Question about Maisto Ford Svt F150 Lightning P/U Truck
Windows will not work
Cant get my windows to go up or down and radio stays on unless i open passenger door its a 2005 ford f150 kingcab
    Problem Solver:
  • 5 Answers
Failed window regulators are extremely common. 2004-2005 have been known to break, there is an updated regulator from the dealer. Are you sure the radio wont go off when any door is opened. Driver door ajar switch may be another issue.
Posted on Mar 07, 2010
I have a 2005 ford f150 s/cab. The power windows, locks and mirrors won't work from the drivers door along with the other doors (I have a 4 door). Only by key-less entry (remote) does it lock and unlock....
The radio not turning off when you turn off your vehicle could have something to do with your ignition switch, and the accessory position on the ignition switch itself. On older vehicles, this becomes worn out, and a little sloppy. This in turn causes the ignition switch to provide power to the accessories even when it should not. It's a far shot in the dark, but It's a possibility.
Oct 19, 2013 | 2005 Ford F-150
Windows do not work
Is the battery failing,if so it will, as you said
mess with the GEM Module & it's relays &
give you just what your getting.
You may have a bad door switch as well a battery
Jul 24, 2013 | 2004 Ford F150
Battery wont stay change
have u test the battery and the alternator?
Dec 13, 2012 | 2004 Ford F150
I have a 1998 ford f150 the interer lights stay on all the time not sure what to do so i took out the fuse now cant even use the windows in my truck. Hope there is a simple souloution to this problem
This is generally a case of the door ajar switch in the door is not working correctly, and needs to be sprayed down really well with WD-40 and close open the door. Might need to do this 2 or 3 times to get it to work.
Some what common issue on the older trucks in the 97-03 MY range.
Thread on this that shows the location at F150online.com
http://www.f150online.com/forums/electrical-systems/193352-if-your-door-ajar-dome-light-staying-read.html
Feb 21, 2011 | 1998 Ford F150 Regular Cab
Electric window on 2005 ford f150 won't work . want to repair myself. need manual or specific instructions
Driver side window is down and won't let up, checked fuses, what are some other possiblities. 2006 f150
Jan 16, 2010 | 2005 Ford F-150
My Ford F150 XLT Triton driver's side power window
window regulator failure. Check window regulator guide for damage. If damage replace!! Hopefully this helps
Jul 20, 2009 | 2004 Ford F150
2005 f150 "Door Ajar Light Always On.. Even with all doors shut..
What happens when you remove both switches, and wires? What happens when you use a jumper wire acros both wires, on both doors?
Feb 25, 2009 | 2005 Ford F-150
I have a ford f150 and window went down 2 inches with the switch and no i cant get it to roll up or down, looked at switch its all together. wigled wires around that didnt work. wondering if anyone knows...
Chad , using a test light check for voltage at he switch when pressing up or down. If you have voltage, you probally have an open winding in the motor or a dead spot.. [Im serious] Try smacking the lower door with a RUBBER mallet to jar the window motor while hitting the up button. If the motor has failed completly, switching wires will not work.
Feb 20, 2009 | 1992 Ford F150 SuperCab
92 F150 power window and locks
try taking apart and cleanig all contacts first. make sure you are getting power to switch. Sounds more switches are going bad. They usually last about 5 to 7 years before they start going out.
Jun 11, 2008 | 1992 Ford F150 SuperCab
Maisto Ford Svt F150 Lightning P/U Truck Logo
142 people viewed this question
Top Maisto Toys Experts
ray gallant
17 SOUTH INDUSTRIES
17 SOUTH INDUSTRIES
Are you a Maisto Toy Expert? Answer questions, earn points and help others
