Question about Garden
I have lost the screws out of the hedge trimmer attachment
I have lost some of the screws out of the hedge trimmer attachment and it is now very loose on the shaft and keeps turning round.
  • 64 Answers
Go to the hardware store and find screws that fit properly
Posted on Jul 11, 2009
Cant remove pull rope housing from homelite gas hedge trimmer
there is a screw in the hole of the clutch housing bell torx bit i think its a #20
Jun 04, 2012 | Garden
Hi i wonder if you can help my Ryobi hedge trimmer has a problem with the pull cord it works goes in and out but it does not turn the engine over is there maybe a key way or something that maybe broken...
Hello Nick,
Inside the cord attaches to a plastic wheel which cranks the engine. This cord can become loose or can break after some use. Try opening the plastic casing where the cord is to see if this is the problem.
Thanks
Jul 25, 2011 | Ryobi ZRRY30550 Factory-Reconditioned 30cc...
16" B&D Hedge Trimmer, No.
motor smoking is an electrical fault internally
brushes , armature of field windings problem
take it in for a proper diagnosis
Nov 13, 2017 | Black & Decker 16Inch Hedge Trimmer
My hedge trimmer blades do not move when I turn it on
Check the power wires that connect to the motor. My 18 inch B&D hedge trimmers both had loose wires at the motor that had to be re-soldered. You will need to open the trimmer casing to get to the loose wires, if that is the problem.
Jul 09, 2010 | Black & Decker Hedge Hog 20-Inch 2.8-AMP...
I've got a craftsman 22 in. hedge trimmer (electric) and I'm looking an attachment to enable me to trim my hedges, which are approx. 8' tall, without climbing up on a ladder to trim the tops of the hedges....
Un less your trimmer is a split sharft model ie you can take of the blade by undoing a handle then the answer is no you will have to buy a diff trimmer
Jun 28, 2010 | Craftsman 22 in Hedge Trimmer
Does anyone know the factory mixture setting screws for electrolux hedge trimmer
Carefully Bottom each screw and turn out 1 to 1 1/2 turns. This should get you started. Adjust low and high speed screws till it idles and does not hesitate on high
Oct 21, 2009 | Electrolux Gas Hedge Trimmer
How do fit a hedge trimmer attachment to a rbc 40 sb brushcutter ? thanks
This unit was not made to have interchangeable heads. Ryobi makes a hedge trimmer attachment for some of its units that are quick connect.
Otherwise, you may buy this attachment and see if you can interchange the head from the brushcutter to the hedge trimmer. You may find it more work than you want to tackle.
Sep 26, 2009 | Ryobi Garden
Expand-It Hedge Trimmer Parts
Belive it or not there is a nice selection at Homedepot.com
Jun 17, 2009 | Homelite Expand-It Hedge Trimmer...
Electic trimmer
You're going to take off like 20 screws including the ones that hold the handle and the hood at the base of the blade. You open it like a clamshell. There is a black plastic cover at the very bottom that covers the gear wheels (one tiny wheel that comes from the motor and a large wheel that actually moves both blades back and forth). The black plastic cover is no attached with screws. You just remove it so you can get to the gears. Now you oil and manipulate the large gear wheel until it comes loose and you can see the blades move back and forth. Put the whole thing back together and you are ready to go!
Jun 12, 2009 | Black & Decker Hedge Hog 22-Inch 2.8-AMP...
Troy-Bilt Trimmer TB425CS
Sound like the clutch is going out or already is bad. There should be a cone shape cover that attaches the engine to the handle. Usually with 4 screws. Take those screws out and seperate the housing. There is a small centrifugal clutch, which is probably bad.
Jan 20, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Garden Logo
Top Garden Experts
roeb
john h
Marvin
Marvin
