Question about Acer eMachines 520-2890 Notebook
I have exernalhard 60 gigabites connected to asus laptop my laptop can not read the hard i need help
  • lazyart May 11, 2010
    When you plug it in, do you get a chime from Windows indicating that something was plugged in?
How do I determine what motherboard I need for my Asus laptop G46VW-BS15
If your Asus laptop has a defective motherboard, you can open the casing and read the motherboard reference on a green sticker printed just below the socket of the CPU, as you can see in the image hereafter
http://www.dhgate.com/product/60-nmmmb1100-c06-for-g46vw-rev-2-0-laptop/237664478.html
The sticker with the reference of the motherboard is between the CPU socket and the memory socket (here it is 60-NMMMB1100-C06 but I don't know if it also the motherboard on G46VW BS15 laptop.)
Jan 11, 2016 | ASUS Computers & Internet
Asus ac68u router is not working with my powerline adapter. The router is brand new and less than a year old. The powerline adapter are tp link 500mpbs model tl-pa411. I have tried directly connecting
HAVE YOU DONE A VOLTAGE CHECK ON THE ADAPTER? IF NOT, READ WHAT THE VOLTAGE ADAPTER OUTPUT IS. IF THE MEASUREMENT IS DIFFERENT OR DON'T GET A READING AT ALL IT MEANS YOU HAVE AN OPEN CIRCUIT ON THE ADAPTER. MOSTLY MOST WIRES BREAK UNSEEN INSIDE THE PLASTIC INSULATOR NEAR THE PLUG END OR NEAR THE ADAPTER END, WHERE THEY BEND MOST.
Oct 28, 2014 | ASUS RT-AC68U Dual-band Wireless-AC1900...
Install hard drive in asus eb1037
Some of the specification includes;
For storage, the Asus EB1037 has 320GB hard drive up to 1TB, with SSD options from 64GB up to 128GB. Despite its size, it has the sufficient amount of both wired and wireless connectivity options. It has dual band WiFi 802.11 b/g/n/ac connectivity with Bluetooth 4.0. It also has a Gigabit Ethernet port, 2x USB 3.0 ports, 4x USB 2.0 ports, an HDMI port and a VGA port. The whole package is only 219mm x 172.5mm x 29mm. The Asus Eee Box EB1037 is not actually a replacement for console gaming, rather it would be great for web browsing, watching movies and light or casual gaming needs.
Aug 16, 2014 | ASUS Eee Computers & Internet
OS WON'T LOAD
test all power and data leads that attach to your hard drive IDE SATA
MOTHERBOARD TO THE HARD DRIVE make sure they have secure dust free connections and are not faulty if its a flat ribbon 40pin ide
this will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure dust free connections
a computer needs power and data to travel through every working device and continue its cycle and have a finishing point so any faulty leads will end up with a computer error
make sure the CPU has a secure dust free seating with thermal paste
make sure your ram modules are securely seated with no dust in the sockets also the Cmos battery has charge with no dust in the socket
on some motherboards cmos batteries are soldered in
hope this helps
Aug 16, 2012 | ASUS Computers & Internet
Does asus x52f series have bluetooth
Hello
Send your Email address to me by Fixya comment box. I've the downloaded user manual to your Asus X52Series Laptop. I can't send it to you by this window as it does not allow me to upload PDF files by it. I'll send you a copy of the user manual by return mail. OK.
Dec 18, 2011 | Computers & Internet
I'm not able to connect with my ASUS M50vm to ethernet. how i can check if the hardware is working?
The driver should be on the motherboard disc or the one supplied by your ISP internet service supplier
make very sure all leads are plugged into their specific connection plugs you might have to connect the usb lead to your modem to get a connection then
click start control panel,administrive tools,computer management,device manager scroll to network adapters could see a yellow question mark? right click install drivers
hope this helps if you cant find the driver hopefully one of these will help you
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
Realtek RTL8139 Family PCI Fast Ethernet NIC
http://download.cnet.com/Realtek-RTL8168-8111-PCI-E-Gigabit-Ethernet-NIC/3000-2112_4-99235.html
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access
http://download.cnet.com/Realtek-RTL-Gigabit-and-Fast-Ethernet-NIC-Driver-Windows-2000-XP-XP-64-bit/3000-2112_4-10278840.html
Drivers for RTL8100B(L)/RTL8100C(L)/RTL8101L/RTL8139C(L), RTL8139C(L)+/RTL8139D(L)/RTL8100(L), RTL8130/RTL8139B(L)series. Windows
May 16, 2011 | ASUS Intel 440BX Chipset P2B-VM...
My laptop connect to wireless modem (asus AM604g) and after 30 - 60 min hang wireless and i must reset my modem to connect again. What is problem thank you.
Please make sure that the router and the not placed need to any electromaganetic source or any heat source. The modem/router should be placed in well ventilated area and if possible on a wooden surface. The wireless hangs becouse the modem/router gets heated up.
Jul 01, 2010 | ASUS WL-AM604G Wireless Router
Cannot detect external sata hard disk
I would start by swopping the Internal Sata Cables around and check if that solved it.
If not then there's probably a problem with either the E Sata HDD Controller board or Even the HDD or the Sata cable going from the Motherboard to your input E Sata Port.It's a matter of elimination.
So Remove the HDD from the Enclosure and plug it directly into the Motherboard and see if thats picked up.If it is then the HDD is fine.If not, get it replaced and it might still be under warranty.Check with the manufacturer.Continue reading if the HDD is fine.
Then use the Sata Cable from another HDD and connect it straight to to the E Sata Enclosure and see if the Operating System picks it up,Make sure the HDD you removed is plugged back into the enclosure.If that doesn't work then the problem lies with the Enclosure itself and you should get it replaced.
If it does the the problem lies with the cable itself and you should replce that.
Hope this helps you out.
May 08, 2009 | ASUS P5QC Motherboard - Intel P45, Socket...
Acer eMachines 520-2890 Notebook Logo
18 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
