Question about HP Pavilion dv9700t Notebook PC
My troubleshooter tells me to disconnect my cd rom - what am I supposed to do? It said that the driver is prepared to be safely removed _ I do not want that!
  • 358 Answers
Restart your system first, After this go to the device manager page, then click on add new hardware,- (that is if the CDROM has not been installed automatically when you started the system)-. After this, try and follow on-screen instructions and let it detect it automatically and re-install it for you.
Hope it helps you out.
Posted on Jul 11, 2009
It keeps telling me to conect a burner and restart the player?
make sure that the cd-rom is getting enough power test all leads that are attached to the cd-rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd-rom then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Dec 26, 2010 | Compaq (120192-B21) CD-ROM Drive
My pc doesnt detect my HL-DT-ST-DVD-RAM-GSA-H55N LG super multi dvd/cd-rom, i tried checking ide cables but still it doesnt read, i cant even see the dvd/cd-rom on device manager------there is no...
you might have to uninstall both the dvd/cd + its drivers then reinstall them actually unplug the cd/dvd from its power cable then restart your computer plug it back in your computer should activate found new hardware or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Oct 31, 2010 | LG GSA-H55N DVD-RAM Burner
Cd rom
First use the following steps:
Use the following link, scroll a little and click on Fix It
http://support.microsoft.com/kb/314060
Click Run in the File Download dialog box and follow the steps in the wizard
When completed restart the computer and check the CD/DVD drive
(you may need to run Fix It twice)
Mar 10, 2010 | HP Pavilion a305w (DM181AR) PC Desktop
Need to install second cd driver in desktop computer
It would be much simpler to remove your current CD-ROM drive, and install a CD/DVD-reader-writer combination drive.
1. Turn the computer off, and disconnect the AC power-cord.
2. Remove the side-panels from the case.
3. Disconnect the "power" and "data" cables from the back of the CD-ROM.
4. Remove the screws holding the current CD-ROM in position.
5. Slide the CD-ROM out the "front" of the case.
6. Slide the new device into place, until the face is "flush" with the front of the case.
7. Screw the device into position.
8. Connect the data and power cables.
9. Reconnect the AC power.
Windows will "find new hardware", and will adapt itself.
Dec 10, 2009 | Acer Computers & Internet
PROBLEM WITH ACER ASPIRE 7535 CD-ROM
Put Lense Clener In To CD ROM
ruhidshirazi@gmail.com WWW.RSINFOTECHSYS.BLOGSPOT.COM
Oct 18, 2009 | Acer Aspire 5735 Notebook
Hi my name is ronchy. i have a problem with my coomputer. My cd/dvd-rom driver doesn't appear on my computer please tell me arrange this problem.
THe problem is you have lost the driver software of your CD-ROM. Remove teh cabinet and unplug and replug your CD-ROM, and restart the system. And install the driver again.
Thank you!
Sabharish
Jun 02, 2009 | Computers & Internet
Deleted cd-rw/dvd-rom driver
I talked directly with HP about your problem. Unless you can find the driver in system32 or your windows installation disc, you will likely have to reinstall windows. Prepare a backup of all important files on that desktop though, because data loss is possible.
May 21, 2009 | HP Computers & Internet
Cd-rom, computer won't load.
You will need to call our technical support line on 0845 20 20 118
Dec 24, 2008 | Dell Latitude C640 Notebook
Error Code 47 - Got this message when looking on the system info under problem device? I'm not a technician.... don't understand where and which are the conflicting devices. My CD-DVD Rom doesn't work and...
Hello ,
As per the issue described by you Error Code 47 is described by Microsoft as given below ( as in the link http://support.microsoft.com/kb/310123 ) :
Code 47
Windows cannot use this hardware device because it has been prepared for safe removal, but it has not been removed from the computer. (Code 47) Recommended resolutions
Here are some things that you can try to resolve this problem.
Reconnect the device
This error code occurs only if you used the Safe Removal application to prepare the device for removal, or pressed a physical eject button.
Reconnect the device to your computer
Disconnect this device from the computer, and then connect it again.
Restart your computer
Make sure that the device is connected correctly to your computer, and then restart your computer. Click Start, click Shut Down, and then select Restart in the Shut Down Windows dialog box to restart the computer.
If it still does not help then definitely refer the notebook to the HP authorised service centre.
Regards ,
Puloma
Oct 16, 2008 | Computers & Internet
Removing cd rom
Preparation Steps before removing CDROM:
1.Power down and remove power to the system.
2.Remove access panel.
3.Remove CPU fans and fan basket.
4.Pull the system tray out until it stops.
To remove the CD-ROM drive:
1.Disconnect the power and signal cables from the CD-ROM drive.
2.Loosen the thumbscrew located in the fan basket area to release the metal locking bracket.
3.Slide the metal locking bracket away from the center of the server.
4.Push the CD-ROM drive out of the front of the chassis from the interior of the system.
5.Pull the CD-ROM out and away from the chassis.
Apr 12, 2008 | HP Compaq ProLiant ML530 Server
Open Questions:
HP Pavilion dv9700t Notebook PC Logo
55 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
