba authorized servicer-have same model in shop for same problem-dvd board is defective-new board is about 290 from toshiba america parts-tv is actually made by orion with toshiba name stuck on outside-orion is junk-cost more than new set to fix-junk it and buy a panasonic-so far they still make their oun stuff
Mar 11, 2008 | Toshiba MW20FM1 20 in. Combo
Covergence problem
your set has indications of several problems. red green and blue. indcate convegence issue. the fact that the picture is concave is a indication of totall loss of covergence power supply. the convegence menu missing idicate loss of some voltages from what know as the flyback.AND SHUTDOWN. indicate further problems. generally when convergence fails ..not always the set wont shut down. it could be a simple issue but further trobleshooting would have to occur to narrow it down.
Feb 02, 2008 | RCA HD52W56 52" Rear Projection HDTV
MSI laptop technical problem
Sounds like the laptop used up all the battery power and turned itself off. Its doing this possible because your AC Adapter is not functioning correctly. Most AC Adapters have an indicator light to show wether they are working or not. Does your have this and is it on? If the device is still under warranty, contact the manufacturer for a replacement. http://www.msicomputer.com/support/sup_NBService.asp If the device is no longer under warrany, then I would recommend getting a new AC adapter. Make sure you get the same model AC adapter that originally came with the laptop. This will ensure that you have the correct voltage and amperage.
Sep 24, 2006 | MSI M510C Notebook
Televison & Video Logo
166 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
