Question about Whirlpool GC5SHEXNS Side by Side Refrigerator
Hot refrigerator door jamb - Whirlpool GC5SHEXNS Side by Side Refrigerator
  • 672 Answers
This may be part of your energy saver. The opening around the door will be warm, but not hot to touch, to prevent condensation from forming during humid weather. If you have a switch in the frig marked energy saver, switch it to off, check to see if the frame cools. This feature is automatic in some makes and models and there isn't a control. If no condensation forms when it is switched off, it is not necessary to run the energy saver. Check the owners manual, if one is available, for information on your particular model.
Posted on Jul 11, 2009
4 Suggested Answers
22yooper
  • 828 Answers
SOURCE: subzero 630 hot door jamb
When the door heaters appear hotter than normal it is generally related to problems elsewhere. Refrigerator and or freezer not cooling. Check your temperatures inside. Clean your condenser(s). Check condenser fan motors to insure that they are operating.
Posted on Jun 21, 2008
SOURCE: KitchenAid Superba refridgerator, two-years old;
They tried replacing the fan motor but that didn't help. It just burned out in 3 days. Had to wait for a new control board in the fridge.
Posted on Jan 17, 2009
woodchuck789
  • 4070 Answers
SOURCE: The door jamb on our Kenmore refrigerator model
The condenser fan underneath the fridge is probably not running. It should be running when the compressor runs. You can place a floor fan back there blowing until you have it replaced.
There is a slight chance you have a defrost system failure causing the coils behind the back cover inside the freezer to ice up blocking air flow. This would also affect the temp in the fridge and freezer though.
Posted on Aug 13, 2009
Light won't turn off - very hot and heating up
HI. This is the direct result of a failed door switch. This switch controls the actual evaporator fan, as well. This dysfunctional switch must be replaced, asap. This replacement will correct your issues. The switch will generally be loctaed or mounted near the door jamb or recessed near the the door and unit structure intersecting areas or closing points. Once extracted, it can be tested for proper functionality with a ohm/multimeter.
Sep 22, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Want to disconnect door chime
A lot of times there's a little push button switch on the door jamb that resembles that of a refrigerator door switch. You can remove that switch and disconnect the wiring harness from behind it. If the switch isn't on the door jamb then it's incorporated with the latch assembly inside the door. You want to be carefull with disconnecting this harness because it will also serve the power door locks. I wouldn't recommend going down that path.
May 25, 2011 | Ford Explorer Cars & Trucks
Doors seif locking all the time wont stay unlocked
Get to the bottom of this, the next step is a circuit hot when you do not want it.
Most of these issues happen in the door jamb. Are all of the switches looking non damaged? disconnect the switches one by one to eliminate them.
Move the bundle in the door jamb and see if you can affect the issue. There are no successul repairs in this area, replace at least the entire run throught the jamb, but ideally the whole loom that you have to get to replace the jamb portion.
Sep 13, 2009 | 1992 Subaru Legacy
The jamb between the freezer & frig is very
It is common to be warm to the touch. If it is excessively hot then your door heater may be going out. Have a technician check it out. If this fails the doors will begin to sweat and drip onto the floor. Hope this helps. Good luck.
Aug 15, 2009 | KitchenAid Superba KSRS27CN Side by Side...
The door jamb on our Kenmore refrigerator model no. 106.53354300 is hot to the touch. Most items inside the freezer are soft.
Aug 13, 2009 | Refrigerators
I have a Hygena Built in fridge freezer and the freezer is defrosting and the fridge is not coming
hi try this On the refrigerator door jamb, locate a small push-button switch. This component operates the light inside the refrigerator. If the switch is malfunctioning, the light in the unit may stay on, and the heat from the lightbulb can cause cooling trouble in the box.
Step 1: Check the bulb to see if it is burned out. If not, depress the push button on the door switch.
Step 2: If the light stays on, clean the switch with a cloth. Then remove the switch from the jamb. Remove retaining screws hidden by a plastic trim piece, pry the switch out of the jamb with a screwdriver, or pry off the jamb trim to expose the switch. Then test the switch with a VOM set to the RX1 scale
Step 3: Clip one probe of the VOM to each terminal of the switch and press the push button. The meter should read zero. If the needle on the scale moves above zero, replace the switch with a new one of the same type.
Step 4: Connect the new switch the same way the old one was connected.
Sep 13, 2008 | Refrigerators
Whirlpool built in fridge
hi On the refrigerator door jamb, locate a small push-button switch. This component operates the light inside the refrigerator. If the switch is malfunctioning, the light in the unit may stay on, and the heat from the lightbulb can cause cooling trouble in the box.
Step 2: If the light stays on, clean the switch with a cloth. Then remove the switch from the jamb. Remove retaining screws hidden by a plastic trim piece, pry the switch out of the jamb with a screwdriver, or pry off the jamb trim to expose the switch. Then test the switch with a VOM set to the RX1 scale (instructions for using the VOM are given on page 19).
Sep 13, 2008 | Whirlpool Refrigerators
Sub zero 500 series
Yes you need a new fan motor... check the blades that there are free... door jams have heaters and will be hot this keeps them free of frost...let me know if I can help
Jul 04, 2008 | Sub-Zero 650 / O Bottom Freezer...
Subzero 630 hot door jamb
If the door jambs are hot, that is either a dirty condensor or a dead condensor fan motor. Make sure the condensor is vacuumed and check to see if the condensor fan is spinning. It should be running anytime either compressor is on. You can clear the service light by holdint the "alarm: button for 15 seconds or turning the unit off and then on again.
Jun 21, 2008 | Sub-Zero 650 / O Bottom Freezer...
Whirlpool GC5SHEXNS Side by Side Refrigerator Logo
398 people viewed this question
Top Whirlpool Refrigerators Experts
Sal De
Steve Allison
Steve Allison
Norman Worley
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
