PerfectAire 18000BTU Window Air-Conditioner, PAC18000 Logo
c
charles coursey Posted on Jun 06, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lost remote how do I change thermostat setting button works for timer but not for thermostat
jack morton
Level 3:
Master:
  • Master 523 Answers
  • Posted on Jun 07, 2015
jack morton
Master
Level 3:
Master:
Answers
523
Questions
14
Helped
255583
Points
1290
No way to do that. You will need your model & serial # from the indoor unit and locate one online through the manufacturer.
How do I fix a thermostat that appears to have lost its programming?
Have you changed the battery?
usually the battery compartment (and the model number) on located on back of thermostat
Look up manual on internet
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Is the sunvic sp2 a 2channel timer please
Yes. It appears the Sunvix SP2 is 2-channel timer.
http://www.sunvic.co.uk/documentation/Programmer_Select_207.pdf
Two-channel means CH central heat and WH water heater can be programmed separately, and each can have its own timing program.
pg 3
The timer offers pre-programmed options for both CH and WH, which can be used, or program your own schedule. chart pg 5 and steps pg 3
Limitations: both channels operate on same clock time, and dip switch setting. pg 6. So the WH cannot be programmed for 5-2 weekdays-weekends and CH programmed for 24 hour.
As a convenience for varied work schedules, Sometimes people use the 5-2 weekday-weekend option so 2 days of week can have different programming, and then fudge current day setting during the set-current-time step pg2 so the 'weekend days' are actually moved to wedsday-thursday instead of sat-sun.
Option: both CH and WH timer programs can be linked and follow same programming by using copy button. pg 5
Using advance button on either side of timer, pg 3-4, WH and CH timing schedules can be overridden temporarily until next set point is reached. Then regular programming automatically resumes.
If override or Advance button is pushed for either CH or WH, it reverses whatever programming is in effect. On becomes off, or off becomes on. However if CH thermostat is satisfied and room temperature has not fallen below thermostat set point, then override will not turn CH on, but override will turn CH off. Same for WH override: If cylinder thermostat is satisfied with internal water temperature, the water heater will not turn on and heat more water, but the override can turn water cylinder off.
Unit requires Cr2033 lithium button battery. Pg 6. Probably lasts 3-5 years. Programming is protected for 30 days from power outage.
If programming is lost, change battery, the reset timer and reprogram to restore functionality.
1helpful
I have a Mitsubishi WD-52725 DLP TV and green light (timer) is rapidly blinking after a power outage and set will not turn on. The bulb was replaced a month ago and it has worked fine since. Now it will...
Hello
make a System Reset process. To do this;
If the TV will not respond to either the remote control or the front panel controls and/or will not power Off, press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may again turn on the TV. The changes you made the last time the TV was on before you used the SYSTEM RESET button may be lost, however, the changes that were previously saved are not lost.
OK.
How do you set on and off mode on air conditioning
Use the remote to enter the timer to switch off - OFF timer setting and the On timing after setting the clock on the remote
Once this is presetted the unit will continue to work shut of in the thermostat settings and fully cuts off power in the set off time.
later the set will come back in the set on time and work till the thermostat setting is reached.
29helpful
4answers
E44W46LCD Lamp Timer Reset
To reset the lamp timer, hold the "enter" button on the tv and the "mute" button on the remote at the same time. Once the menu pops up, hit the right arrow on the remote and confirm the reset.
I would guess that's it's a little too late for this answer now, but for future reference... ;-)
6helpful
3answers
Cant get the Unit to respond to the remote control
My remote won't work. It will work once, maybe twice and then no response from it. New batteries, haven't dropped it, etc.. HELP !!
1helpful
2answers
Our TH8000 Series Programmable Thermostat keeps flashing "change filter" even after we changed it. The guide book does not show how to re-set so the flashing stops.
try holding the filter button in for three seconds, if that doesn't reset the timer try the filter button and the temp. up button at the same time for three seconds.
3answers
2helpful
Program timer light blinking
The timer light blinks when the AC power has been disconnected and the clock is not set. This is how the set warns you that it can no longer do timer recordings. Setting the clock and doing an autoprogram will fix it, but both the remote and the remote receiver must be working. If the original remote is not damaged and has good batteries in it but does not work on that set and you cannot get any other universal remote to work, then the remote receiver (the IR "eye") inside the set has failed and needs to be replaced. I have seen many of those little receivers failing recently. If you do not have experience changing electronic parts on small PC boards then have a qualified tech change it for you.
Top PerfectAire Heating & Cooling Experts
Paul Carew
john h
Are you a PerfectAire Heating and Cooling Expert? Answer questions, earn points and help others
