Question about Coby MP-610 MP3 Player
My coby 610 mp3 reads file sys error tried to reset unit, unable
I was attempting to charge unit via computer using usb cord,mp3 player froze up while refreshing library,attempted to reset,file sys error displayed
  • 69 Answers
May be thers to many data
Posted on Jul 11, 2009
My M-610 MP3 keeps saying its unplugged even when it's not?
Here are instructions for a solution to your Coby 610 problem.
Replacing the firmware of your Coby 610 MP3 Player will unfreeze it and help it act normally again. This will also fix the 'File System Error' that has been popping up with some Coby 610 players. You can find it at the cobyusa.com website by choosing 'Mp3 & Portable', then 'Mp3 & Mp4 Players', then your model 'MP610', from the support page. Or, here is the direct link to the file from Coby's servers.
Unpacking the zipfile from the Coby Website will give you a PDF file with instructions, and a program file to run.
Your music will be erased when you run this firmware update. The instructions suggest that even if your mp3 player won't startup properly, if you plug it into your computer you should be able to access it as a removable disk, and copy all your music to a temporary folder on your computer.
Here are the steps:
  1. Plug your MP610 into your computer.
  2. Copy all your music to a temporary folder.
  3. Disconnect your MP610 from your computer.
  4. Disconnect as many USB devices as possible from your computer (to simplify identifying the MP610 at a later step, and avoid damaging other devices by trying to load the MP610 firmware into them by mistake.)
  5. Run the Firmware Update program 'MP610 T LCD Firmware Update for file sys err.exe'
  6. You will see a screen with up to 24 numbered, empty boxes.
  7. Connect the MP610 to your computer. It will show up in one of the boxes.
  8. Once the MP3 player shows up, click on the Firmware Feature icon to start the firmware upgrade.
  9. After the firmware update is complete, you will receive a checkmark in the firmware box.
  10. Disconnect the MP610.
  11. Close the firmware update software.
  12. Turn on the 610 to confirm it starts up and the display reads 'COBY'.
  13. Plug it back into your computer and copy your music back on to it.
You can refer to this Coby 610 solution here.
I hope that helps.
Jan 10, 2010 | Coby MP-610 MP3 Player
Tip
COBY MP-610 File System Error
COBY MP-610 Digital Media Player File System Error Solution
Unpacking the archive from the Coby Website will give you a PDF file with instructions, and a program file to run.
Here are the steps:
on Mar 29, 2010 | Coby MP-610 MP3 Player
Tip
COBY 610 File System Error
Fix the File System Error of Your
COBY 610
Unpacking the zipfile from the Coby Website will give you a pdf file with instructions, and a program file to run.
Here are the steps:
I plug my coby mp3 n the computer can't read it
Here are instructions for a solution to your frozen Coby 610 problem. This works even though the MP3 player is having problems talking to your computer. They should communicate fine after this update.
Here are the steps:
I hope that helps.
Dec 25, 2009 | Coby MP-610 MP3 Player
How can i get my coby mp-610 stop saying file system error???
View MP-610:
http://www.cobyusa.com/?p=prod&prod_num_id=212&pcat_id=1001
Manual:
http://www.cobyusa.com/files/manuals/MP610_MN.pdf
Quick setup guide:
http://www.cobyusa.com/files/setupguide/MP610_SG.pdf
File system error refers to incomplete startup often due to low battery, faulty firmware or not matching files in the player.
When the startup failed try point 1.Resetting and 2.Charging:
1. Try to reset using the reset button hole on the backside (8).
299c492.jpg 2. Make a connection with the computer and have the device charging for a long period, full load needs 8 hours. Make connection directly to the USB of the computer preferred at the backside of the computer.
When using a laptop see to it that the USB is powered: laptops often switch the USB off going to sleep op hibernate mode.
When this didn't solve the problem, perform a format and reinstall of the firmware, point 4 - 8:
4. Connect the player to the computer and backup your data to the computer using the Windows explorer: copy MUSIC, MOVIE, PHOTO and TEXT directory to a location on the computer.
5. Format the removable disc of the player in Windows explorer.
Check your removable disk having its full memory capacity free after format.
6. Download the firmware for the player: firmware download for MP-610 ( zip file ):
http://www.cobyusa.com/files/software/MP610_Firmware.zip
7. Unzip the file: once unzipped there's a pdf instruction added in the zip file how to perform the firmware update.
8. After the firmware reinstallation the player is ready for transferring
data again. Remember the requirements for the format of files that is put on the player.
Sep 23, 2009 | Coby MP-610 MP3 Player
Coby mp610 says file sys err
I can help you with you Coby 610 mp3 player.
Replacing the firmware in your mp3 player will correct your 'file sys err' message and have it working like new again.
Please try these steps to fix your Coby MP-610 MP3 Player.
I hope that helps.
___________________________
Unfreeze Coby 610
Jun 22, 2009 | Coby MP-610 MP3 Player
Mp3 wont start, freezes, pc wont detect usb
I recommend you try the firmware replacement again with the file you can get form the link below. I have fixed several 610's with it.
I hope that helps.
Unfreeze Coby 610
Jun 15, 2009 | Coby MP-610 MP3 Player
Coby 610-2g won't turn on or charge
Replacing the firmware in your mp3 player should have it working like new again.
I hope that helps.
Unfreeze Coby 610
Jun 03, 2009 | Coby MP-610 MP3 Player
Coby MP-610  MP3 Player Logo
288 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Peter Dragonetti
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
