My LG DV492H will not play DIVX files. Will play audio files vie the usb input but not video files. Believe it may be a setting but have tried various options with no luck. Please advise on what settings it should be to work. South Africa
I have he same problem, as well as my friend. If you insert a DVD video disk, start up the DVD player. It then starts to play the DVD. Stop it and insert the USB drive. Use title to browse to your movies. It then plays them. Tried this on 2 dv492h players and it works
Posted on Aug 11, 2009
GOOD TANX
Posted on Nov 30, 2013
My LG DP122 will play some AVI files from a USB device but not others.
figured this out, lg dp122 uses DivX Home Theater profile, so the technical specs of the video must match that.
Those specs can be found here: http://www.divx.com/files/DivX-Profiles_Tech-Specs.pdf
Jan 23, 2013 | LG DP122 DVD Player, Multi Format...
No audio after recording from sat. Reciever
Double-check your input cables from the receiver to the LG 389. Do you have the sat. receiver AV out connected to the front AV In on the LG DRT389? Make sure that you haven't mixed up the L and R audio connections on either side. (I've done something similar with RCA cables myself.) Next, try a different set of cables.
If that doesn't work, there may be a problem with the audio jacks on either your receiver or the 389. To check, plug the AV cables from the Sat. Receiver directly into the TV. If you have sound and video, then the input jacks on the recorder may be damaged.
Try using another input. (It looks like some models have the SCART input; you may need to set the input source in the menu under AV2 Decoder.)
The fact that you have audio output on USB and DVD's means that cables/connections between the LG289 and the TV are fine.
I hope this helps. Please add a comment with the details of which AV port you are using on the LG389 for additional assistance.
Aug 31, 2012 | LG DR389 MULTISYSTEM DVD RECORDER FOR...
Can't play USB MP4 on LG RH397D
The LG RH397D only supports MP3/WMA/JPEG/DivX image and audio files from a USB drive. There is no firmware update that changes the supported file types. You will need to convert the MP4 to a supported format. The manual for the RH397D is available from LG: http://www.lg.com/au/support-product/lg-RH397D# /
I wish that I had better news for you.
Aug 06, 2012 | LG RH397H DVD Recorder
HI My LG V181 DVD Player / VCR Combo will not play divx. What can I do? Can I upgrade the software? Mark
Divx compatibility with this player is limited as follows; available resolution size of Divx is under
720x576 pixel - file name Divx subtitle is avail by 56 characters - if number of the screen is over 30/sec the unit may not operate norm - playable Divx file avi,mpg. .mpeg - playable codec format
DIVX3.xx - DIVX4.xx - DIVX5xx -XDIV - MP43 - 31VX - if the video and audio structure of recorded
file is not interleaved, either video or audio is outputted.- if the fie is rec GMC the unit supports only
1 point of the record level - may be helpful!
Feb 06, 2011 | LG V181 DVD Player/VCR
Why is it that I canot get sound on all the vidios that I play back on my TV from my Screen Play I can only get sound on a few ?
Hi Mary,
Please check the format of the video that you are trying to play.
this Iomega ScreenPlay Plus HD Media Player is certified to play popular DivX video, and supports many of today's popular CODECs and file types, including H.264, WMV and MKV, as well as plenty of others. (For a comprehensive list of supported video, audio and photo files. Most probably the video that you are trying to play is .3GP or .FLV.
For this you need to convert the video files to supporting format like DivX®, DivX Plus™ HD (MKV), XviD, AVI(Xvid, AVC, MPEG1/2/4), ISO, VOB, MP4, MOV, MKV,H.264, WMV, RMVB and MPEG.
Thanks,
Satheesh
Jan 21, 2011 | Iomega ScreenPlay Plus HD Media Player 1TB...
Hi, how to enable subtitles for DivX movies from USB on LG 42LE5500? I connect USB, TV recognizes folder where DivX .avi file is but within same folder it does not "see" .srt subtitle. Also, in settings...
It seems that subtitle file must have exactly same name as movie file. For example: Movie file: Mission impossible.avi Subtitle file: Mission impossible.srt or Mission impossible.sub or Movie file: Mission_impossible.avi Subtitle file: Mission_impossible.srt
Aug 14, 2010 | LG 42LE5500 42 in. TV
Region code 2 on LG DV492H not playing DVD with same code
You could try to set you firmware to Region 0 (all countries) you can do this with the remote
Eject the disc tray, and while it's open hit 0 - 0 (two zeros) on the remote.
Then enter 0 for the region code (for all regions.)
Jan 11, 2010 | Televison & Video
No audio on AVI files
Hi :
I would download virtualdub (free), install a divx convertor (free to some level), and input your original file in virtualdub (file-open file), check the video tab from VDUB, click compression, select divx, and save the file as an .avi file on harddisk of yr computer. If finished, check this avi file with a media player (winamp or so), see if it plays correctly, then transfer the file to your Archos. This will work.
I believe, when you converted, a stray codec was used for audio)
Gerard
Nov 17, 2008 | Archos 605 WiFi Digital Media Player
Playing DIVX on an LG LH-RH3690 DVD recorder
You can not view from the USB, since the USB port on the DVD player is ver 1.1. The transfer speed is to slow to watch a movie. Alternatively you can copy your movie from your flashdrive to the harddrive and watch from there. You will see what I mean with slow speed when you copy the movie. It takes ages.
Sep 11, 2008 | Yahoo YDP305 DVD Player
How do I play MPEG recordings?
Using Windows Media Player You need Microsoft Windows Media Player Version 9 or higher and Sharp G.726 Audio Codec in order to play MPEG4 files from the Memory Stick on your PC. If you are not currently using Microsoft Windows Media Player Version 9 or higher. Important: The Sharp G.726 Audio Codec needed to play MPEG4 files is no longer signed by Microsoft. If Sharp G.726 Audio Codec is not properly installed on your PC, it will not play MPEG4 Audio. Using DivX® You can also download a free DivX® Player and codec to play your MPEG and other video format files. DivX® for Windows is a free codec built to play every version of DivX content. The DivX codec also plugs into your existing video software so you can view and create high-quality DivX videos at a fraction of the original size. The DivX codec also adds DivX video playback support to most popular media players.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Televison & Video Logo
2,029 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
