Question about Canon Powershot SD450 / IXUS 55 Digital Camera
My canon ixus 9015 digital camera has ben dropped and the metal bit and the front, the lense shutters and another plastic part has come off. i have all the parts but im not havinch much success with putting them together.
  • Canon Master
  • 4,738 Answers
This might help with some examples. Although none are elph series, it should be very similar, except in miniature:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Posted on Jul 11, 2009
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
I drop my camera ixus 9515 canon
Before taking your camera to an authorized Canon repair shop try these procedures. If you need to contact Canon, start here.
Mar 26, 2013 | Canon Cameras
My canon 50d squeals when shuter is released
The shutter is a moving part. It is also made up of several plastic leafs that rub together when opening and closing. Lift the mirror to see if any of them are damaged. You will have to fire the shutter each time before you look as there are 2 sets of shutter leafs. 1 set at the top and 1 set at the bottom firing in rotation. 1 set is of 4 and 1 set is of 2 leafs. also check the action of the mirror. Both are run from the same motor and both have springs to help operation. metal on plastic tends to wear so how many shots have been fired? To check shutter count look up astrojargon and download the EOSinfo software (free) and plug your camera in to your pc. Should give you a shutter count.
May 11, 2012 | Canon EOS 50D Digital Camera
Canon powershot sd1400 is e32 error?
The problem is related to the mechanics in the optical image stabilization. There are 2 plastic ball bearings inside the shutter/lens module that can pop out of their round holders that are held in by 2 springs. This can occur by simply dropping the camera with the lens extended. I fixed many of these particular models and would not recommend an amateur attempt the fix as the complete lens has to be disassembled. A very poor Canon lens design.
Oct 16, 2010 | Canon PowerShot SD1400 IS IXUS 130...
I have the same problem as this person: I have a Canon Digital IXUS 500 with the same problem: when turned on previous pictures can be viewed menu and fuctions available , unable to take and view pictures...
Hi!
There could be two causes - a dead CCD or a broken shutter cable inside the lens (so the camera is not able to open the shutter) - they both are common problems with the camera and are expensive to repair. I don't think it's worth it.
Sorry for the bad news!
Tom
Oct 09, 2009 | Canon PowerShot S500 IXUS 500 Digital...
I have a Canon Digital IXUS 9015, i was wondering where the setting is for black and white photos?
On the IXUS 900 you can not use black and white, although you can change it to black & white when you go to print it in the shops or on the computer in programs like adobe, zoombrowser or windows.
Oct 01, 2009 | Canon Digital SD900 / IXUS 900 Ti Digital...
I'm looking for an instruction manual for a Cannon IXus 9015 digital camera.
Am unfamiliar with an IXUS 9015, but I think you really mean IXUS 90 IS? If so, the camera is known in the United States as the SD790 IS. You may download the manual directly from Canon at the following link:
http://gdlp01.c-wss.com/gds/0300000871/PSSD790IS_IXUS90IS_CUG_EN.pdf
May 03, 2009 | Cameras
Canon G7 lense does not extend fully but it is NOT e18
Maybe lens needs adjustment. The info on this page may help. Copy and paste this link for more info.
http://www.fixya.com/PostAnswer.aspx?thid=1841738&prdid=447928&ctgid=67
Mar 22, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Dropped my camera canon sd450
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 17, 2008 | Canon IXUS V2 Digital Camera
Canon ixus 400
throw it and a new one a bit more modern.
Aug 20, 2006 | Canon PowerShot S400 / IXUS 400 Digital...
Open Questions:
Canon Powershot SD450 / IXUS 55 Digital Camera Logo
797 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
