You may need to take to a Pride dealer to plug the diagnostic unit in to check for faults. Have you got a power seat lift on the chair. When the seat is up (or not fully down) the drive speed is limited so you wont tip over. If the seat is down fully and still have problem, it could be the down micro switch needs adjusting or is faulty.
SOURCE: battery power on mobility scooter
The Hand Control has probably bent in from use. ( Where she Pushes the throttle Control )
Grab a hold of it and bend it out towards you slightly
The part about the indicator going down when she moves and back up when she stops is normal
SOURCE: Batteries are fully charged. Scooter goes at full
Based on your description you have a bad throttle potentiometer or speed potentiometer. Remove the covers of the front console and check the resistance throughout the range of both pots at the connector. It should be even throughout the range with no dead spots. The newer CTE throttle pot is more reliable than the older model Celebrity scooter with the 5K ohm potentiometer. I usually replace the throttle and speed pots as a pair since they are connected electrically in the console.
Load test the batteries while you are driving. Using your voltmeter that is still connected under the rear cover while you are driving, check to see if you get a voltage drop of more than 1 volt. Static testing of batteries only tells you that there is a full charge. It does not give you an indication of how the batteries perform under load.
If you have clean brushes, you can still have a large amount of conductive brush dust in the motor and armature. Blow out the dust with compressed air. Check the motor and brake with you meter. The motor coil resistance should be less than 1.5 ohms and the brake should read between 40 to 60 ohms. Hope this helps.
SOURCE: Jazzy 1113 Unit has a full
Go ahead and try this web site.It will give you the flash codes and narrow down your search to finding the problem.http://www.pgdt.com/scenter/diagnostics/diagvsi.html
