Question about Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive
Laptop does not read WD400GB hard-drive.Tried every port, does not make noise, light is on, and it is about a month old! Can anyone help please???
Are you using the short usb cable that came with it? Will a desktop recognize the drive?
I had an issue with mine where the laptop would light the drive but it wouldn't show up. Used a 6" usb cable and problem solved.
A lot of laptops don't put out the required power for these to use a longer cable. But, a desktop will.
Posted on Aug 24, 2009
Backup Plus Potable 500 GB Light Blinking and disk not being read I've got a Seagate 500 GB backup plus external hard disk which is about 2 months old. The hard disk has started to make a slight clicking...
The clicking could be a symptom of imminent failure of the hard drive . Back up all information from this drive as soon as possible. It may be something that a program such as checkdisk can fix but be sure to backup drive before attempting any fixes just to be safe. Hope this helps.
Dec 31, 2013 | Seagate FreeAgent® GoFlex? Black 1TB...
I have hooked this up with my laptop to back up my system and the drive is not linking with a laptop that it has manytimes before and is now making a clicking noise like something is catching. This is the...
If the drive is making noise, that means the drive is physically malfunctioning. It is possible that your laptop is causing a short in the units. However if you use usb ports often with no other issues, then it is probably just the drives being defective.
Jan 02, 2011 | SimpleTech 1TB HITACHI SIMPLEDRIVE IIUSB...
I just purchased a WD400GB portable hard drive. I
Hi. Yes it should wok on your MAC
by doing this >>> http://tinyurl.com/5bnyj9
Hope this helps but if not reost and ill try to help you further ok ;-)
all the best
Mark
Aug 24, 2009 | Western Digital WD Passport 250GB Portable...
WD800U017 passport problem
The drive in the case is broken. You will have to take the drive to data recovery centre to recover your data.
Aug 03, 2009 | Western Digital Passport WDXML800UE...
WD hard drive not recongnize by laptop!
Do ypu have another computer you can test it on? Plug it into via your USB port.
Jul 12, 2009 | Western Digital My Book Essential Edition...
External Hard drive = possible shortage???
I have found that after all the new updates the system takes on. It becomes less an less likely to even recon ise old equipment. This one way the big guys phase out our old stuff.But you should be able plig in external drive , in a usb port . like a 40 gig for about $70.00 at raido shack, and they will stear you in the right direction. thoes guy know there stuff
Apr 11, 2009 | HP/Seagate 3.5inch 450MB IDE Hard Drive...
My Hp Pavilion dv6700 laptop will not start properly. I was in the process of installing a program, and the screen forze. I restarted the computer by holding down the power button, and I tried to reinstall...
Hi there.
Seeing as the laptop is only 5 months old it is still covered by the manufacturers warranty, the clicking sound you can hear is the hard drive failing, the hard drive is hardware and IS covered by the warranty.
Send it back to HP it won't cost you anything to have it repaired.
Good luck and thanks for using Fixya!!!
Feb 23, 2009 | HP Pavilion dv6000z Notebook
My computer stopped reading my external hard drive
Try the drive in a different USB port. If it still fails try another computer. If it still fails then it's possible the drive is bad. If the warranty has expired you may be able to find a tech savvy friend to remove the actual drive from the case and hook it up to another computer directly. If it recognizes fine then the case is bad. If it does not recognize the drive then the drive is dead.
You won't be able to retrieve the files on the drive unfortunately unless you use an extremely expensive service. These tend to run in the hundreds of dollars.
Nov 22, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive Logo
157 people viewed this question
Top Western Digital Computers & Internet Experts
Alun Cox
Marvin
Marvin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
