Kind of a problem if you can't get into your car. If you can t get into the car you can't pop the hood or disconnect the battery. Try to rotate the key in the lock in a sequence. On off three times in a row or 5 times in a row. Be ready if the car responds by locking and unlocking the power locks in response. when you hear the click quickly open the door .. Are you sure the battery in your remote isn't failing?
Call toyota
SOURCE: i have a grand voyager
dont go through all the hassles of removing the door trim just take the terminal off the battery for about a minute then reconect again worked on mine good luck
SOURCE: mercedes 1999 c200 key fob
Hello Haq!
Could it be the key just needs re-coding? maybe you are worrying to much as £177 would be about right as that would need coding etc., Try phoning your local Merc dealer or take the key and V5 to them for coding (Hopefully)
Good Luck!
Paul 'W'
Onyer~EDson(:0)~[><
SOURCE: 2005 dodge durango key fob
Hello and thank you for choosing fixya.com. I would suggest taking your vehicle to a local auto parts store and request to have a diagnosis done. (while auto stores vary, this is usually a free service and only takes a couple minutes to complete) to see if any codes are brought up. If so, the representative can tell you what the codes mean, and what needs replaced or repaired. Let them know of the situation. Even if no codes show up, ask them to clear the codes. If this does not work, do the following. 1: make sure that the batter in your key fob is inserted correctly, and that it is the correct size and type. 2. Disconnect the + Positive cable on your battery. This will reset your the vehicles computer. Maybe this will allow the vechile to code up with the fob. If not, I would take it to dealership, or backto an auto part store for further assitance.
I thank greatly for choosing fixya.com. I hope this information is useful to you and helps you get your fob working again. Let me know if you need further assistance, or have any questions or comments. Feel free to rate this information at your earliest convenience.
SOURCE: 2005 Chrysler Grand Voyager. Central locking
the body control module may need a software update..check with your local dealer
SOURCE: kia rio key fob power lock/alarm problem
if the lights flash when you hit the panic button but the horn does not beep, then the alarm horn is bad. Vehicle has a second horn just for the alarm
