Question about General Electric Microwave Oven
Microwave model # JES1146BF001 is giving me a F3 error. What is this telling me?
  • William Miller
    William Miller May 11, 2010
    F3 on a GE / Hotpoint
    microwave means you have a shorted membrane keypad.
    If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
    So until it is repaired,
    please leave it unplugged or leave the door
    open when it's not in use, and please do not leave it running
    unattended.
    GE has not yet made a parts list available for this model, so it may be an "exchange only" warranty.
    If it's out of warranty, the oven would have to be replaced.
    You can download GE
    owner's manuals and installation instructions here to find out about the warranty.
    GE Customer Service is here.
    Good luck.
    We're
    happy to help you with free advice and we'd appreciate your
    thoughtful rating of our answer.
MicrowaveSvc
  • 9156 Answers
SOURCE: GE Sensor Microwave model JES1456wf001 error code
Unfortunately, it appears that GE did not make that model to be repaired.
According to the owner's manual, there is a one year warranty.
After that, GE offers no support for it, but they sometimes make exception is people raise heck with Customer Service.
Good luck.
Posted on Sep 14, 2009
  • 42 Answers
SOURCE: The oven doesn't work. Gives an F2/F3 error. This
f3 code temp sensor circuit bad ,f2 oven temp higher 500 degrees
Posted on Mar 27, 2009
  • 178 Answers
SOURCE: GE Sensor Microwave model JES1456wf001 error code F3....how do we
F3 is a shorted key pad. To prove this, unplug the ribbon cable of the key pad from the control board and this symptom should go away when you plug the AC cord back into the wall. BE CAREFUL!!!
espressonist
  • 1711 Answers
SOURCE: ge microwave jvm 1430 error code F3
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Posted on Nov 04, 2010
espressonist
  • 1711 Answers
SOURCE: ge psacemaker microwave oven no working it started
F3
pad).
Posted on Dec 26, 2010
Microwave is showing F3 what is wrong?
What make and model of microwave is it?
The error message F3 can be searched using http://www.google.com
Google
May 15, 2018 | Microwave Ovens
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Ge psacemaker microwave oven no working it started with a sensor error and the message change to F3 and beeping. I unplug and plug its still same error.Model JVM1750. What does F3 message stands for?
F3
pad).
Dec 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave oven stop working. buttons will not work and an error code F3 come up on display. Could you tell me what this could be?
F3 is a shorted key you need a new keypad control panel. For the JE2160 series countertop model this should be the part#WB27X10681
Dec 06, 2010 | GE JE2160 Microwave Oven
GE Sensor Microwave model JES1456wf001 error code F3....how do we fix . Microwave comes on when plugged in and then reads to set clock and then it rings several times and we get an F3 code
Sep 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave jvm 1430 error code F3
Jul 17, 2009 | GE JVM1430 Microwave Oven
Spacemaker Microwave Oven
F3 means shorted key panel. You get prompted with F3 error if a short on key panel is detected for over 60 seconds.
Test key panel wiring and eventually replace key panel.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 17, 2009 | GE Spacemaker JVM1750 Microwave Oven
General Electric Microwave Oven Logo
387 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
