If your power outage wad caused by a surge your tv may have died. Check fusebox for tripped circuit breaker also check tv wall plug fuse in case that has blown. It might be that the tv internal fuse has blown, you should disconnect the tvv from the electricity supply if you intend opening the rear of the set to check this.
If they are all okay the set probably needs the services of a trained technician
Good Luck
SOURCE: my tv wont turn on
Look for power outlet and ensure there is power. Check TV on other power outlets. Ensure required voltage is there on the power outlet. Even then, if you notice that the TV does not work, it might be attended to by a skilled and qualifies service technician.
