Question about Pioneer SD-582HD5 58" Rear Projection HDTV-Ready Television
2 fuses blow on power up
Hello - I have a SD-582HD5 Pioneer Rear Projection TV Monitor - it would not power up. So I looked at the back and fuses FU204 (5A/125V) and Fuse FU202 (6.3A/125V) blow out upon power up.
I called a repair service but the cost of repair is high. Is there a way to isolate the problem.
  • 790 Answers
Re: 2 fuses blow on power up
Good day sir! if you have knowledge in electronic trouble shooting, ican give an instructions to fixed this trouble!
But if you have no experience in electronic trouble shooting much better to call a qualified technician in this site near you! just type then go to find repairman.
Posted on Nov 15, 2007
  • 306 Answers
Its the power pack on the system board. It has a short in it and causes the fuses to blow.....if your farmilar with replacing it you can order the part though the manufacturer.
0 characters
3 Points
Still looking for help on Pioneer SD-582HD5 TV Monitor
hi you guys well this is a comon problem with pioneer most boards have lots of cold solder connections this will also make the symptoms like blown h-out mark all the connections on the powersupply board connections meaning all the wires you seethat connect to the board then remove the board from the tv this will make the repair more easy for you then look very close eventhough you might think that there is no broken connection there might be so go over this very carefully and slow make sure that you dont create any solder bridges after you have done his then you must go to the regulator cuircuit you might have some connections there ok now we are going to find the horizontal output transistor this guy is located neer the flyback transformer this (fly) sort for flybacktransformer is a big black looking transformer with a red wire comming out of it DANGER you are in the high freqency part of your tv pic tubs may store electricity this will make you think twice befor messing with tvs again ok this transistor is mounted to a large heat sink sometimes by it self check with vom meter in diode mode from collector to emitter then emitter to base if from collector to base reads short then it is bad if from collector to emitter it is bad the only short should be from emitter to base replce fuses and try again hope this helps
Nov 15, 2007 | Pioneer SD-582HD5 58" Rear Projection...
No picture on my pioneer TV model SD-582hd5
The problem is on lamp try to replace it to get back the picture..
Feb 23, 2012 | Pioneer SD-P55A3-K 55" Rear Projection...
If the sound keeps working your probably just need a new lamp, if the sound does not stay on, you probably to get someone to fix the power supply.
Sep 02, 2009 | Pioneer SD-582HD5 58" Rear Projection...
Pioneer sd-582hd5 shuts off while watching
internal components probably need to be cleaned.... sounds like a problem with t.v. overheating
Jul 11, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Pioneer SD-582HD5 Picture looks 3D with red and blue copies of images seperated on the screen..
Replace BOTH of your convergence ICs they are big black ICs will have part number on them if 110s use 180s.
Feb 18, 2009 | Pioneer SD-582HD5 58" Rear Projection...
Pioneer 58" SD-582HD5 1080i -Rear Proj TV
Like most problems with this model, check and re-solder the connections on the power supply board on the right rear of the tv, just behind where the main power cord goes in. Most problems are around the upper left corner where the white connectors E-12 and others. Check all of them from loose and cold solder solder connections on the board. Hope this helps.
Jun 02, 2008 | Pioneer SD-582HD5 58" Rear Projection...
How to open pioneer sd-582hd5
from back good luck most problems are cold solder connections and i some models you have to replace three small caps in the video circuit
Oct 31, 2007 | Pioneer SD-582HD5 58" Rear Projection...
Pioneer SD-582HD5 58" Rear Projection HDTV-Ready Television Logo
344 people viewed this question
Top Pioneer Projection Televisions Experts
Jaime Hernandez
Level 1 Expert
Are you a Pioneer Projection Television Expert? Answer questions, earn points and help others
