Question about GE Spacemaker JVM1640SJ Microwave Oven
Lights permanenly ON
I had to remove one of the under the cabinet light sockets to replace. Now the lights are permanently on and I cannot turn them off with the touch pad. Any ideas?
    Problem Solver:
  • 11 Answers
I had the same problem today. Burned out lamp burst in my hand with a "pop" when I went to replace it. The new bulb now stays on all of the time. I am adamantly opposed to paying for a repair ($40) or a replacement (+$100) controller board. Why didn't the manufacturer design a circuit that would not fail when the lamps were replaced? So, I'm bypassing the switch and installing a separate toggle switch to turn the lamps on and off. If I could retrofit the unit for a standard light bulb I would do that as well. These little lamps it uses are $4 each - ouch!
Posted on Jul 25, 2009
  • GE Master
  • 9,149 Answers
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation or inside light, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jul 13, 2009
This is an over the stove microwave. Need help replacing the light bulbs on the bottom of the microwave.
Disconnect the power and get a flat bladed screw driver to remove some of the bulb base away from the socket. Insert long nose pliers into the area created and turn base counterclockwise to remove.
Nov 21, 2015 | Microwave Ovens
Ge lvm1750dm1ww microwave
<-- I see and repair this problem on a regular basis. Details are here.
This failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line, as the warning label near the light socket advises.
This causes a failure on the control circuit board.
The lights can can be inoperable, or stuck on, or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
You can get it your smart board repaired or order a replacement part number WB27X10935 here.
Whether you choose repair or replacement, the first step is to remove the controller assembly.
Here
is a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Next, disconnect the strip as shown in the photo below, then remove the screws that hold your circuit board in the old frame.
Then carefully (since the display is made of glass) move your circuit board to the new frame, and reassembly is the reverse of disassembly.
If you choose repair, do not disconnect the keypad connector and do not remove the board screws. Leave the controller assembly intact.
Feb 16, 2014 | Microwave Ovens
How to replace burned out light bulb
You need to remove the top cover to access the bulb. That is the only way on most microwaves.
Dec 02, 2011 | Emerson MW8107WA Microwave Oven
Lights under microwave went out. Replaced the bulbs and bulbs work fine, however, now the "surface light button" will not work. Pushing the button will not turn off the lights. Lights continuously stay on...
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
William E. Miller
prototech@usa.net
Apr 26, 2010 | GE JVM1653 Microwave Oven
It sparks, lights up from the inside when turned on - it is 5 yrs old should I replace it?
this would indicate a failing magnetron,the magnetron should still be under warranty and should be replace by a service tech,to also determine if the cabinet has suffered any damage.
If nothing is covered under warranty the it is usually cheaper to go by a new microwave
Feb 23, 2010 | Microwave Ovens
Need new light bulb socket for GE spacemaker mircrowave
The bulbs are glued in at the factory. Unplug the microwave and see if you can remove the base of the bulb from the socket with needle nose pliers. You may have to twist the heck out of the bulb base but it should come out. If you do need a new socket it is available at www.geappliances.com under parts and accessories. Or call 1-800-626-2002 for GE factory parts
Dec 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Ge Eterna Model Em0300 HBB01 under neath light
Please unplug the oven first!
This is pretty common and can be a pain. It's tacked in place with hot glue, and sometimes there may have been enough moisture to corrode and seize up.
You could heat it up (hair dryer, maybe?) then use needle nose pliers. Be careful if heating so you don't burn anything.
You may be able to put the tips of needle nose pliers inside the broken bulb's socket, gently but firmly force the pliers jaws apart and then rotate the pliers to loosen it.
Another cool trick is to put a big glob of hot glue on the end of a stick or dowel, then shove it into the broken base and let it cool about 5 minutes, then turn the stick.
I like to put a little WD-40 or rust buster on the threads of the new bulb, too. Grease, Vaseline, cooking oil, or anything like that will work. Just a thin coat.
Once you get new bulbs in it, please let me know if you the lights are still not working. This is usually a problem on the control board that can be easily repaired.
Sep 07, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable, lights and fan inop
sounds like a cross wire, and a short. I'd inspect the socket for the bulbs to ensure that there's no short circuit.
Feb 11, 2008 | Magic Chef CMV1000B Microwave Oven
I'm guessing that nothing is working...is that right? If so, first guess is the breaker or an internal fuse. Nearly all units have them. You don't say what fuse you checked. Unplug the unit, remove the bulb and see what is in the socket. Next, open the breaker and then turn it back on. This will reset it. Something caused this.
Dec 19, 2007 | Magic Chef CMV1000B Microwave Oven
Roper mw under cabinet light
You probably need to have the receptacle replaced that the bulb screws into
Oct 29, 2007 | Roper MHE14XKB Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
73 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
