Question about Kenmore Washing Machines
Does anyone know where the water temperature sensor is on a Kenmore HE2 washer? I have an F24 error code and I need to check the sensor. Thanks.
  • 15,935 Answers
This advice is for Whirlpool Duet and Kenmore Elite model FRONT LOADERS displaying the “F24” Error Code. Some of the error codes on these model washers can be erroneous, however. The first step in troubleshooting any error code is to simply unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main "brain" of the washing machine. If the error code reappears following a CCU reset, then you have a genuine problem.
"F24" is an indication of a water temperature sensor (NTC) error, or Heating Circuit failure. Check the Water Temperature Sensor and check connections to the Water Temperature Sensor.
To access, you will have to UNPLUG your washer and remove the lower access panel under the door. The panel comes off by removing the screws under the bottom edge. HINT: If you place a 2 x 4 under the front feet of the washer, it will make access to the screws much easier. If the panel sticks, a tap on the sides will knock it free. The panel will drop down then come off. The sensor (NTC) is located at the base of the wash tub in the front on the heating element. This will be a small square shaped plug between the heating element terminals. Make sure this plug is secure and not loose or unplugged. It is common for the connector plug to come loose due to vibration. If the plug is intact, check the contacts for corrosion. If everything appears as it should, then unplug the wire harness and take a resistance check. Readings will be as follows:
Temperature Meter Reading
32°F (0°C) 35.9 K ohms
86°F (30°C) 9.7 K ohms
104°F (40°C) 6.6 K ohms
122°F (50°C) 4.6 K ohms
140°F (60°C) 3.2 K ohms
158°F (70°C) 2.3 K ohms
203°F (95°C) 1 K ohms
Roughly...around 9K ohms at room temperature if I'm reading the chart correctly. Take readings as listed and also double check the connector to make sure it is not oxidized. Try cleaning the plug and reconnecting to see if the error code goes away. If not, you will probably have to replace the sensor. If the sensor checks good, take a reading across the heating element terminals. It should indicate about 15 ohms.
Lastly, remove the washer top panel by removing the three screws holding the panel in place in the rear. Once the screws are removed, slide the panel back then off. Locate the Central Control Unit (CCU) directly behind the wash tub. Take a resistance check at the Heating Element Solenoid by removing connector 9 from the CCU (this is the second connector from the RIGHT as facing from the front). A reading across test points 1 & 2 should also read 15 ohms.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
Tested water temp with an ohm meter and connection
The "F24" error code is an indication of a water temperature sensor error. The temperature sensor is located at the rear bottom of the tub. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 09, 2012 | Kenmore HE2 Plus Front Load Washer
Check the water temperature sensor on a kenmore he2 plus washer
I am having the same problem, one wire broke off from the plug. Can this plug be fixed or will I have to buy a new wire?
Oct 29, 2012 | Kenmore HE2 Plus Front Load Washer
Error code f24
Hi
F24 is a water temperature sensor error. You have to unplug the washer and check the water temperature sensor and its connections, if that is fine then check the resistance of the heating element and the part that is bad should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 31, 2011 | Kenmore HE2 Plus Front Load Washer
We are seeing F24 for the first time today on our Kenmore HE2plus front loading washer. What does it mean? How do I solve it?
Hi
Daniel
Aug 08, 2011 | Kenmore HE2 Plus Front Load Washer
The meaning of error code 24?
Hi, F24 error code a water temperature sensor error or enought hot water to the washer.
check to see you have both valves are turned on. Also, the water inlet valve on the washer has a screen and it is known to get clogged and restrict water flow. Turn off the hot water valve. Pull the hot water hose off where it attaches to the back of the washer.
Even if you are getting good hot water flow, inadequate water temperature can cause an F24 error code. Check the temperature setting on your hot water heater. It should be set at 120 F. You should reach this hot water temperature at your washer within about 1 minute.
If you are getting a good hot water flow, you may one of the following failures:
1 loose or dirty connection at the temperature sensor or control board.
2 The temperature sensor could be out of range. Bad or shorted sensor
3 Control board failure.
The temperature sensor should have a resistance reading of 6.6k ohms at 104 degrees F and should drop in Ohms as temperature rises,
The temperature sensor is located at the back lower section of the tub with 2 small black wires. It would require a ohm meter to measure the resistance of the sensor. .
Sep 13, 2010 | Kenmore HE2 Plus Front Load Washer
He2plus does not drain and spin
code F24
WATER TEMPERATURE SENSOR ERROR
next information is only for the TECHNICION
If the water temperature sensor NTC value is out of range (23 F to 217 F to 103F C) during the water-heating step of the WASHcycle.
NOTE:To find corrrect Ohm reading refer to the water temperature sensor in TECHNICION ONLY section.
Possible couse/Procedure
1.- Unplug washer or disconect power.
2.*check the water senser and conection to it.
3.-check resistence of heating element, if present on this model(abnormal=indifinity)
4.-refer to the water Temperature Sensor section
Am sorry but F7 error code is not in the information system.
"Was this helpful?"
May 11, 2009 | Kenmore HE2 Plus Front Load Washer
HE2-plus washer will not start. error, status light shows "F-24"
code F24
sorry but the following information is for TECHNITION SERVICE(only)
"Was this helpful?"
May 10, 2009 | Kenmore HE2 Plus Front Load Washer
Error code f24
F24 indicates a water temperature sensor error. If during the wash cycle in the water-heating step, the water temperature sensor (NTC) value is out of range the F24 error code will display.
Possible causes:
  • Too cold of water or hot water is turned off
  • Temperature sensor failure or loose connection
  • Control board failure
Dec 18, 2008 | Kenmore Washing Machines
Washing Machines Logo
253 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
