Question about Metra Tsunami 1.2 Farad Capacitor
I was given a tsunami 1.2 farad digital capacitor with no installation info or charging info. which side of the cap is the positive if you are looking at the front with the digital readout?
2 Suggested Answers
  • 8 Answers
SOURCE: need wiring diagram for tsunami
After a bit of searching I found the instruction manual:
http://a248.e.akamai.net/pix.crutchfield.com/manuals/120/120pp912u.pdf
Hope it helps.
Posted on Mar 05, 2011
What are the causes of tsunami
Usually caused by an under sea earthquake.
Check out this WEB site for details.
http://wiki.answers.com/Q/What_causes_a_tsunami
Feb 14, 2013 | Tsunami Lite Wave Capacitor 2.0-farad with...
Need wiring diagram for tsunami 1.2 farad capacitor cap.
Hope it helps.
Mar 05, 2011 | Metra Tsunami 1.2 Farad Capacitor
For some reason my capacitor wont charge, I've checked everything! I just bought a boss cap3.5b and I know for sure the fuse is working there is power coming from the battery and the cap is grounded...
get a small led or something that runs on 12 volts. i use my 5 dollar 12v test light and hold it to the positive cable thats gonna be hooked to my cap.
hook the other side to the cap, it will light up the test light and in a minute or two the light dims and then goes out, after its out , the cap is charged......JUST DONT LET IT TOUCH THE OPPOSITE WIRE WHEN YOU HOOK IT UP OR YOU DISCHARGE IT and its not funny
Jul 31, 2010 | BOSS AUDIO CAP3-5B 3.5 FARAD CAPACITOR,...
Hey i had 2 car amps +for 4 speakers(140W maxi) and a sub 12inch
1 cap, either .5, 1 or 1.5 farad will be fine. they make 5 10 and 20 farad that cost way more than u need to spend for 400 watts RMS. i like the rockford fosgates, you can get a low cost Tsunami, just make sure you follow the charging instructions.
Oct 20, 2009 | Car Audio & Video
35 Farad hybrid power capacitor not charging like instructed in manual, tryed charging the cap throgh the supplyed resistor "2watt/10ohm" between power cable and cap.But nothing happens seems like it dosnt...
Yes you certainly wire the 12v+ wire directly to the positive post of the stiffening Capacitor, however if you have a one of those test light probes to check for current on a car? They are really cheap but what i do is clamp the one end on to the battery and than touch the probe to the + teriminal of your capacitor, when the light goes out your cap is fully charged. Now if the light does not go all the way out or stays on you have a bad capacitor, and might i ask why the hell are you driving to need a 35 Farad Capacitor anyway?? Damn.. We do show and competition cars here and sometimes use them. I like the BatCap way better, it's a Battery and a Capacitor all in one. Way strong like bull..... good luck... Mark
Aug 14, 2009 | Boss Audio CAP10 10 Farad Digital...
Need installation advice
All caps are designed to be wired in parallel with another cap if desired. The three openings work to daisychain caps, positive to positive and neg to neg, the third connects to ground on the negative side and 12v+ on positive. You do not want to ground multipule caps individually. You can add as many caps as you can afford!
May 05, 2009 | Car Audio & Video
1 amp cuts off
i had this same prob. & i run 2 amps as well, cameto find out i had a neg. & positive touching , so check all ur wiring for tht amp..
Apr 01, 2009 | Kenwood KAC-9102D Car Audio Amplifier
I was given a tsuname 2 farad
It doesn't matter...Just make sure your negative and positive terminal hookeups are correct. (as in, don't connect a positive wire to a negative terminal).
Mar 22, 2009 | Tsunami Lite Wave Capacitor 2.0-farad with...
I have a Rockford Fosgate 1 Farad capacitor, power cap how do i wire it in to my car. i know one side is what about the other side is it or -
hi there installing a capacitor is at your own risk as they charge up and hold a lot of power if hooked up wrong can give you the shock of your life and blow your sterio and computers to bits i learnt my lesson any way remember to take off positve before installing here is a diagram how to install it,,,, ok the positive goes to the battery and the amp on one side and the other to ground .....take a look at this easy to use diagram i found for you hope all goes well http://www.caraudiohelp.com/images/car_audio_capacitor_installation.gif
Jun 30, 2008 | Rockford Fosgate Car Audio & Video
Metra Tsunami 1.2 Farad Capacitor Logo
159 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
80stech
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
