I have a large round dot of incorrect color inside another on my screen. Is the CRT blown and is it worth fixing?
    Sniper:
  • 60 Answers
If it is appering after switching off set crt may be faulty
Posted on Jul 12, 2009
TV cut off. Little red dot on black screen. Sharp 20f - m100 model
This is a common problem. If you are handy with a soldering iron you can fix it yourself. There is a thermo detection capacitor (round) on the main circuit board that has to be replaced. Use a low wattage soldering iron (25Watt)and electronics solder. If you aren't familiar with electronics soldering; then it's best to replace the set... repairers will charge you more than the set is worth to replace the $5 part and you can buy better ones these days. It is best to NOT wall mount these types of sets as they often overheat and fail.
Jul 08, 2015 | Sharp Televison & Video
I have black & white dots on the tv screen.. What causes this and how can it be fixed?
Hello... you know it looks like its the DMD BOARD.
if the dots are really rounded and all over the screen the answer it's yes the DMD.
if you what to do it yourself its easy!
here is a link to a web site bout first you need to take out your dmd and check the part number and that is inside.
be very careful
this link is not the part. its just a website you need your part number and type it
http://www.discount-merchant.com/1070535-HD61LPW42-p/1070535.htm
good luck hope i was help full
Jan 21, 2010 | Samsung DLP HL-P5663W 56" TV
Bad color
If it is a glass crt then you need to have the set demagnatized with a demagnatizing coil. All tv shops have one. This is worth fixing and usually at the price of a service call.
Mar 15, 2008 | Panasonic CT-32SX12 32" TV
Sony Trinitron Color Rainbow
Usually when a tv is dropped the phospher screen inside the picture tube will detatch making the rainbow color This cannot be fixed as it requires changing the picture tube. Only other thing is demagnatize it with a demagnitizing coil (used by tv techs) but not likely to fix it since it was dropped. You have a bad picture tube.
Dec 30, 2007 | Sony KV-32FS13 TV
TV repair
hi there, yes it is worth fixing for a 32 inch tv. , check up the connection inside and some loose connection or some cold solder. do some cleaning and check up. ty
Dec 29, 2007 | Philips 32PW6006 32" TV
TV making clicking sounds
if you had good color yes it is worth fixing sounds like your fly back trans former may be out see if you have any blown fusesif so get back tome for more help
Nov 02, 2007 | Sanyo DS31520 31" TV
COLOR
damaged shadow mask inside CRT==not worth fixing!
Sep 25, 2007 | Panasonic CT-35G25 TV
Panasonic Color Rings
It sounds like you have a warped shadow mask in your picture tube if your set uses a picture tube. A shadow mask is like a screen wire that lets the three color guns shoot electrons to their respective phosphor dot on the screen to produce the three primary colors which are mixed properly to produce the scene that is being shown. In other words you have a bad picture tube. Stargazer
Aug 12, 2007 | Panasonic CT-27SF37 27" TV
Red screen
Christ, why did you disturb the bias settings? Which stupid @#$% told you to that? The red color was most likely a blown Red Output Transistor, or something as simple as a bad CRT base. Now, I suggest that you switch off the TV, wait for a couple of hours, open the set, and very slowly and carefully pull the CRT PCB (along with sockets base. Then clean the CRT terminals (use a fine emery sheet.) Also check the base for dry (cold) solders. Replace the CRT board. Picture should be normal. If problem persits, then it is definitely the Red Output Transistor or associated components. Get a professional to have a look.
Aug 23, 2006 | RCA F27628 27" TV
Focus good in centre but fuzzy around edges
If you have some electronics experience, is it with TV'S?? There is way to much Hi Voltage inside these sets to be tweeking around as this set will have to be plugged in and running when you do the a grey scale alighnment and color drive alighnment. If the pic is out of focus on the outside its probably like you said not wrth a techs time unless you wanna pay a min. bench charge to clean the grids inside the CRT with a speacial piece of test equipment. As a handy man its not a good idea to service these sets as there are no user serviceable parts inside+. Good Luck
Jun 20, 2006 | Sanyo DS27910 27" TV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
