Not too hard if it is a southern car, if it's from the north, a bit more effort might be needed because the nuts on the exhaust rust. If you are working on the ground, get it up high on ramps or jack stands. Always put another support under the car. Leave the floor jack in place and use jack stands, slide something, like the front tires, under the car, too. NEVER work under a car without a backup support. Cars can, and do, fall off jack stands.
1st you have to remove the exhaust "A" pipe. 3 nuts, 14mm on each exhaust manifold need to come off. ALWAYS spray a penetrating lube, like WD40, on any exhaust nuts before loosening, and before installing them. You need a really good socket, extension and a breaker bar, make sure the socket is on the nuts correctly, break them loose without rounding them off. Then two 12mm nuts on the support bracket, and 3 14mm nuts at the outlet of the "A" pipe at the converter. If these last 3 are too rusty, you can unhook the exhaust hangers and move the assembly over. (Leave the back muffler hangers on.) Drain the oil. (I always try and do these jobs when an oil change is due) two 14mm bolts going from the oil pan to the transmission, and a 10mm bolt holding an access plate at the transmission end, remove access plate. Now a bunch of 10mm bolts and nut holding the oil pan in place. You might have to pry the pan loose, a big drift works good. There are a couple of spots to hook onto and pry.
SOURCE: how to remove door panel on 1997 acura tl
Follow this link. There is detailed step-by-step info here
Please kindly let me know if it works for you
Good Luck
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c1528008c18d
SOURCE: HID BULB REPLACEMENT 2003 ACURA TL DRIVER SIDE
heres the procedure I uploaded it for you click [b][i]HERE[/i][/b]
SOURCE: 2003 Acura TL TypeS - heat and air not working
it's a wire from under the dash it usually burns out after awhile,i had the same problem email me at [email protected] for more info on the wire i forgot the name for it.
SOURCE: ACURA TL SERVICE DUE SOON B1
It's a service interval reminder light that you should take your car to acura and have them perform the "b1" service. I would ask for an estimate first, and ask what that service includes. You may be surprised to find necessary and unecessary services. Some people view the b1 light as a way for Acura to get you car in there, quite possibly be charged for things you could probably do yourself.
SOURCE: 2003 acura 3.2 tl type-s. radio code
Retrieving Your Radio or Navi Code
You can retrieve your code using
A) This website ( https://radio-navicode.acura.com/ ) and by
providing identity verification
and vehicle information in a few simple steps.
OR
B) Contact an Acura dealer, provide requested info (such as the serial number) to receive the Radio/Navi Code you are requesting!
GO HERE: https://radio-navicode.acura.com/
Information You Will Need
Vehicle
VIN Number
Phone
Number and Zip Code matching those on file
Device Serial Number: Radio
and / or Navigation
Hours of Operation
This automated process is available
Monday to Friday 4:00 AM to 9:00 PM PST
(Pacific Standard Time) , 4:00 AM to 6:30 PM on Saturdays , and 4:00 AM
to 9:00 PM PST on Sundays.
OR
see ACURA FAQs for official info about this topic. http://owners.acura.com/site/site_sitehelp.aspx#faq14
Alternate ways to contact Acura are listed below:
By Phone: (800) 382-2238
Monday through Friday,
6:00am to 5:00pm Pacific Standard time at the toll-free phone number
above
By Fax: (310) 783-3535
By Mail:
Acura Client Services
Mail Stop 500-2N-7E
1919 Torrance Blvd.
Torrance, CA 90501-2746
Roadside Assistance
(800) 594-8500
24 hours/day, 7
days/week
