Thought it was wheel bearing thats tight took cv joint out cause it clicks an goes in an out while turning wheel. Has a lot of play. bad vibration an humming. If not cv joint could it be a bearing in transmission?
Cv joints should not click as that is the first indication of a failed unit
( going slow and changing direction produces a click,click is a cv joint)
wheel bearings should not be tight as that will produce a humming noise and will result in early failure
because the axle turns with the change of direction ,the distance from the pivot point to the transmission changes and so the shaft will move in and out of the transmission to compensate
take it to an accredited drive line specialist for a diagnosis
