Question about GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave turns itself off after a few seconds
We have a GE spacemaker microwave that is 3 years old. When we try to cook something it shuts off after a couple seconds.
  • GE Master
  • 9,098 Answers
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again. If that doesn't work, leave it unplugged for about 5 minutes.
Otherwise, I would suspect a "noisy" failing magnetron.
NOISY MAGNETRON TEST (c) 2009 William E. Miller prototech@usa.net
One way to test it is to do the following:
1. Unplug the microwave or turn off its breaker.
2. Open the door, then detach the control panel as shown in the video at http://www.microwavedisplay.com and swing it down, but without disconnecting the wires. If you have any trouble getting the grille off once the screws are removed, slide the hood vent grille to the left about 1/4", then then pull it forward. On some models there are L-shaped clips that fit into a slot to hold bottom of the vent.
3. Plug the microwave back in.
4. Make sure neither you nor anyone else reaches in behind the control panel. There will exposed high-voltage connections.
5. Put a few cups worth of water in a microwave-safe container and place it inside the microwave.
6. Shut the door.
7. Run the microwave for about 1 minute or so on full power. (Time Cook > 1 > 0 > 0 > Start, e.g.)
8. If it does not fail, try it several more times.
9. When the water boils, change the water and try again.
NOTE:
If your model does not have a door handle, you will need to unplug the oven and reattach the control panel to be able to open the door.
If it still does not fail, I would recommend that you put it all back together and keep using it until it fails more consistently, then repeat this test.
While a microwave should never be left running unattended under any circumstances (as your owner's manual will tell you) it's even more important when one is exhibiting a failure or any odd behavior. So play it safe and stay with it while it's running!
If you or someone you know want to replace the magnetron yourself, you will need to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
Sometimes they will send you the magnetron to do it yourself. Call them at 888-239-6832.
Be persistent. You may have to speak with a supervisor.
If it is not within the magnetron warranty, you can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jul 13, 2009
Ge spacemaker jvm1650sh01 starts to microwave then loses power
See this FixYa solution.
May 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave powers off after few seconds of working
Hello :
This could happen because of a bad keypad . Just replace it and problem will be solved . I need you to think before replacing it . Because sometimes a new unit is better than repairing . Think it before !
good luck .
please rate !
Apr 01, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker microwave oven - Sensor error
Hello :
Many models of the GE microwave have sensors that can detect humidity from the foods you are cooking. This allows the microwave to make adjustments to the power levels used to cook your food. If "Sensor Error" appears, you should either press "Clear" to cancel the mode or leave the food in the appliance longer to give the microwave more time to detect the food.
Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect
good luck .
please rate !
Mar 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My ge over the range spacemaker microwave keeps blowing fuses after a few seconds cook time. This is my second unit within a year and a half with the same problem. Would not recommend this product.
Buy a Microwave Oven after checking it out on http://www.cnet.com .They do a wonderful job rating different products. Check them out and type the product name you are looking for in the search box if not already listed.
Mar 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker model #JVM1650CH01 that keeps on shutting off everything after a few seconds. I have to rest the clock and month -year - date to try again.
my spacemaker xl jvm 1650 microwave shuts down after just a few minutes of operation and after a few minutes needs to have a clock/time/day etc reset. is this reparable by a homeowner?
Oct 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Touch control failed on GE Spacemaker Microwave HVM1540
If you want to order a touch pad, (it has the micro computer built in it!) and fix it that way, you'll still have a 2-3 year old machine.
I would say it would be quicker and cheaper to buy a new one.
Jun 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver XL 1650 microwave shuts off after a few seconds
this would be the digital control board that would need to be replaced
Nov 27, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Panasonic Microwave Problem
Even though these are different symptoms, the same part may be causing both.
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Sep 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
941 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
