Call Service Konica Minolta 7145 Error F-35-1 what to do and how to fix it
    Problem Solver:
  • 17 Answers
Press 25 togehter and power on your machine you will see another screen press software switches 3-0 make it off .off main power and on it again
Posted on Jul 11, 2009
Konica 7145 say PM fixing unit (Web) won't copy but will print
have tech come out and replace the web roller above the fuser unit, and clear the counter after install. THAT IS LEGACY MACHINE google for the web roller
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 10, 2017 | Konica Minolta Konica 7145 Minolta Bizhub...
How to remove minolta 7135 code E 56-1
replace the image control board, all check all connection to printed circuit board remove each connector seperately and check for a bent pin
Oct 11, 2016 | Konica Minolta Office Equipment & Supplies
How do i fix my copier konica code f-35-3
Power off the machine. Then holding down the 2 and the 5. Power on the machine. When the screen comes on your in Mode 25. Locate soft switch. In the first box you will put a 3, second box put 1, change the third box from 1 to 0. Then power off. Power on if the code comes back your fusing unit (The Hot Part has issues) Do not reset again your resetting the fuser code. The fuser could catch on fire, that would ruin a perfectly good day.
Mar 06, 2015 | Konica Minolta Office Equipment & Supplies
Konica 7145
fuser code hot part replace it
Apr 13, 2014 | Konica Minolta Konica 7145 Minolta Bizhub...
I just ask my copier to try to enlarge past 200%, had really little type on the original. It says "call service" code F-35-1. I work from home and need help to clear out this message. Please...
Fuser error, here is the reset procedure.
Set SW2 (sub power switch) OFF and then back ON, after set to "0" the bit 1 in DIP SW3 in 25 mode. (If you switch power back on without releasing the latch, the error will recur.).
Hope helps.
Sep 02, 2011 | Konica Minolta Office Equipment & Supplies
What are codes F-34 and F-35?
These are heat sensor abnormality error codes in Konica Minolta 7222/7145/7135/7235/7228 models.You did not mention the model.
Oct 04, 2010 | Konica Minolta Bizhub C300 All-In-One...
I HAVE A KONICA 7145 COPIER ANND HAVE THE E-56-1 COPIAR
this code means the system control board and the main control board are not communicating with each other. the new main boards have modified to prevent this code. to reset the code turn the main switch on the left side of the machine off for about 10 seconds then back on
Oct 04, 2009 | Konica Minolta Office Equipment & Supplies
Eror code 82-2 konica minolta 7145
eror code f_26_1 konica minolta 7145
Feb 23, 2009 | Canon imageRUNNER 400S Copier
KONICA 7145 PRINT DRIVER
The Konica Minolta 7145 have two different companies that made the print controller. If you have an older KM 7145 then you need the old Peerless Legacy driver. It's not on KonicaMinolta's website. You can use HP 5Si driver, but you won't have and of the options (ie finisher, fax, lcc).
Mar 14, 2008 | Computers & Internet
584 people viewed this question
k24674
Marvin
Marvin
