Question about Uniden BC248CLT Base Scanner
My Volkswagen Golf GTI had to have its battery disconnected, but now my radio does not work and needs activating. I type the code in but this does not do anything. Could you tell me the procedure to input the code and get the radio working?
  • flam528 Jul 11, 2009
    Probably five times
  • 6,784 Answers
HI, this is a very important question i am about to ask you. How many times did you attempt to enter the code?
Posted on Jul 11, 2009
  • Michael Masters
    Michael Masters Jul 11, 2009
    OK, the unit is programmed to lock down after the third unsuccessful attempt. This is a pe-programmed security feature that is to prevent the usage of this unit if it was stolen during a break-in.
    Due to this unfortunate situation, you will need extract this unit and, send to the manufacture for the unlock procedure or, you can take your entire vehicle to the nearest dealership to have the service techs reprogram(unlock) the unit.
Radio not working golf gti mark 4
If factory installed put on radio.The safe sign will appear.There should be a 4 digit code for the radio.Punchin the code using numbers 1-4.Press repeatedly from number 1 till for the fist digit number 2 for the second digit etc.when you have punched the code in the safe sign will appear.Briefly press loud /expert then wait a few seconds your radiio should then display .Look for your favourite channels .If you punch in the code wrong there is a waiting period.First attempt wait 21 seconds ,second attempt1.5 minutes 3rd attempt5.5 minutes...4th attempt22 mins.5th attempt1.5 hrs. If this fails ,disconnect battery and start again
Aug 11, 2014 | 2000 Volkswagen Golf
My vw golf tenacity battery went flat replace now my radio is blocked on safe mode and showes two
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your VW service centre and get them to enter this code for you.
Mar 29, 2013 | Volkswagen Car Audio & Video
I have bought a 1999 volkswagon golf and the the battery was disconnected during repairs and the radio will not work without a code . How can I remove the radio to access the serial number so I can...
need code for radio
there is little slots in radio and use whats known as radio keys to remove them
and radio shop or automobile supplies should have them
lot of different types so bring car with you keys inserted and they pop the radio for removal
hope this helps
Feb 15, 2011 | 2007 Volkswagen Golf
Im looking for the raido code for my vw golf,,,, i changed the battery the other day and i need the code for the radio to work ,,, does any 1 no where i could get the code ..... its a gamma radio serial...
If it is a factory radio,you can contact a VW dealer(I think you need the VIN# also)and they will provide the code for free.Write down the code and method because anytime the battery gets disconnected that will happen and it does get disconnected for some problem checkouts other than battery or alternator.
Good luck! Greg
Sep 25, 2010 | 2001 Volkswagen Golf
The battery was replaced and now the radio in my 2003 gti does not work
When you disconnect/replace a car battery, your radio anti-theft security system will be triggered: consult your car user manual on how to reset the anti-theft security for your particular radio/audio system: you will need to enter a specific 'security code' that should have been provided when your car or car audio system was bought.
Dec 24, 2009 | 2003 Volkswagen GTI
Golf gti left rear door locking system
it is probably your door lock has gone into safe mode.you need a new door lock.try using the lock/unlock button on your remote or on the drivers door button and gently tap the door handle with your hand while pressing the lock/unlock button,carefull not to dent your car.if that does not work,try disconnecting the cars battery for a few minutes,but note the vehicle might pick up fault codes which need a diagnostic machine to clear...good luck
Nov 09, 2009 | 2001 Volkswagen Golf
Radio reset code?
Radios go into safety mode when power is lost like a battery being changed. The only way to find out the code is if you can contact the original owner and they still remember or you have to take it to a VW dealership service station. The service department can find out the code it might co$t you though.
Apr 24, 2009 | 1996 Volkswagen GTI
Geargox for mk 4 1.8 gti
The way to find this out is simple, on the housing of the trans there is a code, a serial number, that will tell you what type of gearbox is required for this model.
Mar 02, 2009 | 2000 Volkswagen Golf
Uniden BC248CLT Base Scanner Logo
41 people viewed this question
Top Uniden Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Van Allen II
Van Allen II
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
