Question about Zanussi Washing Machines
Turn on my jet system 1200 fj 1254w xc just makes clicking sound
Please help my machine was turned on this morning blue fuse in plug i changed fuse started again but machine just makes clicking sound then starts to bleep
    Master:
  • Zanussi Master
  • 489 Answers
Obviously appeared family error code E40 (visible to the customer) what means a problem with door interlock. Could be: door open (mechanical failure), door interlock malfunction, the problem with main PCB (triac) or wiring. In service mode you can see exactly error code: E41,E42,E43,E44 or E45.
Dado
Posted on Jun 09, 2015
  • 1294 Answers
SOURCE: zanussi jet system 1200
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Press "end of cycle" to finish the mid stoppage..
Rate me pl.....if helped.
Posted on Jan 02, 2008
Timon90
  • 126 Answers
SOURCE: Zanussi jetsystem 1200 XC leaking from underneath
Check the door below, it's pretty vulnerable.
Posted on Jan 25, 2008
dauphine
  • 207 Answers
SOURCE: just wont work
  1. Turn it off.
  2. Unplug it.
  3. Wait 5 or 10 minutes.
  4. Plug it in.
  5. Turn it on.
Posted on Apr 09, 2008
ginko
  • 19396 Answers
SOURCE: Aquarius 1200 WM64 - machine does not start
If you already replaced the fuse, next part to inspect is the control board behind the timer.
If that is ok, check the wiring harness, the socket and the power cord.
Posted on Feb 03, 2009
SOURCE: I have a Zanussi 1600 Jet System Washing Machine,
This error code relates to water pressure check that the pipes are not kinked,check the water valves are fully on also check if the little filters in the end of the hoses are cleaned.Make sure that the mains water pressure has not been reduced.There could still be a fault with one of the inlet valves but it is most probably the little gauze filters
Posted on May 04, 2010
2005 Harley Davidson XL 1200 R Sportster Roadster misses on takeoff
Hi, Stacey and the usual suspects are:
1. Throttle cables misaligned or misrouted.
2. Damaged or restricted fuel tank venting system.
3. Intake system air leak.
4. Vacuum piston malfunction.
5. Pinholes or torn diaphragm.
6. Accelerator pump leaking or no output.
7. Plugged bowl vent or overflow.
8. Fuel level in bowl too low.
9. Restricted fuel supply passages.
10. Plugged jets or passages.
11. Worn or damaged needle or needle jet.
12. The enrichner valve/choke not seated or leaking.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
Carburator Theory and Tuning
Harley Davidson 2005 Sportster Service Manual
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
http://mybikemanuals.com/harley-davidson/2005-harley-davidson-owners-manuals
Instant Tech Relief To speak to me personally absolutely "FREE"
Jul 16, 2017 | 2005 Harley Davidson XL 1200 R Sporster...
Aqualux whirlpool bath
The panel has failed and it is unlikely that it was your dogs fault.
Dec 02, 2013 | Washing Machines
Error on Zanussi Electrolux Jetsystem Turbo XC FJR 1254W
Your Washing Machine is starting to have more movement and is doing an Auto Stop, you need to get new mounts to get rid of the Excess Movement.
Apr 08, 2013 | Washing Machines
Fj 1200 float level
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Float height suggestion for 1986 Fj1200
Fj 1200 float level Google Search
Yamaha FJ1200 1984 1993 Best Service Repair Manual PDF Download Manuals...
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-fj-owners-manuals
Jan 19, 2013 | 1986 Yamaha FJ 1100
How to adjust idle on fj 1200
Hi, Anonymous the carburetor throttle shaft wheel has two cables the cable closest to the right side of the bike is the throttle cable and the one closest to the left side is the idle cable. Right about the middle between the two is the idle adjustment bolt it faces out towards the air filter end of the carb . The engine should be at operating temperature with the enrichener off to set the idle between 950-1050 rpm. Turn the idle adjustment bolt clockwise to increases idle speed and counterclockwise to decrease idle speed. If you have access to your air fuel mixture bolt you may adjust it as well if not there is a video below on how to gain access, make sure you start with clean or new spark plugs. Gently turn the air fuel mixture bolt clockwise until it starts to bottom out "STOP" do not over tighten as it will damage the taper on the end, now back it out 2 full turns to establish a starting point start the engine and check the idle rpm's and adjust the idle adjustment bolt accordingly for 950-1050 rpm if necessary, adjust the air fuel mixture bolt 1/4 turn at a time and let the engine settle for about 10 seconds, clockwise for a leaner mixture and counterclockwise for a richer mixture you are seeking the highest rpm your air fuel mixture bolt can acquire without going past 3 full turns from bottom then readjusting the idle adjustment bolt back down to 950-1050 rpm If you can not detect any rpm change and can not stall the engine by turning the air-fuel mixture bolt all the way in then your pilot/low-speed jet is too big. Final adjustment should be made with a clean air filter mounted to the carburetor. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
FUEL MIXTURE SCREW ADJUSTMENT PROCEDURE
Carb tunning
Yamaha 1992 FJ1200 Service Manual
Nov 16, 2012 | Yamaha Motorcycles
How do i change oil and filter on yamaha FJ1100?
Hi, M_martino13 for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $10 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://meiguohosting.com/how-to-change-the-1986-Yamaha-FJ1100-motorcycle-s-oil-in-its-engine
Yamaha FJ1100 1200 easy install oil filter spin on adapter easy to install
Yamaha FJ1100 1984 1993 Best Service Repair Manual PDF Download Manuals... $10
Jul 05, 2011 | 1985 Yamaha FJ 1100
1989 Yamaha fj1200 will not start
Hi, Passin77 and the usual suspects are:
1. Fuel tank empty.
2. The fuel tank has old dead gas.
3. Fuel tank bottom contaminated with ethanol sludge, dirt, water, rust, etc.
4. Fuel supply valve/petcock turned off.
5. Fouled spark plugs.
6. Engine flooded as a result of overuse of the enrichner.
7. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
8. Fuel valve/petcock or filter clogged.
9. Fuel line to carburetor or throttle body pinched, kinked or blocked.
10. Carburetor float stuck.
11. Fuel injectors clogged.
12. Fuel injectors stuck open.
13. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a cursory reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead acid batteries.
14. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
15. Loose or corroded wire connection at the coil or plug between ignition sensor and ECM module.
16. Spark plug cables in bad condition and shorting check for spark leakage in the dark, cable connections loose, or connected to the wrong cylinders.
17. Ignition timing incorrect due to a faulty ignition coil, ignition module or MAP, CMP, CKP, O2, TPS, ETP, IAC sensors.
18. Faulty neutral, clutch lever, or kickstand safety switch.
19. Faulty fuel pump or fuse or relay.
20. A stuck bent or burnt valve.
21. Tilt sensor needs a reset.
22. Security system not disarming alarm needs a reset.
23. Check for engine trouble codes.
FJ 1200 STARTING PROBLEMS
What to do When Your Motorcycle Won Start
Yamaha FJ1200 1984 1993 Workshop Service Repair Manual Download Manuals... $10
Jun 02, 2011 | 1986 Yamaha FJ 1100
I have a yamaha gladiator ss purchased on 1 june 2009. My bike makes a very hollow and loud sound and has poor pick up as compared to other gladiators, also its not at all smooth to drive. It behaves like...
Hi, Gaurav and the usual suspects are:
Idle problem in Yamaha Gladiator Team BHP
http://www.xbhp.com/talkies/help-me/23140-yamaha-gladiator-rs-2008-not-performing-top-end.html
Yamaha Motorcycle repair manuals
YAMAHA GLADIATOR Ower Manual
May 19, 2017 | 2008 Yamaha Gladiator SS
Water in the fabric softner compartment after wash cycle
You need to poke all the holes clear in the top of the dispenser housing with a piece of wire or similar.
This should solve the problem.
Dec 15, 2009 | Washing Machines
Jan 19, 2008 | Washing Machines
Washing Machines Logo
114 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
