Question about Mitsubishi WT-42311 42" Rear Projection Television
TV Won't Stay On...
My Mitsubishi projection TV worked fine, then shut off and when I attempt to turn it on, the light comes on for about 3 seconds and shuts itself off, without sound or picture. I tried pressing the menu and input buttons simultaneously but nothing changed. Please advise...
  • 26 more comments
  • Anonymous Nov 20, 2007
    also, .v. will not turn on. Green indicator light stays on for fivish seconds. When menu and input buttons are pushed tv indicator light flashes 22 times or 2 quick flashes ten times (same thing) What could the problem be?
    whats up??
  • Anonymous Nov 30, 2007
    Will not power up - green "on" light comes on for approx 3 seconds then goes off.
  • Pretty Lady Dec 17, 2007
    I have the same trouble & error code on a Mitsubishi VS-50111. The WT-42311 is a model number that is mentioned on my owner's manual so I'm hoping the solution is the same. Some have said the Capacitors are bad & others say it is the Convergence Chips (IC's) that are shot. I'm so confused!!
  • shiv_101 Dec 28, 2007
    my wt-42311 wont stay on...comes on (with green light) and goes off in about 5 seconds? Any guesses as to what is going on here and how to fix? thankx
  • nibbox Feb 15, 2008
    where are the fuses located?
  • neonicty Feb 15, 2008
    I have the exact same problem with the power on for a few seconds and then turns itself off. No sound, no picture. Also, the control buttons on the tv are disable for no apparent reasons. Any help is appreciated.
    have the same problem. Where are the fuses?
  • tammieb Feb 17, 2008
    i have a mitsubshi projection 60" and when you turn on it goes right out no sound or nthing all of the sudden what up with that? help i miss my tv model 005958
  • jayb76 Mar 11, 2008
    where are the fuses...
  • danwithnotv May 07, 2008
    I have a mitsubishi wt-42311 and you turn on the tv the green light comes on about 3-5 seconds and turns it self off. there is no picture or sound. I this ty worth repairing?
    danwithno tv man
  • kenny n May 20, 2008
    i have the same prom.
  • abinadab3 Jul 07, 2008
    mits tv wt42311 wont come on
  • Anonymous Jul 12, 2008
    my mitsubishi tv model wt42311 won't stay on when I hit the power picture no sound just black screen for a few seconds then turns off.. I tried av reset, did not respond also unplugged set for 1 hr. still same problem... please help if you can
  • Anonymous Jul 17, 2008
    i was told to change the pico fuse?
  • beighley101 Jul 19, 2008
  • Anonymous Jul 24, 2008
    Ditto: turn on, power light comes for 2 seconds and goes off. Tv is 5yrs 4months old. Also...About 2 months ago, once in a while the colors split so bad you see 3 people instead of one [all in seperate colors], turn off tv and back on then picture is OK.
  • john73160 Aug 05, 2008
    Having the same issue, but I'm having difficulty finding the power supply board or the pico fuses without a service manual.
    Can somebody please provide a manual/guiode/instructions on how to access the power supply board and the pico fuse(s) ???
  • gizmogirl Oct 01, 2008
    I have the same issue with the same TV- mine is 5 yrs 4mo old. I find it interesting that all the issues are occuring after the 5 yr mark....
  • Anonymous Oct 03, 2008
    I have the exact same problem. Is there a manual to show me how to locate and fix the bad component?
    What all will I need for tools and how difficult will it be to fix myself?
  • digital-grl Oct 06, 2008
    This is so crazy! My WT-A42 does the same problem. Since I'm not a repair-type person, I hope to find someone to fix it without costing too much.
    Thanks for all the info!
  • Anonymous Oct 12, 2008
    I have the same problem. Where are the fuses located?
  • jfritts Nov 07, 2008
    Mine started w/ the green light and the few second thing. Now nothing... Just hear a click when I try and turn it on.
  • sandrabowlin Nov 08, 2008
    I have the same problem as gdc1964's can you give me a solution. Thank You
  • MPGERM2 Dec 03, 2008
    Same problem as described above. The first time the repairman replaced the "voltage regulator" for $170 and then had the same problem again in 2 months. He came back in and "adjusted" the voltage regulator. 6 months later I had the same problem....I'm calling a new repairman.
  • bradwiser Jan 10, 2009
    does the fuse have to soldered in to be replaced?
  • kenseelow Jan 10, 2009
    same problem, mitsubishi tv model wt42311 won't stay on when I hit the power picture no sound just black screen for a few seconds then turns off.
  • dmccart Jan 14, 2009
    5yrs and 6 months here..same problem..get the green light on and it goes right off.
  • stevenvanryn May 11, 2010
    I have a Sharp television. I've had it for 14 years with no problem what so ever. For the past week I have been experiencing a problem with the inputs. The tv will always be on input 1(one), but it has been flipping through all the inputs and is getting to be very annoying. Whether we watch tv live or if we are watching Tvo, it still does it. I called Direct TV and they said it wasn't their problem, and that it was the tv itself. I've checked all the cables in the back of the tv and they are all secure. What can be causing this problem?
Same problem, same solution. Small green pico fuse on the power supply board. There is a sticker inside the back cover with the layout of the fuses on the board. Check them all, one of the 5A125V is bad on mine. I have the board out, now I just need to locate a replacement and someone with the skill to solder it in for me. Thanks for the help...hopefully this saves me thousands on a new TV. I bought this TV five years and one month ago to the day. Guess when the extended warranty ran out...a month ago today.
Posted on Jul 19, 2008
Small green pico fuses repair turn off problem
Posted on May 10, 2008
I found a blown fuse in the circuit board 5amp125volt.
replaced and the tv works as it did before.
Posted on Feb 06, 2008
Mine did the exact same thing after I turned it on and turned off too fast. Checked all the fuses with a multimeter and found a bad one. soldered in a new one and works perfect now. $7 fix with a few minutes of my labor. I got lucky that it wasn't something particular that blew the fuse but that is a good place to start
Hope this helps.
Posted on Dec 21, 2007
I had a service some out and they replaced the amps and the TV has worked fine since then....
Posted on Nov 27, 2007
  • 3,130 Answers
Fuse do not blow for no reason, th reason thy are blowing is he convrgence iC"s are going bad.
Posted on Aug 16, 2008
2 Suggested Answers
  • 790 Answers
SOURCE: TV Doesn't stay on...
base in your comments in your TV you have defective power oscillation circuit! and need to diagnose your TV with a qualified technician! now if you have knowlegde in electronic trouble shooting i can give you the method to fixed your TV. Thanks in Advance!!!
Posted on Nov 15, 2007
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
I have a Mitsubishi TV model WS-48511 it was working fine, I shut it off came back a few hours later & when I turn it on the green light will come on for about 3 seconds but turns back off. What can I...
Unplug it from the wall for about 5 minutes.
with it unplugged, Press and hold the power button for around 30 seconds.
This should discharge the unit and allow it to come back on.
Jul 02, 2011 | Mitsubishi WS48511 48" Rear Projection...
The lamp went out in my TV. I replaced the lamp and it worked fine. I moved the TV and when I went to turn it on it wouldn't stay on. It will come on for about 10 seconds and then shut back off. The red...
Recheck all the projection lamp conections again.Still getting,the same result.Replace the projection lamp again,some how the move,it got the projection lamp shorted.
Oct 03, 2010 | Mitsubishi WD-60735 Projection Television
Mitsubishi VS-50111 Tv does not stay on.Turn Tv on and shuts off after a few seconds.
Aug 06, 2010 | Mitsubishi VS-50111 50" Rear Projection...
Tv does not stay on
If you have a rear projection, it is the bulb. Ypou need to replace it.
Jul 24, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi 50inch TV Turns off right after I turn it on
tv is in shut down.could be several a repairman.
May 10, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Tv won't stay on
2 of 3 circuit boards in your Mits can give your symptom...
1)Center power supply board = open fuse & bad IC's
2)HV scan board defective.....
A qualified Mits tech with parts in stock can fix it.......T.
Dec 13, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi WT-42311 42" Rear Projection Television Logo
1,529 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
